G35 & G37, Coupes & Sedans
Everyone: Check Your Oil!
Rating: Thread Rating: 5 votes, 4.80 average.
Old Oct 8, 2011 | 09:10 PM
  #1651
djamps's Avatar
Originally Posted by g35_white
So, i managed to check it today noon. The car isn't moved from its place for past 15 hours.
Some observation. The oil traces were upto half crosshatch. Where it says H. The bottom part is a little darker color. Should i add more? I am planning to get it changed next weekend. Should it be good till then?
Please view the pictures below. Not the best quality of photos, please pardon for the same. Would appreciate your feedback.
Thanks
Dude your oil is EMPTY. You probably need at least 2-3 quarts added.
Old Oct 8, 2011 | 11:46 PM
  #1652
Texasscout's Avatar
I would think you would be good, how many miles since you bought it? You should add a quart if it gets to the bottom of the crosshatched area.
Old Oct 9, 2011 | 01:29 AM
  #1653
g35_white's Avatar
But some portion of oil traces is found till half cross hatched area. the thick part is at bottom. can i add it from top? Or do i have to do some other procedure for adding oil?
Its like 1100 miles since i bought it. i guess i will get it changed on monday instead of doing it next saturday.
Old Oct 9, 2011 | 01:46 AM
  #1654
G2FLIP4's Avatar
everything
When i got it checked a month back, the mechanic did the same. he didn't wipe it out. I just followed what he did.
That's a pi55 poor mechanic
Jesus dude, READ YOUR OWNERS MANUAL for starters!!!
Old Oct 9, 2011 | 03:22 PM
  #1655
g35_white's Avatar
i checked again today morning and oil was a little less than half of cross hatched area. So i got a 1qt of castrol 5w30 and added just to be on safer side. I will be going to get oil changed early next week.
thanks for all those who helped me.
Old Oct 13, 2011 | 09:03 AM
  #1656
caly2121's Avatar
It appears that this issue has just gotten to my car. Driving home last night I saw the oil pressure light blink when I slammed on the brakes. Car had made some weird noises starting up the past few days but I thought it was belt related since they need to be changed.
Checked my oil this morning and it doesn't even register on the dip stick, WTF.
I'm at 90,000 miles, is it really possible this is just appearing now? Or is it just not noticed previously because I was changing my oil frequent enough to never have burned it all off?
Sitting at home, waiting for a tow truck at this moment.
Do the '07+ G35's have this issue?
Old Oct 13, 2011 | 09:19 AM
  #1657
djamps's Avatar
How long did you go between changes in the past and who changed it? How long did you go this time?
You could have been low before each oil change and unless you measured what came out you wouldn't know. That's why it's important to always monitor your oil level from time to time with any car. The light won't come on until you're bone dry and damage has already occured.
Vehicle ownership 101 guys...
Old Oct 13, 2011 | 09:23 AM
  #1658
caly2121's Avatar
I'll have to ask the garage... I typically went 3-4k per change. I'm probably around 5k this time around, and no I haven't monitored (I did initially but never saw any major change, got lazy/dumb after awhile and stopped). I actually never saw this thread till searching around last night about the oil light (not as active on here as I used to be).
Old Oct 13, 2011 | 11:07 AM
  #1659
Golden's Avatar
That belt grinding sound when you start up is a huge indicator that your oil and therefore oil pressure were low. Same thing happened to me and many other people on here. Some belt (can't remember which) loses tension with low oil pressure and rattles on startup, so at the very least, whenever you hear that noise check your oil ASAP or get a new engine.
Old Oct 13, 2011 | 11:19 AM
  #1660
djamps's Avatar
It's timing chain rattle (not belt). Oil pressurizes the tensioners.
Old Oct 13, 2011 | 01:48 PM
  #1661
Texasscout's Avatar
Once oil drops two quarts down, you have three quarts trying to do the work of five. It doesn't take long for the oil to break down due to heat and stress. Once that happens, oil consumption goes through the roof. If you check it and add at the "low" mark, you can slow this process but not stop it.
Old Oct 14, 2011 | 02:35 PM
  #1662
caly2121's Avatar
Ok, so most of 06 and earlier drivers are driving and putting up with this situation? Just keeping tabs on the oil I'm assuming?
Mechanic recommended putting Lucas Oil Engine Stop Leak in, any thoughts on this?
Old Oct 14, 2011 | 03:46 PM
  #1663
Texasscout's Avatar
, No, most don't have a problem.
In my experience, nothing that you pour into an engine will "fix" a problem. Disguise it maybe.
Old Oct 14, 2011 | 05:41 PM
  #1664
jibberjabbers's Avatar
This is a known issues since 2002. Oil Consumption problems with most VQ35DE Altimas, Maximas, and Pathfinders and any other car with this same motor.
Of course, it became more apparent on the Rev-up motor when the genius over at Nissan decided to increase the rev limit and keep the internals the same.
Crappy rings are to blame. The pistons and engine bearing aren't all that good either. Glad they decided to go with a German motor for the next round.
Old Jan 23, 2012 | 11:54 AM
  #1665
dec55's Avatar
Don't be so sure that oil issues will be solved by getting German engines...they have oil issues too....
http://www.benzforum.com/forum/showthread.php?t=14691
TSB: High Oil Consumption (M112)
http://www.benzworld.org/forums/w210...tion-m112.html
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
