Any one replace their lower ball joints?
Old Mar 23, 2014 | 07:38 PM
  #241
fonzer's Avatar
Originally Posted by Gdirtyfive55
Are you the original owner? I think the original is 17mm or 19mm. Yours may have been changed before. (If I'm understanding you correctly)
Good job on getting it done!
I am the oringal owner. Mine is a 2005, not sure if the previous years were smaller. Never changed them before either.
With not much mechanical experience, I can do one side solo under and hour….only because I had to pop them in and out a few times
But many thanks to this forum
Old Mar 23, 2014 | 09:04 PM
  #242
ScraggleRock's Avatar
Oh, ok. Mine is an 04 so they could have been revised in 05. Maybe that's why the aftermarket ones are 22. Originally tho mine were 19.
Old Mar 23, 2014 | 10:28 PM
  #243
joedaddy1's Avatar
how much are y'all paying for labor?
Old Mar 23, 2014 | 11:35 PM
  #244
$free.99
Old Mar 24, 2014 | 12:02 PM
  #245
fonzer's Avatar
I'm glad I changed out my own…made me learn more about my car. No doubt it's easier if you have a friend too. Just borrow a ball joint press kit from your local auto store, make sure you buy the right parts and you should be good to go.
Old Mar 24, 2014 | 02:28 PM
  #246
Frankieg35's Avatar
Does the balljoint press that you can rent come with everything you need to do the job??
Old Mar 24, 2014 | 02:49 PM
  #247
It doesn't come with a pickle fork/prybar (I needed a 3 footer to get that cone off), a wrench or a breaker to use on the wrench. I used a 4' fence pipe on the end of the wrench; Made it real easy.
Old Mar 25, 2014 | 09:01 AM
  #248
fonzer's Avatar
I couldn't get my cones off...but never thought about adding an extension to the pickle fork. Good advice here.
Old Mar 25, 2014 | 03:44 PM
  #249
Oh, yeah, I tossed the pickle fork aside and got a big prybar. Still had to put all my body weight on it and bounce up and down. Thing shot off like a bullet when it finally gave.
Old Apr 4, 2014 | 02:04 PM
  #250
Sarj06's Avatar
Hey,
I saw this thread come up so I thought I would share what I had recently done on my '07 G35x.
Sooo....$800 later.......Front passenger side lower suspension replaced, ($550), alignment ($120), plus taxes....everything is all good to go....
Here are the pricier part numbers to what was replaced....
54500-1NA4B (lower link) ($300)
55044-EG01A, 54550-EG00A, 54580-EG00A, 40262-EG010 ($24), 40173-EG000, 39241-CG027($60), etc...etc...
Old Apr 8, 2014 | 11:02 PM
  #251
herrschaft's Avatar
Anyone know if this ball joint can be purchased separately:
Old Apr 9, 2014 | 12:06 AM
  #252
That balljoint is irreplaceable. You have to buy the whole arm. I sell the whole arm with energy bushings pregreased and pressed in if you're interested.
Old Apr 9, 2014 | 12:11 AM
  #253
herrschaft's Avatar
Oh well. I already have the Whiteline bushing installed in it so I'm just going to pick up another arm and swap the bushing.
Old Apr 9, 2014 | 02:10 AM
  #254
That's what's up.
Old Apr 17, 2014 | 10:53 AM
  #255
mikeygsens's Avatar
Is there any other way besides buying the entire knuckle to get a front lower ball joint for 06 G35 AWD? I have already ordered a Vollig part off of ebay and the shaft was thinner in diameter. Should I be using a thicker sleeve?
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
