G35 Compression Rods are Total Crap
Old Jan 20, 2011 | 06:19 PM
  #361
buzzking's Avatar
The version of the TSB I have covers ONLY SEDANS. I have a coupe. Does anyone have the latest TSB? I am not sure how recent mine is but I have a coupe and I would like to get it fixed under warranty!
My TSB is dated April 29, 2009.
Old Jan 20, 2011 | 07:13 PM
  #362
OCG35's Avatar
you dont need a TSB to cover warranty items - if your compression rod bushings are bad and you are under warranty, they will replace...
The TSB is only telling service departments to stop replacing entire arm and press in bushing only - however, I've read that many dealers are still replacing entire arm.
If you are out of warranty - it's doubtful they will replace for free (regardless of the TSB)... on the other hand, some dealers will replace as "good will" - typically that's if you have a record with them of being a valued customer... I wouldn't count on that, but it's worth a shot...
if you are under warranty you have nothing to worry about.
Old Jan 20, 2011 | 07:26 PM
  #363
ELMACHOGERACHO's Avatar
there is no TSB for coupes.
Old Jan 20, 2011 | 07:27 PM
  #364
buzzking's Avatar
warranty
My car just hit 60K.
Which warranty do I need?
I have extended warranty still. Does that work?
Old Jan 20, 2011 | 07:29 PM
  #365
it depends on how comprehensive your extended warranty is
Old Jan 31, 2011 | 07:07 PM
  #366
bubbafresh's Avatar
So, both of my compression rod bushings are cracked, driver side worst than the passenger side. The dealer wants $458 + tax to replace both. Due to recent financial hardships I can't afford to drop $500 for bushings.
Was wondering if anyone has a good recommendation for a local shop here in the Bay Area (San Francisco) that anyone can recommend? I can order the bushing from Riverside, just need to find a place to press and install.
Thanks ahead.
Old Jan 31, 2011 | 07:20 PM
  #367
mbian's Avatar
i would recommend you replace the whole thing, because the ball joint side could be fault too, if you only replace bushings, you end of pay more.
there is a guy sell the pair only for $250 in California. if you handy, you could DIY.
Thanks ahead.
Old Jan 31, 2011 | 09:03 PM
  #368
buzzking's Avatar
Thanks ahead.
They won't cover it under TSB?
Old Jan 31, 2011 | 10:37 PM
  #369
bubbafresh's Avatar
@mbian I'd like to think my self handy, but looking at the DIY forum on this topic it doesn't seem like it's something that's straight forward. I wish someone would post a video of it since people discuss on this topic so much...
@buzzking, TSB is not a recall, and my 2004 G35 Sedan has been out of warranty for years.
Old Feb 1, 2011 | 10:50 AM
  #370
mbian's Avatar
if you replace the whole rod, it's very easy, only unbolt/bolt 3 or 4 nuts. I did it for my 03 G35 sedan.
Old Feb 1, 2011 | 12:28 PM
  #371
bubbafresh's Avatar
Thanks mbian. You mentioned there was a guy who's selling a pair of rods for $250? Looking on eBay and Riverside the cheapest is $180 each.
Thanks for the info.
Old Feb 1, 2011 | 04:14 PM
  #372
mbian's Avatar
I bought them from this Forum, the id is "TaiWG35".
Good luck.
Old Feb 4, 2011 | 01:25 AM
  #373
ryanwiggum's Avatar
how about a compression rod group buy?
Nismo and SPL are the only aftermarket options for compression rod bushings?
I'm looking to replace various worn out OEM bushings with Whiteline bushings, however I did not come across compression rods bushings.
Old Feb 4, 2011 | 10:44 AM
  #374
OCG35's Avatar
^^^ Energy just released a bushing kit, but I don't know if compression rod bushings are included - worth a look...
Old Feb 11, 2011 | 08:34 PM
  #375
Sunsetrider's Avatar
05 AT, 112,000 kms. IOW, just out of warranty - I just had my driver side compression rod replaced for $250 plus labor. I was getting rattles over slow-speed bumps and a fairly loud vibration sound at high speed. The replacement has fixed both issues.
Unfortunately I also had a limp issue and had to replace the throttle bodies at the same time. I just bought the car (private) 2 weeks ago, add $1,470 to the cost!
But now my only worry is keeping the shine on in this snowy weather! Love the car!
