DIY: 2006 Projector Cutoff/Color Mod
Old Feb 9, 2007 | 09:59 PM
  #76
IvoryGT's Avatar
3mm sounds good. The spacer needs to be able to fit just around the area of the holder and no interfere with the lens.
Old Feb 10, 2007 | 11:11 PM
  #77
tommy2go's Avatar
you dont have to put the 06 headlight into the oven?
Old Feb 10, 2007 | 11:22 PM
  #78
SuperShick's Avatar
of course u do.....that's how u open up the headlight
Old Feb 11, 2007 | 02:13 AM
  #79
IvoryGT's Avatar
sure do
Old Feb 18, 2007 | 02:39 PM
  #80
tommy2go's Avatar
lol argh alot of work...
Old Feb 18, 2007 | 09:22 PM
  #81
IvoryGT's Avatar
no one said modding was easy.
Old Feb 28, 2007 | 10:48 AM
  #82
05BLACK6MT's Avatar
06 projector
IvoryGT- I did some test last night with the 06 projector.
1- i did swap the lens to a old MDX lens ( the one with ripples )
2- I did use the same o-ring that I send you to space out the len
(note the o-ring is not big enough so I cut it and then cut another
short piece to add in the gap. This added piece have to be longer than
the gap to put some tenson to hold the oring onto the grove.)
3- i also used another smaller and thiner oring on the base of the bulb to give
it some more space.
The result is very good overall.
1. the lens swap give me the clean cut off same as the TSX.
2. The spacing of the lens give me blue color above the cutoff.
3. The spacing of the bulb give me more light out put to the ground ( you
know the area in the middle of the light in front off your car) and clearer
cut off.
Will do some more testing later on tonight. Can anyone show me how to put some pic on here ???
Old Feb 28, 2007 | 12:49 PM
  #83
IvoryGT's Avatar
photobucket.com it's free and it has automatically created codes to post on here.
Old Feb 28, 2007 | 03:36 PM
  #84
g35sedan5at's Avatar
wow...i responded to ivorys quesiton on page 1 bout sedans with projectors. ok im done feeling idiotic
Old Mar 7, 2007 | 07:52 PM
  #85
IvoryGT's Avatar
Updated. Ive done this about 4 times. The bi-xenon works perfectly and the color remains. The spacer is NOT applicable in this mod as it distorts the focal point much different than other projectors (M45 projectors does the same thing).
Old Mar 8, 2007 | 04:48 PM
  #86
redlude97's Avatar
What thickness spacer were you using and was it on an otherwise stock projector?
Old Mar 8, 2007 | 06:59 PM
  #87
IvoryGT's Avatar
it was about 3 mm. the focal point for this projector is just not between the lens and the shield. If you insist in using a spacer. I suggest also space out the bulb. to achieve the color and right cutoff.
Old Mar 13, 2007 | 12:42 PM
  #88
redlude97's Avatar
I started playing around with mine and I got something like this:
This was only at a distance of ~12ft using the stock 4200k 85122+ bulbs that haven't colorshifted yet, and shot onto an creme colored background. The rainbow pattern makes for some really colorful flicker patterns, and the camera doesn't capture the dark purple of the cutoff too well, the cutoff is a good 2-3" in width @ 12ft. Heres a video of the flicker from the projector
Old Mar 13, 2007 | 12:48 PM
  #89
IvoryGT's Avatar
that's very nice. did you do it with a spacer or what did you do. Because the band looks very uniform across. But the rainbow up top is a source of loss light to me. Though it is pretty.
Old Mar 13, 2007 | 12:53 PM
  #90
redlude97's Avatar
No spacer, I just followed your steps. I couldn't get rid of the rainbow no matter what I did. My lense is also kind loose inside the holder, the diameter is slightly smaller than stock, what did you do to stop it from moving?
