Pirates coilovers
#406
#407
#408
#412
cz... I hope you get an answer on the clank from some other pirate that has this sorted out.
1) Did you re-check your installed valve dampening settings to be sure nothing is broken or not functional inside the shock tube?
2) I'd notify racingfirst of your noise issue it sounds like their problem.
3) Are you certain the passenger side and driver side shocks are set to the same distance? Your slammed story makes me think you could not have been off by more than 1 thread of rotation. That is nothing.
My pirate coilovers are on car 7 months and 3000+ miles, never an issue; noises or unsatisfying road handling. This is a fact.
I hear you saying something along the line of factory defect, I think. Clanking or hand forced free play of the un-installed piston/ rod in the shock body is a warranty complaint that should immediatedly be documented with racingfirst for replacement.
The piston/rod must be very rigid in all side hand pushed/shook tests and very slow to compress the rod by hand using your body weight outside of the car.
No noise whatsoever on the uninstalled shock.
4) Just for talk; how low was your maxed out drop? I hope you measured the rocker panel to the ground and most coilover people claim the body drop from the OEM fender / ground distance to the dropped change after install. Both measurements would be helpful information since the question of max slam on pirates has never been clearly posted. You seem to have made that mistake haha.
Those slammed, slow and low G's on any coilovers must not drive around much in a practical way. Maybe to meets at parking lot's to show off, get pic's and post the greatness of low.
And if I were like that /I'd pack wood boards to use as steps as driveway crutches, if you all envision what I mean.
cz...Just for a base OEM height my 2003 sedan with sport 17's fender height was 28" above the ground.
Czarlos,
Yer light winded message o' woe, it sent us all far off course. We have fun ere matie with these cheap stinkers. Well at least sometimes, it can be funny when a limp torpedo is launched.
Arr, squiddy, I got nothin' against ya. I just heard ya say there was rattle problems with yer G "pirates" right out o' the box on her maiden voyage. Ha ha Harr,Harr Harr.
Arr, Ebay - Racingfirst be in a lotta trouble now fer your complaints. Hey, if yee made contact with those trading partners last week after the failed install, did they take the blame?
Let us "shamed pirates" know what tis it they sez to ya. Narr, no secrets be kept ere, join the crew and help us.
A few things in update, started having a whooshing sound out of passenger rear strut, then realized I accidentally loosened the dampening adjuster on that strut. Retightened and solved the whooshing sound over bumps.
However, still have the clunk, its on both sides and is terribly loud. I messaged Racingfirst and warrantied the rears, they shipped them out around 1am PST, they should be here sometime in the middle of next week. I am really starting to think the noise is bad or poorly lubricated pillowball mounts binding and hitting. Has anyone greased these? A good friend of mine has some blown Topspeed MDU rears and I want to possibly swap mounts to see if there is a difference in noise.
This time around I will try to keep you guys posted, so far this thread has been a wealth of info.
Oh and I never got fender to ground measurements, but I am sure they'd be off as I have these on my 04 Z. If I can get the sound to go away I might be able to drop the car all the way down to see how low they go. I know with zero preload they are almost undriveable in terms of bottoming out, but still reasonable to navigate the streets.
#413
And in response to someone asking about air suspension,
You could literally use any coilover kit to do a custom bag over coil setup. Did the same thing on my GF's BMW. Its pretty simple, but you'd definitely want someone to make you (or even DIY if you know what your doing) a set of threaded brackets. Otherwise your airbag might move around and you'd rip out an airline and be stranded.
#414
CLUB MODERATOR
#415
#418
Update,
Removed the rears, noticed one of the pillowball mounts was super loose to the point where I could hand tighten the nut on top. And the other had a small amount of shock fluid pooled on the strut.
For the mean time I threw on my OEM rears and noise is pretty much non-existant.
#419
#420
About 4 days for me haha
I don't give up that easy! Just received my new rears so its time to swap them again!
Yes I messaged RacingFirst and they were more than accommodating, no charge whatsoever to me. Not even shipping! Great seller
