Any one replace their lower ball joints?
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jan 22, 2015 | 11:27 PM
  #286
Rob902's Avatar
Lower control arm
For my 2004 g35x I can't seem to find any aftermarket lower balljoints. I believe the balljoint that connects to knuckle only comes with the knuckle assembly. But there's a second balljoint that is bolted in with 2 bolts. The new control arm I purchased from the dealer does not have this ball joint. Can anyone tell me if this ball joint is is sold separately?
Old Jan 22, 2015 | 11:58 PM
  #287
ScraggleRock's Avatar
Most (maybe all?) ball joints and control arms for the X are dealer only. Bummer.
The lower ball joint has to be bought as the whole steering knuckle assembly. Double bummer.
Old Jan 28, 2015 | 06:35 AM
  #288
InfinitiGeeX's Avatar
So AWD owners are SOL? All I can find are the Vollig and Duralast ball joints. I ordered the Vollig ones a few weeks ago but they got lost in the mail. It doesn't help that I'm currently in Canada. Either I reorder the Vollig or I get my cousin to send me the Duralast ball joint from USA. Shipping will be expensive regardless.
http://www.ebay.ca/itm/New-Premier-F...a34b25&vxp=mtr
http://www.autozone.com/suspension-s..._376835_11395/
I'm not sure how the Vollig ball joints are compatible with both RWD/AWD. Surely there will be fitment issues.
Old Jan 28, 2015 | 06:21 PM
  #289
akoustic's Avatar
Sorry to hear that... I replaced mine with SPD ball joints from ConceptZ. It worked out just fine. The mechanic broke his presser trying to take out the original ball joint LOL!!! Not sure about AWD compatibility though... Good luck!
https://conceptzperformance.com/Cart...n.php?II=12275
Old Jan 29, 2015 | 09:48 AM
  #290
joedaddy1's Avatar
how much did you pay for the install?
Old Jan 31, 2015 | 03:28 PM
  #291
digital sol's Avatar
How are you getting that stupid cone off the top of the ball joint? I am beating the **** out of it and prying it with a pickle fork for the last hour. Even used a breaker pipe over it and tried prying it up but no luck. I can hammer it all the way in but the cone itself dosnt budge. I have 3 different sizes ive tried
I am considering making the trip to get a pneumatic fork & use my air hammer or cutting off the stud
Old Jan 31, 2015 | 04:53 PM
  #292
i took the trip to harbor freight, bought a pneumatic pickle fork and it flew off in <30 seconds.
Old Jan 31, 2015 | 07:40 PM
  #293
I got a 3' pry bar, found a good place to pry it, and still took my whole body weight bouncing on it a few times. When it came off it shot off like a bullet. Be careful.
Old Feb 1, 2015 | 02:23 PM
  #294
Originally Posted by dtg35
I just completed replacing the drivers side ball joint on my 03 coupe. I bought the ball joint from Concept Z performance and it seems like a quality unit. Also, since i live in AZ and there is no Advanced Auto to rent the ideal ball joint press kit, I rented the ball joint press kit from my local Autozone and also rented the Ball Joint adapter set #27166. They worked perfectly. I've never pressed out anything before and these two kits made it a trouble free job.
You have any issues with the boot covers? On mine they are not really fully against the base evenly. The boot slides up and off rather easily but dosnt wanna budge all the way down.
Edit: Checked out pics online, seems normal for the boot not to sit 100% on the base. The boot gets squished down a little from pressure after its bolted back down anyways. Time will tell!
Old Feb 2, 2015 | 12:02 AM
  #295
Frankieg35's Avatar
I got mine to sit around the base, took a bit and some patience but i thought it was important to do so i took the time..
Old Feb 9, 2015 | 04:04 PM
  #296
I reordered the eBay ball joints on 1/28 and they arrived today ($32 shipping). I noticed the brand is MTC and not Vollig as stated in the listing.
MTC# 1010163
Ball Joint Only
OEM # 40015-AL55BJ
5/22/14
www.mtcparts.com
So I emailed MTC today and they said it isn't compatible with AWD models. I messaged BremenTech (eBay) before purchasing and they confirmed that it is compatible. I even left a note at checkout, "For a 2005 G35X AWD Sedan."
Here's the item on Amazon.
Amazon.com: Nissan 350Z Infinifi G35 Ball Joint Kit - Front Lower Control Arms | Two (2) Pieces | Fits Left and Right: Automotive Amazon.com: Nissan 350Z Infinifi G35 Ball Joint Kit - Front Lower Control Arms | Two (2) Pieces | Fits Left and Right: Automotive
Such as waste of time. Can anyone confirm if the ball joint from Autozone is actually compatible with the G35X AWD? Thanks.
Old Feb 9, 2015 | 06:57 PM
  #297
Rob902's Avatar
MTC# 1010163
Ball Joint Only
OEM # 40015-AL55BJ
5/22/14
www.mtcparts.com
Almost 99% sure awd and rwd are different. I seen these on eBay but I don't trust them and for 500$ it's robbery. http://m.ebay.com/itm/151069010061?_mwBanner=1
Old Feb 9, 2015 | 07:00 PM
  #298
Rob902's Avatar
The ball joint comes with the steering knuckle. They are about 300$ a piece from Infiniti parts usa. I'm in the same boat
Old Feb 10, 2015 | 06:06 AM
  #299
The ball joint from Autozone and eBay look exactly the same. I think the one from Autozone only fits the 2WD. Clearly an error in the listing.
Old Feb 10, 2015 | 07:20 AM
  #300
Anyone have a picture of an extracted ball joint from an X for comparison so we can finally put this unicorn to rest?
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
