Makeshift Oil Catch Can
Old Nov 21, 2010 | 05:13 PM
  #256
jon121587@yahoo's Avatar
Ok then Yea they are two diffrent Filters. And yes i have read that some or most people dont use the filter. I was too not using the filter untill i found excessive amount of oil bieng passed through the other side into the manifold. Now that i have of 1 HD catch can(without filter) hooked up for the oil to hit and break off to liquid and the second HD catch can(With Filter) to filter excessive oil and it seems to be working perfect. Also I dont have to dump the filters out because Of there bieng two points for the oil to break up and be caught in. I checked the line going into the mani and nothing so now i kno this is an effective way of catch ing the oil and none getiing passed through
Old Nov 30, 2010 | 03:35 PM
  #257
monteitis's Avatar
Could this issue have anything to do with the fact that my car consumes quite a bit of oil? And then the fact that I get a lean code after every time I change my oil???
Old Dec 1, 2010 | 05:58 PM
  #258
The pvc throws quite a bit of oil maybe half a quart or some have said 1 hole quart they have seen lost wen using catch can setups within a 3000 interval oil change. Id really doubt that the vq35de burns oil but i could be wrong. Just my two cents
Old Jan 19, 2012 | 11:43 AM
  #259
Igaly1021's Avatar
this should get a sticky
Old Jan 19, 2012 | 08:57 PM
  #260
OCG35's Avatar
it is a sticky - has been for many years
Old Mar 20, 2012 | 02:41 AM
  #261
nadjkovic's Avatar
Was going to post a new thread with my catch can setup I just installed, but I then figured it'd be best to post it here..
So I referred to my own parts/install on my last car (an '03 Nissan Altima 2.5S) here:
http://www.nissanclub.com/forums/eng...cuum-leak.html
Same exact concept.. So my part listing is as follows:
- modified Home Depot Husky air compressor 3/8" inline filter (removed unnecessary pieces, bored out the restrictive uptake piece, and filled the bottom plug with RTV after boring it out)
- 3/8" male barbed x 3/8" male threaded 90° fittings (x2) bought off amazon @
Amazon Amazon
- "plumber's tape" (used on the threaded fittings for a good seal)
- approximately 2-3 feet of fuel injection hose
- small >3/8" hose clamps (x4)
- large hose clamp to clamp it to the closest resevoir
- new PCV valve
I'll post back this weekend on how much oil fills up!
Old Mar 28, 2012 | 10:23 AM
  #262
FullOutPwr's Avatar
Just a thought, but back when I had my Evo most of us were throwing steel wool in our catch cans. The steel wool was catching most of the oil vapor.
I'm doing my catch can today, and adding steel wool.
Old Apr 30, 2012 | 01:41 PM
  #263
Mr. Samster's Avatar
out of curiosity, will it be more harmful to add one on now if i have over 150,000 miles and have never ever taken off my plenum? I did replace my TB and there was oil at the end of plenum.
Old May 2, 2012 | 02:07 PM
  #264
bump
Old May 2, 2012 | 11:31 PM
  #265
UR2EZ's Avatar
No way a catch can would be harmful in any way, it simply removes oil vapor waste that is otherwise meant to be burnt up in your engine... adding a catch can is a great idea at any mileage
Old May 3, 2012 | 12:36 AM
  #266
gary c's Avatar
Not Pretty but works as intended!
This....^....was my third mod, the Home Depot catch can functions perfectly by catching oil we don't want running thru our plenums.
Gary
Old May 4, 2012 | 12:57 PM
  #267
when making your own. Has anyone ever thought of putting an open/close valve at the bottom to make it easier on draining the oil?
Old May 25, 2012 | 01:11 PM
  #268
silvG35's Avatar
Originally Posted by Andy2434
This last January, our fellow forum member, GEE PASTA, posted a thread on a makeshift Oil Catch Can. He noticed that when working on the lower collector, there was a small amount of oil in the said. I had noticed the same when installing the MREV+ back in October. Subsequently, other members had posted about the same experience.
https://g35driver.com/forums/showthr...=oil+catch+can
At that point, I gave serious consideration to installing a Stillen Oil Catch Can. However, due to its size, I did not know where to install it.
Just recently, our friend, DaveO found a great thread in a FX forum,which dealt with this issue. DaveO posted his results and pics of his makeshift oil catch can for his Z.
https://g35driver.com/forums/engine-drivetrain-forced-induction/97246-catchin-oil.html
I took DaveO's lead and have done the same. Many have stated that this is not neccessary. That may or may not be true and I will not argue that point. Nonetheless, for those of you whom may have concerns with regard to this issue . . . Here is my makeshift Oil Catch Can DIY.
The parts needed and shown above are:
1. 2 - 1/4" dia. threaded (male) to 3/8" barbed fittings
**Edit: 2 - 3/8" elbows and 2- 3/8" x 1" nutted nipples
These additional parts are reflected in the pics in post #46.
A 16 gauge anodized Aluminum bracket was added, as well.
2. 2- 5/8" hose clamps
3. 2 feet of 3/8" dia. Fuel line hose **(edited: After some 3 days of using the fuel line hose . . . I swapped out the said for fuel injection hose. This new hose prevents the hoses from collapsing during idling rpm and may prevent the "Sucking" sound, which some have experienced.)**
4. 1- Mini All Purpose Filter with 1/4" dia. threaded female connectors
The 3/8" dia. fuel line hose was purchased at Kragen for $2.40. Everything else was purchase at Home Depot for some $17.00. So, this quick and easy mod cost me less than $20.00.
Note: The filter comes with comments reading . . . "Avoid synthetic oils, chemicals, solvents, paints and fumes which may cause bowl failure."
The above 3/8" dia. hose needs to be removed. This existing hose connects to and from the PCV valve and to the fitting at the lower collector, which is shown.
This is what it looks like after the existing hose has been removed. Note the oil residue at the base of the yellowish PCV valve.
Apply some white teflon tape to the threaded portions of the 2 - 1/4" dia./3/8" dia. fittings and thread them into the filter. Note the "ARROW" stamped on the filter housing. The arrow is the side of the filter which will be connected to the lower collector.
When all is said and done . . . The following pics are the final product. This little project took all of 30 minutes including the snapping of the pics.
I reused the existing hose clamps at the PCV valve and lower plenum connections and used the new hose clamps at the new filter assembly.The glass bowl is easily removed. When removing the bowl, note that there is a thin rubber "O" ring, which can fall out. The entire assembly can be removed at the PCV valve and the lower collector connections in a matter of seconds, if one should wish or need to replace the existing OEM hose assembly.
Thanks to GEE PASTA for pointing out a potential issue . . . And thanks to DaveO for digging up the info to afford me a very simple and cost effective mod.
Hey guys where can i find the filter at?
Old May 26, 2012 | 12:28 PM
  #269
silvG35's Avatar
[QUOTE=nadjkovic;6377785]Was going to post a new thread with my catch can setup I just installed, but I then figured it'd be best to post it here..
Amazon Amazon
- new PCV valve
is it necessary to bored out the UPTAKE PIECE
Old Jan 9, 2013 | 10:35 PM
  #270
mrgrey's Avatar
Has anyone done this mod recently, good place to get all the supplies. Any stuff online?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
