DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Old Jan 23, 2010 | 01:58 PM
  #76
RaginRaj11's Avatar
so for n/a application, going from a 3.3 to 3.5 rear diff will improve off the line acceleration or highway acceleration the most?
Old Jan 23, 2010 | 02:53 PM
  #77
OCG35's Avatar
off the line...
however, in any rmp range you will feel snappier/zippier acceleration...
It takes a little getting use to though (at least 3.7)... when you are accustom to being in 3rd for example, you will now be in 4th a bit sooner... (applicable to all gears - but 3rd is most relevant to me because I'm in that gear most during street driving)
Old Jan 26, 2010 | 01:04 PM
  #78
chinabean's Avatar
mmm 27th seems so far away
Old Jan 26, 2010 | 01:40 PM
  #79
SyCo's Avatar
Originally Posted by OCG35
off the line...
Maybe someone with better mathematical knowledge than me could reproduce the same explanation as I found below for a BMW but of course applied to our G35 ???
Very interesting nonetheless ...
Originally Posted by Carver
***The benefits of a shorter gear ratio in the E46 M3 ***
A member asked me to come and give my $.02 here so that hopefully some truth and some understanding could be gained.
Now, in physics, engineering, and design, as in many other fields, there are always multiple ways to arrive at the correct answer. Elegant explanations generally consist of the most basic examples which most clearly demonstrate the proof with a minimum of complexity.
Ok, so we can solve this problem in any one of these ways:
a) Area under the HP curve along with time
b) Area under the TQ curve along with time and gear ratio
c) Total work through integrated force and distance
d) Kinetic energy through fuel burn and time
e) Impulse through integrated force and time
f) Power through integrated force, distance and time
g) Force:time ratio with time in gear
h) A couple more which are really derivations of the above
So, which one of the above is the most elegant, meaning simple and easy to understand while yielding accurate results?
g is by far. Why? You use the fact that both cars have the same mass, burn the same fuel, have the same horsepower curves, have the same torque curves (redundant), use the same transmissions, have the same wheel/tire rolling diameters, have the same aerodynamic drag etc.
By cancelling these similarities out, you come up with a basic F=mA and time ratio along with speed which clearly tells the story.
Here we go.
F(t) = the time function of force at the crankshaft
since we're not interested in the actual time or distance of the race but a relative position of the two cars in relation to gears and each other, as we race through time, the functions will cancel out as each car runs through it's powerband. Remember, the only reason this works is that we are comparing the cars with identical tq/hp curves in a ratio and not looking for an absolute value. If we wanted actual time or distance separation, we would have to integrate the torque curves over time along with the gearing to get actual force derivatives. That's why this ratio is so powerful and easy. You don't need the actual integration of the area under the curve. With axle ratios of 3.620 and 4.100 and gear ratios of 4.230, 2.530, 1.670, 1.230, 1.000 and .8300 we have 11 unique force ratio stages yielding unitless distance units when combined with speed and time or acceleration in each gear. Call the distance factor d(g) or distance separation relative to gear with all of the distance units summed. We will make positive values the 4.100 car and negative values the 3.620 car. The distance units are a constant distance/time ratio derived from the force ratio ie. it is torque/mass independent. That's why there are no units. If you used actual derived integrated torque and mass, you could figure out the actual distances.
Car A = 4.100 car, Car B = 3.620 car
Stage 1-Both cars in first-ends at 36mph
(17.34-15.31)36/(15.31*17.34) = .2752 distance units total d(g) = .2752 du
What this means is, depending on the identical torque or HP curves of the cars (the same for each car) and their identical masses, there is a constant times the distance factor which will give you the car's relative positions in actual units ie feet, meters etc. Car A is .2752 distance units ahead.
Stage 2-Car A shifts to 2nd gear-ends at 40mph
(15.31-10.37)4/(10.37*15.31) = -.1245 du total d(g) = .1507 du
Continuing the process, Car B had an advantage of .1245 du from 36mph to 40 mph and closed the gap to .1507 du, but didn't make up for the advantage Car A had to 36mph. Why? Even though the percentage advantage of Car B was greater in Scenario 2 than the advantage Car A had in Scenario 1, the time available was much shorter from 36 mph to 40 mph than from 0-36 mph.
Stage 3-Car B shifts to 2nd gear-ends at 60mph
(10.37-9.159)20/(9.159*10.37) = .2550 du total d(g) = .4057 du
Car A is now .4057 du ahead. The extra time in identical gears for the 4.100 car is too much of an advantage compared to the short period of time the 3.620 car has in the lower gear.
Stage 4-Car A shifts to 3rd. gear-ends at 68mph
(9.159-6.847)8/(6.847*9.159) = -.2949 du total d(g) = .1108 du
Car B gets a break because of the big jump in the M3's 2nd.-3rd. gear ratios and closes the gap to .1108 du.....car A still leading.
Stage 5-Car B shifts to 3rd. gear-ends at 90mph.
(6.847-6.045)22/(6.045*6.847) = .4263 du total d(g) = .5371 du
Car B pays dearly for the combination of the 3.62 rear end and the M3's 2nd.-3rd. gear ratio split....Car A is now .5371 du out in front.
Stage 6-Car A shifts to 4th. gear-ends at 102mph.
(6.045-5.043)12/(5.043*6.045) = -.3944 du total d(g) = .1427 du
Car B takes advantage of the 12mph that it can stay in 3rd. Notice however that on each chance that Car B has to do this, Car A is still slowly increasing it's advantage.
Stage 7-Car B shifts to 4th. gear-ends at 123mph.
(5.043-4.453)21/(4.453*5.043) = .5517 du total d(g) = .6944 du
The extra time it takes to reach each speed is now starting to favor the 4.100 car's rear wheel force advantage even more. Notice each even and each odd stage gap is increasing.
Stage 8-Car A shifts to 5th. gear-ends at 139 mph.
(4.453-4.100)16/(4.100*4.453) = -.3094 du total d(g) = .3850 du
By looking at the jump from stage 6 to stage 8, you can see that the 4.100 car is taking advantage of the big 4.100-3.620 advantage while having closer gear ratios.
Stage 9-Car B shifts to 5th. gear-ends at 151 mph.
(4.100-3.620)12/(3.620*4.100) = .3881 du total d(g) = .7731 du
Notice that each advantage is greater for Car A than Car B as long as the gear ratio jump isn't too large.
Stage 10-Car A shifts to 6th. gear-ends at 171 mph.
(3.620-3.403)20/(3.403*3.620) = -.3523 du total d(g) = .4208 du
Car B gets a little help from the 5th.-6th. jump in ratios on Car A but it's not enough.
Stage 11-Car B shifts to 6th. gear-ends at 182mph.
(3.403-3.005)11/(3.005*3.403) = .4281 du total d(g) = .8489 du
Notice that the gap at the top of 4th in the 4.100 car at 123mph is 2.5 times the gap at the top of 1st. gear (a good rough 1/4 mile+ example) The main idea here is that the advantage and time the 4.100 car has in the same gear as the 3.620 overcomes the advantage the 3.620 has in a lower gear because of less time in that scenario. Another way to say it is when you integrate force at the rear wheels (F=mA), the sum of F(4.100) over time is greater than the sum of F(3.620) over time up to the top speed of the 4.100 car. As a result, the total integration of acceleration over time is greater in the 4.100 car. Notice also that the outcome was partially dependent on the M3's ability to hold a gear for a long period of time ie. flat torque curve and high redline. I could do a proof showing that for the M3's gearing, the optimum shift points are actually up in the 8400-8700 rpm range depending on the gear change. Obviously an added shift, corner, or turbo car spool time etc. between cars on a track could change this equation, but that is a different argument.
As a side point, what you feel as a driver/passenger isn't always what the clock shows. The human body is pretty good at feeling force but not very good at feeling the integration or time of force. That's why quite often a turbo car will "feel" faster than an NA car of equal acceleration because of the torque peak or "hit" of the turbo. Likewise, the added force in each gear of the 4.100 car will "feel" faster than it really is because of the force increase. You won't notice the reduced time of the force in each gear as much. It wouldn't be surprising to see someone reduce their 1/4 time by .3sec with a 4.100, but "feel" like the car is over .5 sec. quicker. Since most people get an M3 for how it "feels", this is even more of a reason to go with a 4.100 differential. A 400rpm increase on the highway, imho, is nothing with this car. The M's moderate torque and high redline along with fairly large weight make the argument for the added force "feel" even more weighted toward the 4.100 side.
My $.02
Happy New Year
__________________
Andrew
Old Jan 26, 2010 | 02:09 PM
  #80
DaveB's Avatar
I've been saying this for years regarding the use of deeper gear ratios. The claims regarding gear swaps on this site and my350Z are pretty comical. By many, it's accepted that deeper gears on a G/Z will result in a .3 to .5 improvement in the 1/4 mile. However, most of this belief is based off seat of the pants feel and not real 1/4 mile data. When you add deeper gears, the car is going to feel more responsive and faster because of the increased torque multiplication, especially in the lower gears when you first hit the pedal. The reality is seat of the pants feel doesn't jive with 1/4 mile acceleration numbers. A great example was my friends 90 LX 5.0 Mustang. He swapped the 3.27 gears for 3.73 gears. The car felt like it gained 50hp/tq and it felt so much stronger at any speed below 80mph. Under the times though, it was only .15 second and 1mph faster.
Old Jan 26, 2010 | 02:30 PM
  #81
OCG35's Avatar
my 1/4 time and trap speed have been better since the gears...
I have never heard anyone disappointed about getting shorter gears... take that for whatever its worth to you.
BTW, on paper - given all factors... it's pointless to modify this car (taking everything into consideration)
Edit: previously posted that there were other changes to car as well... after thinking about it - all I did was FD & differential at that time... 1/4 was faster.
Old Jan 26, 2010 | 03:24 PM
  #82
SyCo's Avatar
Originally Posted by DaveB
[...] A great example was my friends 90 LX 5.0 Mustang. He swapped the 3.27 gears for 3.73 gears. The car felt like it gained 50hp/tq and it felt so much stronger at any speed below 80mph. Under the times though, it was only .15 second and 1mph faster.
At least he was faster That's what I'm looking for ! Winning by an inch is still winning!!
But seriously, I've read your posts when you did some tests with smaller tires and all... and I agree that upon certains circumstances (1/4 mile specific runs) you do not always benefit from shorter gears.
If someone could translate the numbers (0 to top speed) from an M3 to a G35 it would be nice also
Old Jan 26, 2010 | 03:33 PM
  #83
Jeff92se's Avatar
Red Card Crew
Dave. That mustang swap is about a 14% difference. If that 5.0 was putting out 300 hp or so, 14% of 300 hp is about 42 hp.
Old Jan 26, 2010 | 04:08 PM
  #84
Tollboothwilley's Avatar
Those numbers from the M3 to G35 are different but not by much.
3.3 FD top speed for 5AT in 1st gear is 40, with 3.5 its around 38.
The problem with the shorter gearing is the added shift that you need. If you have a faster shift (valve body kit) this shortens the loss of acceleration time dramatically and will definetely decrease your 1/4 mile time. Especially if you are able to increase the redline by a couple hundred RPMs.
Old Jan 26, 2010 | 05:29 PM
  #85
OCG35's Avatar
fixed
Old Jan 26, 2010 | 11:53 PM
  #86
LOL. ya...just a typo...
Old Jan 27, 2010 | 11:42 AM
  #87
DaveB's Avatar
Yeah, my short tire DR radial combo results in an effective ratio of around 3.55+. The car definitely felt snappier with the short rear tires. When I tested it at the strip on the same day with the OEM 17s, the car was actually fractionally (hundreths) slower with the 3.55 ratio. One of these days when it warms up, I'll install my 3.54 pumkin. With the 3.54s and the short DRs, the ratio will be close to a 3.80. We'll what happens. I got the 3.54s with VLSD more for auto-x than anything.
Old Jan 27, 2010 | 11:45 AM
  #88
DaveB's Avatar
He wished that thing had 300hp It only had a 2.5" catback, timing advance, and pullies. It made about 220whp/270wtq. Thing is, that 5.0's power dropped off like an anvil after 4900rpms. I loved that car though.
Old Jan 27, 2010 | 08:15 PM
  #89
SDGenius's Avatar
mine came!!! damn that fvcker was heavy... lookin' like install's gonna run under $400. got a few other projects ahead of this one, but glad to already have this piece on hand.
Old Jan 27, 2010 | 11:22 PM
  #90
you doing the install yourself? $400 = parts + install?
