Another G sedan with 350z suspension *PIX*
Old Feb 9, 2010 | 01:13 PM
  #226
NFSP G35's Avatar
? = 2B || !2B
^IDK about the shocks/struts
Best bet would be to ask ther person you got them from what year the Z was. Only problem is if it's 04 you'll have to figure out if it's the half year or not.
If the rear springs from the Z they originally came off of have 1 purple dot and 2 red dots then it's revised suspension.
Old Feb 9, 2010 | 01:17 PM
  #227
Hammerhead i-Eagle Thrust's Avatar
if u have all the struts it doesnt matter if the springs are revised or not aside from the rear maybe being too low i guess
Old Feb 9, 2010 | 01:23 PM
  #228
NFSP G35's Avatar
? = 2B || !2B
^I was under the impression that the damping on the shocks was different for the revised suspension.
Old Feb 9, 2010 | 01:27 PM
  #229
yeah but if he has the complete suspension, revised or not, it will work fine
i think the problem is mixing the revised rear springs with g struts
Old Feb 9, 2010 | 01:29 PM
  #230
GAU-8's Avatar
So any year Z spring set works? What would I need to get to keep the G level front to rear?
Old Feb 9, 2010 | 01:37 PM
  #231
NFSP G35's Avatar
? = 2B || !2B
Z springs in front (any year will do)
Non-sport coupe springs in back (any shocks except non-sport sedan shocks)
Old Feb 9, 2010 | 01:38 PM
  #232
GAU-8's Avatar
Why non-sport coupe? Is there that big of a spring rate difference between the sedan and coupe for non-sport?
Old Feb 9, 2010 | 01:46 PM
  #233
QUiKSR20's Avatar
Hello GAU-8,
All this info is in the thread :
For spring colors specs and rates etc see page 10
https://g35driver.com/forums/brakes-...on-pix-10.html
This whole thread is for running Z/G Coupe spring setups not aftermarket springs. All Z front springs are the same as G Sport Suspension spring rates. Now on G Coupes and Z's they went to a revised spring rate I believe in 2005 or so+ when they offered 19" rims and the rates went up.
If you go with NON REVISED Z or G Coupe ( NON SPORT ) you keep your spring rates the same as your G Sedan has and still attain the drop your looking for.
You can goto REVISED but you will have a stiffer spring and would require rear struts that match. Not your stock non sport or sport struts.
Hope this helps.
Old Feb 9, 2010 | 01:49 PM
  #234
NFSP G35's Avatar
? = 2B || !2B
^A sport coupe has revised z springs in the back. If you're going to do that, you might as well go z all the way around.
Maybe this will help: http://www.nfspmotorsports.com/forum...php?topic=51.0
  #235
he said he has z struts though
Old Feb 9, 2010 | 01:56 PM
  #236
NFSP G35's Avatar
? = 2B || !2B
^ You're freaking killing me here!!!
Old Feb 9, 2010 | 02:04 PM
  #237
GAU-8's Avatar
Originally Posted by QUiKSR20
Hello GAU-8,
Hope this helps.
So you linked me back to this thread? Lol! Page 10 means nothing to me since I'm at 50 posts per page. So G coupe non-sport springs or Z unrevised springs front/rear should work? As I wrote previously, I don't want any aftermarket parts. I found out from the seller that I have 05 Z shocks/struts. I do want to be able to upgrade wheels at a later time.
Old Feb 9, 2010 | 02:10 PM
  #238
lol
sorry im not paying that much attention
whats the problem again?
Old Feb 9, 2010 | 02:22 PM
  #239
NFSP G35's Avatar
? = 2B || !2B
^Then get Z springs for the front (all are the same), and non-sport coupe springs for the back.
Old Feb 9, 2010 | 02:24 PM
  #240
i dont get it, if he has full revised suspension why should he buy more springs?
