What happened to the Motordyne Engineering 3/8" plenum spacers?
#91
Originally Posted by OCG35
I plan to paint mine smoked anodized color - and powder coat the plenum... Also, ma_sha1 took the Infiniti Logo of his stock cover and re-applied to CF cover, looks good - I plan to do the same.
& get an Infiniti emblem to replace the hamburger.
Here's a painted Z cover (on a Z)
it leaves the plenum exposed for better cooling
#92
Originally Posted by inTgr8r
That's my plan too, except I'll stick with body color instead of the anodized color.
BTW – not sure if I’m going with the smoked anodized paint now… just got car back from having exterior door trim & handles painted that way (plan was powder coat – long story) but they cleared over it and lost the anodized look… Still in the air about what color for the cover, but I don’t want the carbon fiber look.
Making unique changes to the look of my G has become a huge pain in my @SS!!!!!!!
#94
Bottom line, if you want a cover and care about plenum temp, use ˝ cover (aka Z cover) – if you REALLY care about plenum temp, cut the down lip (in front) for more air flow across plenum. Another idea (I considered but probably won’t do) is stock or CF G full cover and cut the center out (around plenum). I was thinking of doing it but wasn't sure how it would look… low and behold a few days later I saw David’s (jdmv35) – it looks pretty good (see pic). He did it for after market plenum clearance (good idea for 1/2" spacer too) but it would work for my intention of plenum cooling too. The plenum gets damn hot with that full cover on!
DaveO is running a stock Z cover with cut front down lip - I'm not sure if he has done temp comparos, but I know he's happy with the results. Theoretically it makes sense to do.
#96
Originally Posted by lowrider
Dremel a "G" Cover, and it looks just fine IMO.
Lou
Lou
I really like what you did with yours though!
#98
Tony;
Just looked at the new manual....
Can you clarify what appears to be conflicting information?
- to me, it does not appear to be necessary to remove the TB
unless I'm missing something.
pg 3 bottom;
pg 4 top
pg 3 bottom;
Notice, the TB is neither removed from the plenum, nor unplugged from the harness.
Do not unplug from harness
Aramid Gasket Install....
For iso-thermal gasket install; Unbolt the TB from the upper plenum, without unplugging it from the harness..........
#99
Tony;
Feedback is always very helpfull and appreciated!
YOU DO NOT NEED TO UNBOLT THE THROTTLEBODY FROM THE PLENUM.
You could unbolt it if you want to but it would only be more work and it isn't really necessary. You can do everything you need by simply tilting the plenum on its side as shown in the picture.
The GB for the Motordyne Iso Thermal upgrade will be $50.
The spacer kits will be $50 off.
Thanks again!
Tony
EDIT:
I also have the arctic weather edition that will be comming out very soon too. I may hold off on doing the GB for a little longer so the polarized copper thermal bypass can be included. It will allow you utilize the fullextent of Iso Thermal upgrade no matter how cold it is outside. The throttle body will always be heated and the plenum assembly will remain cold.
So if you are driving in sub zero weather, engine performance will literally be the equivalent to driving on 1 psi of boost (due to increased atmospheric density). The plenum will be cold like you put ice on it but the throttle body will remain heated.
#101
on
Originally Posted by maxpower
Tony,
At some point before the GB on the thermal kit upgrade will you have some performance data available? For those of use that already have the 3/8" spacer installed, will there be a measurable performance increase?
Thanks,
max
Thanks,
max
I'm with him, since I have the 3/8" spacer too.
#102
Originally Posted by Hydrazine
I also have the arctic weather edition that will be comming out very soon too. I may hold off on doing the GB for a little longer so the polarized copper thermal bypass can be included. It will allow you utilize the full extent of Iso Thermal upgrade no matter how cold it is outside. The throttle body will always be heated and the plenum assembly will remain cold.
#103
I'll get it dynod but it may not be for some time. I have a ton of other dynos and time consuming things in que. But when I do, it will be done in a manner that best simulates (or approximates) real world conditions.
Running a dyno with the hood open and a fan blowing on it for several minutes before the pull provides real results, but not real world test conditions. Ideally, it would be best to find out what the car does when it is heat soaked with with typical plenum and engine compartment temperatures.
I may be able to do a good approximation by creating similar pre/post "plenum temperature" test conditions.
The car could be taken right off a long freeway cruise, quickly slamed on the dyno with the hood opened just seconds before doing the dyno pulls. That would provide near realworld heat soaked test conditions. After doing three baseline pulls, install a MIT kit and repull 3 more runs. (I can already tell you there will be some amount of gain)
Of course all other temperatures and variables would have to remain constant. Ambient air intake temperature, engine coolant temperature, oil temperature, transmission temperature, ECU and every other variable within reason.
Although I've done many, many research dynos there is always room for more. The only problem is my back is killing me from hours and hours of bolt turning over the engine while on the dyno. And I have so many more dynos to do for so many other cool projects. I love it!
I'm gonna have to get a dyno of my own just to keep up with the research requirements.
#105
Man, you really have my attention now!
The engine regulates itself to about ~195 deg F coolant temperature. (And a normal plenum runs at temperatures only slightly below that.) With Sub Zero air flowing through an un insulated plenum, the heat flux will be very high and the cold air will absorb/gain a lot of heat.
So cold weather areas have more to gain from a MIT upgrade with polarized copper throttle body heater because you won't have hot engine coolant heating up the entire plenum.
So in a way, cold weather areas are naturally boosted.
Here in California, Sub Zero temperatures are extremely rare so a coolant control valve is all that is needed.
