DIY Cam Position Sensor Easy Version
Old Apr 18, 2012 | 09:14 PM
  #106
s_lloyd_s's Avatar
How were you able to pull out the sensor on bank 1 after removing the bolt?? i am pushing in on the little "spring" release but can't manage to pull back the other way on the sensor. theres not enough room to get to hands in there...
Old Apr 18, 2012 | 09:36 PM
  #107
cvipgo's Avatar
Once the connector and screw is out the turn the sensor and you should be able to insert a flat blade screw driver between sensor body and the engine and turn the scre driver, which should release the sensor
Old Apr 18, 2012 | 09:39 PM
  #108
Trickstyle's Avatar
when you remove the bolt, you can pull out the harness and the sensor. use a pliers on the harness to release the sensor.
I posted a pic on page 5, post #64
Old Apr 18, 2012 | 09:45 PM
  #109
s_lloyd_s's Avatar
I know a few people have said to get OEM sensors but is it REALLY that big of a deal to get normal ones at Autozone or other stores? I just want one that will work and stop my car from sputtering and dying!
Old Apr 18, 2012 | 09:48 PM
  #110
Trickstyle's Avatar
I got autozone ones and mine are still perfectly fine, I did mine in last october. I'll probly buy some OEMs to keep on the side for next time but the duralast ones work perfectly fine. but I can tell you that they at least last 6 months lol come october i can tell you if they last a year lol im sure they will tho, im not worried at all...
Old Apr 18, 2012 | 10:14 PM
  #111
saywat?'s Avatar
i bought my sensor from orielys first , which costs the same as oem online btw, and they werent working for me and after exchanging it once and still the same issue. then i said fk it and bought oem ones .i dont recommend aftermarket ones esp since they cost the same as oem
Old Apr 18, 2012 | 10:37 PM
  #112
s_lloyd_s's Avatar
I was just trying to get this done ASAP and didnt want to wait for online order or pay a ton for overnight/express....Now i have the 10mm harness bolt out and need to drive around for the next couple days as is...hope thats ok!!!
Old Apr 19, 2012 | 01:52 AM
  #113
ErikNYC's Avatar
I used pliers as well to loosen mines, as well and purchased an aftermarket brand. I paid $25 for a replacement from a local friend of mines, that's the main reason.
Old Apr 19, 2012 | 02:31 PM
  #114
s_lloyd_s's Avatar
If I'm not able to pull off the green connector can i pry out the sensor and connector together and then situate it so i can remove the green connector after? I've already removed the bolt that holds in the sensor...
Old Apr 19, 2012 | 02:34 PM
  #115
JaE35's Avatar
Moderator
G35 Sedan
if you've read anything in this thread the one thing you should know is to spend the money and get the oem sensors.
Old Apr 19, 2012 | 02:35 PM
  #116
JaE35's Avatar
Moderator
G35 Sedan
Push in on the release carefully with something, it's a PITA but it'll come off
Old Apr 19, 2012 | 02:37 PM
  #117
saywat?'s Avatar
the connector is not like the other ones where u gotta unclip the tab while pulingl them apart. thats the misleading part. the connectors actually easy to undo. all u have to do is press the green tap forward with ur finger (not downwards) like a button. that unlocks it ull hear it click then jus pull apart
Old Apr 19, 2012 | 02:40 PM
  #118
JaE35's Avatar
Moderator
G35 Sedan
Mine wasn't moving at all with my finger...i had the broken nail to prove it lol
Old Apr 19, 2012 | 02:41 PM
  #119
s_lloyd_s's Avatar
Well i don't want to wait extra days on parts to come in the mail. It's a little tough to push on the release when its underneath it and i can't fit my hand down there...I don't know how you guys have done this, my hands don't fit! I need a little person! I had cuts all over my arm yesterday from trying to fit my hand down there and got nowhere on the issue!
Old Apr 19, 2012 | 02:42 PM
  #120
saywat?'s Avatar
i used my thumb. u trying to release the connector while the sensor is in the engine or something? undo the bolt and pull the sensor out. ull have more access to it that way
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
