Easy Ecu Resetting
Old Apr 30, 2013 | 11:26 AM
  #511
G2B35AGN's Avatar
Originally Posted by RicoG35x
Nice!!
That's the thing with a proper ECU reset.. the car is more responsive.. fun to drive... therefore any possible gains in MPG's because of the reset... are diminished BECAUSE of the reset... because it's FUN to drive!!
Enjoy man!!
btw.. you should at least be seeing about 19mpg average, more on highway...
The 2006 AWD had the worst EPA mileage ratings of any of the Gs. Extra weight plus energy needed to turn multiple wheels I guess. So I wasn't surprised. It was around 15-16 in town. Out on the road for 2 hours of highway riding first time this weekend and got a bit over 20. So we'll see.
Old Jun 12, 2013 | 02:04 PM
  #512
Urbanengineer's Avatar
Just purchased a Motordyne Isothermal and Plenum set (non copper). Will post fuel mileage change in a month after 2 weeks testing 80/20 highway/city mpg's between stock and post-upgrade. Of course resetting ECU tonight
Old Jun 13, 2013 | 08:55 AM
  #513
g35slug's Avatar
Interesting, might have to try this. 05 sedan 97k
Old Jun 13, 2013 | 11:53 AM
  #514
Reset ECU last night and drove it like a dentist, a lot of the power seems to be gone... If only there was a switch for spirited driving and high fuel economy driving. Even the Man-U-Matic mode seems effected
Is there also a negative behind resetting the ECU?
Old Jun 15, 2013 | 04:46 PM
  #515
grigortheboss's Avatar
Should I do am ecu reset after a cold air intake installation
Old Jul 24, 2013 | 12:17 AM
  #516
deleo14's Avatar
Ecu reset-crossing fingers
I have a 05 sedan w/ sport package. Purchased it brand new and currently have 181000 miles and I've recently noticed it is getting worse gas mileage and shifting slower. So I started reading threads and I came across this ecu reset. I don't think my ecu has ever been messed with from infiniti. If it has-no one ever told me. I have chosen to do the battery disconnect option for 12 hrs. I'm excited to see if this works. I have always monitored my gas mileage and use to get 200 miles around half tank and averaged 21 mpg and gas light would turn on around 370 miles. I'm now getting around 18 mpg and recently my gas light comes on around 300-310. Most of my driving is done on highway to and from work and live in Phoenix.
Old Dec 17, 2013 | 09:01 AM
  #517
labidus's Avatar
Did you see any change?
Old Dec 31, 2013 | 05:46 PM
  #518
Wow I was a noob. Resetting the ECU by the pedal method or unplugging the ECU resets fuel knowledge of the ECU.
Resetting the ECU and driving like a grandma will desensitize the throttle.
It does not change things majorly for your MPG. Check your intake track and complete a tune up if your MPG's are falling. A simple tune up procedure can be found on google, it costs about a hundred bucks and 2 hours of your time.
Old Jan 17, 2014 | 11:59 AM
  #519
infinitigman35's Avatar
can this fix low idle issues ?
Old May 10, 2014 | 02:21 PM
  #520
Ross240Z's Avatar
I tried the complicated throttle / stopwatch procedure on my '04 G35 a few times with no results, then ran across a really easy quick reset that turned the light off right away. Just disconnect the battery and pump the brakes a few times - Bingo!.
Old May 10, 2014 | 02:26 PM
  #521
GeezerB's Avatar
Do you lose your radio & seat presets?
Old May 10, 2014 | 02:33 PM
  #522
Ross240Z's Avatar
I don't have the memory seats, but I'm guessing a person would. The radio (Bose) is a whole other story - went to disconnect the auxiliary input the last owner had installed, put it all back together, and now everything works but I have no volume at all. That's tomorrow's project!
Old May 10, 2014 | 03:42 PM
  #523
herrschaft's Avatar
For the radio yes.
Old Jan 8, 2015 | 02:38 AM
  #524
AZG35sSedan2008's Avatar
This YouTube video helped immensely
http://youtu.be/95WszTnphPI
I just did the reset in sync with this video and it worked perfectly. Now my G35 doesn't drop idle when at a stop light and the service engine soon light was cleared. The service engine soon light turned on after a really cold night that threw a thermostat/coolant/temp sensor error. I will monitor this closely.
Old Feb 17, 2021 | 01:23 AM
  #525
G 35johnie's Avatar
Love my g35
Lmao hahahahahahah ikr
raydeon
Apr 26, 2020 03:48 PM
Matchstickman60
V36 Engine, Exhaust, Drivetrain & FI
12
Jan 25, 2009 11:29 AM
savefatkids
Sep 15, 2005 03:51 PM
MBentley
Sep 1, 2005 08:17 PM
zimbo
Sep 9, 2003 08:41 PM
