Canada Serving Canada.
Compression rods replaced
Old Nov 7, 2008 | 06:29 PM
  #61
STCLAIRWEST's Avatar
is it under power train warranty or bumper to bumper? if i change my rims and springs would it affect my warranty?
Old Nov 11, 2008 | 05:38 AM
  #62
reconJDM's Avatar
no, the comp rod is not under powertrain warranty since it doesn't effect the motor or transmission, as for bumper to bumper; what year is your car? likely the 2003-2004 bumper to bumper is over and you are not eligible for compression rod replacement.
not too sure about springs.
Old Nov 13, 2008 | 02:46 AM
  #63
nibble's Avatar
Originally Posted by LD500
Just had my compression rods replaced on my 2005 G35X and was curious where it's located. I looked under the car around the front tires but didn't know which one was the compression rod.
Here's a pic:
I'm getting one of mine replaced this week, hopefully it will fix my clunking noise issue.
Old Nov 13, 2008 | 11:25 AM
  #64
SGSash's Avatar
We may be able to help you guys do it a bit cheaper, but I really can't say much more without being a vendor unfortunately
Email me or PM me for info, I hate to see you guys spending 1000+ to get two of these things replaced.
sanis@sg-motorsport.com
Thanks!
Had no idea it was such a common problem on G35s, but the revised part should hold up better.
Old Nov 15, 2008 | 08:48 PM
  #65
dubbletrubble's Avatar
It will get rid of the klunking, I just did mine the other day after a year of klunking and it is heaven. I would have done it sooner but I live in Kingston and I am nowhere near an Infiniti dealership
Matt
Old May 12, 2009 | 04:27 PM
  #66
Jasonp32's Avatar
Originally Posted by obender66
All knocking is gone!
Damage-parts $364 USD shipped from Riverside
Tax and Brokerage $90
Labour 1.5 hours $125
Total $579, say $600 CAD for both sides. Far cry from $800-1400 quoted by local dealerships.
Did you have to do anything from a customs perspective when you ordered your compression rods from Riverside Infiniti? You mentioned it cost you $90 for tax and brokerage. Did you just pay Riverside by paypal or credit card for the parts, then you get billed the $90? Or did you have to contact a broker to get your parts across the border?
I need to do the same thing and was just curious about the process.
Thanks.
Old Mar 24, 2010 | 11:36 PM
  #67
batanatoly's Avatar
I have same problem (05 G35 Coupe) please anyone. I want to know how you replaced the compression rod. I will be changing them soon.
Do I need to remove the cross arm underneath the compression rod (where the rod is mounted), how do I take it out.
Pictures will be very helpful.
Thank You
Old Mar 25, 2010 | 11:41 AM
  #68
Shawn87's Avatar
Thank You
Just the under carriage.
Old Mar 25, 2010 | 12:26 PM
  #69
416dawn's Avatar
If you are interested I can give you coupe c. rods for 253,- each, and sedan for 270,-.
Taxes are extra, pick-up in Ajax Nissan.
Old Mar 25, 2010 | 04:41 PM
  #70
batanatoly's Avatar
What do you mean under carriage (what exactly)?
I’m just wondering how the rod will go out since there is a bolt going through it.
appreciate
Old Mar 25, 2010 | 04:44 PM
  #71
Shawn87's Avatar
appreciate
yep remove the red part its like 8 bolts. then you have to take the bolt for the compression rod. its usually fused in there. We had to torch it to heat the sleeve up to pull it out. What a bitch of a job.... the old boot caught fire... car started smoking lol
Put alot of anti seize on it when you put the bolt back in.
Old Mar 25, 2010 | 05:49 PM
  #72
batanatoly's Avatar
Thanks, that really clarify everything.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
