NEW SPL PRO front compression rod bushings
Rating: Thread Rating: 3 votes, 4.67 average.
Old Oct 20, 2010 | 06:01 PM
  #121
sexyrob's Avatar
finally got mine, now I just need to install them. I'm dying to feel the precision.
Old Nov 14, 2010 | 09:34 AM
  #122
SpForces's Avatar
Ah, Cant freaking wait. I figured these were going to be great. Thanks for confirming it.
Old Nov 29, 2010 | 09:51 PM
  #123
skyline250GT's Avatar
Andrei, were the compression rod bushing very difficult to press out? Do you think they can be pressed out with a vice or a even a big G-clamp? I have ordered the compression rod bushings and considering whether I should buy a cheap hydraulic press or try to DIY it with basic tools. Thanks.
Old Nov 29, 2010 | 09:59 PM
  #124
sexyrob's Avatar
got mine in, they feel soooo good, wish the car had these from the factory.
Old Nov 29, 2010 | 11:41 PM
  #125
AARONHL's Avatar
Originally Posted by skyline250gt
do you think they can be pressed out with a vice or a even a big g-clamp?
no way jose
Old Dec 2, 2010 | 09:09 PM
  #126
2006g35sedan's Avatar
The TSB calls for up to 4.5 tons force or 9000 pounds force. I don't think you'll get that out of a c-clamp or vise...
I bought this press specifically for this job:
Amazon Amazon
I justified buying the press by getting the cheaper OEM bushings instead of the SPL ones. 1 press + 2 oem bushings ~= 2 SPL bushings not installed
Old Dec 2, 2010 | 09:56 PM
  #127
sexyrob's Avatar
^ have fun changing them out again when they rip again...
but good buy on the press. I need to get one.
Old Jan 4, 2011 | 02:50 AM
  #128
Invalid_User's Avatar
So is it $167.00 for 2 bushings?
Or is it 167 each bushing?
Old Jan 7, 2011 | 11:36 PM
  #129
tyau's Avatar
Used spherical bushings on my s14 240sx. They wear out extremely quickly if exposed to dirt. They wear out even quicker when there's water delivering dirt into the bushings. My friends used SPL control arms with similar bushings. They all wore out and started to clunk within a year. They are probably good for track, but daily driving will wear them out mainly because dirt will go in. I don't think they are teflon coated either.
Old Jan 8, 2011 | 03:05 PM
  #130
04G35NYC's Avatar
I guess these feel exactly like the OEM in terms of ride quality. The price is a big difference but driving in NY i think these will last much better with worse roads then the oem.
Old Jan 8, 2011 | 07:42 PM
  #131
tyau's Avatar
stfu noob, the price is for a pair.
Old Jan 8, 2011 | 07:53 PM
  #132
WhosRich's Avatar
Lol. I thought you were actually calling him a noob.
Old Jan 8, 2011 | 07:59 PM
  #133
tyau's Avatar
LOL i just noticed that! Bad choice of user name,
Old Jan 26, 2011 | 12:12 PM
  #134
Dan_K's Avatar
What is the noise when the compression rod goes back?
Would it be necessary to replace the front lower arm bushings as well? That's an extra $300 from SPL.
Old Jan 26, 2011 | 12:21 PM
  #135
sexyrob's Avatar
not unless they've gone out... I'll end up replacing my lower arm bushings as a preventative measure because after feeling the SPL compression rod, I know it will only get better the more I replace.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.67 average.
