Mobil 1 Oil users
Old Jan 13, 2009 | 03:11 PM
  #271
Jeff92se's Avatar
Red Card Crew
Originally Posted by Braintree
Mobil 1 is a phosphodiester bonded, polymer based, synthetic lubricant with anagrelide, isosorbide momonitrate and hydroxychloroquine additives not found in other synthetics.
Jeff, Jeff, Jeff.... it doesn't really matter what I think about Mobil 1. The context of our (the last couple of commentators) collective comments was that the most important variable is not your oil alone, it's how you maintain and use your car overall.
If that were the case, I'm confused by your comments. Your previous comments were to clarify it was inconclusive as to Mobil's base stocks. I'm confused as to why you choose to specifically address this specific subject if it weren't revelant to the overall conversation at all. Especially when this thread is specifically about Mobil 1's base stocks.
For the record, I never questioned Mobil 1's quality or it's ability to protect. I was addressing the point of the thread. And that was Mobil 1's definition of "synthetic". Which is briefly (but indirectly) is addressed in the article you posted (one that you apparently legitimized).
Old Jan 13, 2009 | 03:14 PM
  #272
WILLIE BEANS's Avatar
Old Jan 13, 2009 | 03:17 PM
  #273
Jeff92se's Avatar
Red Card Crew
Originally Posted by wingsprint410
Exactly- other than neglect- when is the last time you have heard of a OIL related engine failure?
My point is too many people focus on brand. The fact is it just does not matter.
Although I'll generally agree that due to the oil change frequency of most here, oil brand is less important.
But I'll also point out that instances of oil related engine failures isn't a good example in this discussion.
One could run oil damaged for many miles. A neglected engine that's running far from it's peak performance potential is still a running engine.
Old Jan 13, 2009 | 07:05 PM
  #274
Braintree's Avatar
Originally Posted by Jeff92se
If that were the case, I'm confused by your comments. Your previous comments were to clarify it was inconclusive as to Mobil's base stocks. I'm confused as to why you choose to specifically address this specific subject if it weren't revelant to the overall conversation at all. Especially when this thread is specifically about Mobil 1's base stocks. [Braintree quote: The discussion was academic in nature since many folks were adamantly and clearly stating the superiority of one oil over the other, and others were stating that Mobil 1 was no longer a purely synthetic product. Simply, I wanted to draw attention to the fallacy of these conclusions based on anecdotal data alone or hearsay regarding lawsuits or even the letter from Mobil 1's rep. That was my entire point then]
But I'll also point out that instances of oil related engine failures isn't a good example in this discussion. [Agreed!]
The bottom line for me, pushing aside the academics, is that I drive slowly, methodically, deliberately and like an old man in a hat-- as such, whichever synthetic (Amsoil, Mobil 1, PP, RP, urine samples, etc.) will suffice. I'd be more particular if the car was pushed aggressively, at that point I'd be counting metal shavings in the oil, getting my oil analyzed, driving in the buff to reduce weight, and shaving my head to reduce wind resistance.
Now, on a more interesting topic, "IMAFUKINRIDER," do you have any more pictures of hotties wrestling?
Old Jan 13, 2009 | 07:14 PM
  #275
Jeff92se's Avatar
Red Card Crew
Based on the evidence I've seen and the article you posted, I still say Mobil 1 (in most grades) is no longer a group IV sythetic based oil like they used to be.
In the whole scheme of things, it could have little revelancy. But when you are sitting there in the oil section, ready to plunk down the extra $$ required to purchase a synthetic, you will try to purchase the best oil that you are willing to pay. IMHO, at that time, knowing what your oil choice is made up of, now becomes important. Would you pay Amsoil prices for a WalMart branded generic oil? Even if both would most likely protect your engine pretty much the same way (given your driving habits)?
Old Jan 13, 2009 | 07:57 PM
  #276
Braintree's Avatar
Based on the evidence I've seen and the article you posted, I still say Mobil 1 (in most grades) is no longer a group IV sythetic based oil like they used to be. [ Braintree wrote: According to what I've been reading today, inclusive of the federal complaint filed by Mobil 1 against Castrol, you may be right.]
Again, from my readings, it seems that Mobil 1 has been on that slippery slope of group IV motor oils, the definition of which has been slackened so that it can legally refer to itself as fully synthetic. What we don't really know is what percentage of it is group III and what is group IV-- 20%, 35%, 50%, 75%???? Amsoil does tell you, on every bottle I believe, what it's made of: Mobil 1 does not and calls it proprietary information.
Mobil one, on it's website, states clearly that it needn't challenge or respond to Amsoil's claims since the proof is in the pudding-- racers use Mobil 1, Amsoil is not mentioned, therefore, Mobil 1 must be superior (to use their logic)!!! What do you think?
Old Jan 13, 2009 | 08:07 PM
  #277
Jeff92se's Avatar
Red Card Crew
One might not know what % of Mobil 1 is group IV. As I've said before, look at the ORDER in which the state their ingredients. Most if not all ingredients are listed in the order of most to least. Group IV isn't listed 1st (might not even be listed 2nd). So that means (to me)
1) It's not a Group IV based oil (why would they list it twice?)
2) It's not the main ingredient.
Mobil 1 doesn't tell you simply because it doesn't have to. The engineer that replied to my email gives us a clue. But that's about it.
So again, you have xx dollars to spend on your next oil. You're standing there trying to choose. Which one would you rather have?
Old Jan 13, 2009 | 08:37 PM
  #278
Braintree's Avatar
Here's what I "know" (can one really know one knows??):
A) Group IV (PAOs) = Amsoil (except XL), Royal Purple, DSI, North American Lubricants, Amtecol, Eneos, Castrol (German Castrol that is) among others.
B) Group V (esters)= Motul, Elf, Redline, Maxima/Maxum4, Kem-o-pro, Neo, and silkolene among other.
You can “Google” these to get a better idea of each one's synthetic base.
For the price and my purposes, I'll be changing to Amsoil the next go-around! No thanks to your persistence!
Old Jan 13, 2009 | 08:56 PM
  #279
Braintree's Avatar
Just as a quickie intro to esters for those who may not be familiar. If my memory works, ester oil molecules are made up of the positively polarized Oxygen (O) and the negatively polarized Hydrogen (H). Collectively, both molecules "absorb" into the metal electrically to form a molecular film: in conventional oils (groups II, III, IV) this film is created by viscosity. If someone knows more about this or if I missed the mark, please feel free to correct me.
And there you have it: bio-physics 101.
Old Jan 14, 2009 | 05:39 AM
  #280
wingsprint410's Avatar
Yep.
This is a good place to end this thread.
Old Jan 14, 2009 | 01:01 PM
  #281
Braintree's Avatar
Yep.
Nah.... it may end here, but the same debate will go on elsewhere. Someone else will start the issue and in 1-2 months, we'll have a raging debate. This is one of several threads with the identical topic- not sure why it keeps getting resurrected?
Old Jan 14, 2009 | 01:54 PM
  #282
Jeff92se's Avatar
Red Card Crew
Ah ha!
Gee Braintree, why isn't Mobil 1 on that your list for Group IV? hehe j/k.
IMHO, you don't need the Amsoil. But if your engine is up the task, you could run it on extended drain intervals in order to recoup some of the costs.
Old Jan 14, 2009 | 01:56 PM
  #283
Jeff92se's Avatar
Red Card Crew
Yep.
Why? It's not what the thread was originally about?
Old Jan 14, 2009 | 02:29 PM
  #284
Braintree's Avatar
Ah ha!
It seems Mobil 1 is not considered by those "in the know", to be a "true" group IV (more of a hybrid group III and IV). I run Mobil 1 extended and run it 10K with 1 filter change every 5K. The engine uses about 1 cup of oil per 3K . Keep in mind that my driving style is akin to this guy below.
Also, I'm extremely environmentally conscientious (not in the same fashion as Americans) so do everything I can to protect that which is sacred (Americans struggle with this one and have a one-dimensional view of environmental concern).
My shift to Amsoil will be for the even longer periods between changes-- more environmentally friendly and is less connected to whether or not Mobil 1 is a group IV motor oil. Overall, this has been educational from a lubricants perspective. Thanks for pushing the issue!
Old Jan 14, 2009 | 02:33 PM
  #285
Jeff92se's Avatar
Red Card Crew
Awesome! I'd like to run extended drains also but I tend to use a touch too much for that. After about 4k, I'm about 1 qt down. I'd be topping off and eventually replacing the whole 5 qts before the interval is up. Thus I find the best group III oil I can find for the price and run a fairly short oil change.
