G35 & G37, Coupes & Sedans
Old Aug 7, 2018 | 08:20 PM
  #8731
Edgarc6789's Avatar
I've done the rear before it was really easy but I bought the rear shock mounts I dont how they go I've never even seen them before .
For the front im keeping the same springs I wish I can lower my car a bit but the roads where I live are HORRIBLE
Old Aug 7, 2018 | 10:58 PM
  #8732
Scorpi0's Avatar
Horrible roads in LA?? Where do u live?
Old Aug 8, 2018 | 05:31 AM
  #8733
Blue Dream's Avatar
I drove ttrank's car solo
I'm guessing Louisiana, not California.
Old Aug 8, 2018 | 05:38 AM
  #8734
Scorpi0's Avatar
Hmm you migh be right
Old Aug 8, 2018 | 11:41 AM
  #8735
Edgarc6789's Avatar
I've never been there lol
I live in Compton
Old Aug 8, 2018 | 12:00 PM
  #8736
LoSt180's Avatar
Had a code P0340, ordered new revised parts from Nissan. Only got intake, will probably get the exhaust ones anyway as preventative.
As you can see, they've got some kind of metal io them now.
Unfortunately, my starter also decided to die, so that will be this evening's festivities.
Old Aug 8, 2018 | 03:49 PM
  #8737
Edgarc6789's Avatar
What kind of oil do you guys use for your diff?
what weight
Old Aug 8, 2018 | 04:34 PM
  #8738
LoSt180's Avatar
what weight
manual calls for 80W-90 GL-5
think I used Amsoil fluids when I did my diff and trans fluids over the winter. Really any local auto store gear oil will be fine, it's the trans that requires special stuff.
Old Aug 8, 2018 | 07:29 PM
  #8739
Blue Dream's Avatar
P0335 is the code for the crank position sensor, P0340 is the code for the bank 1 (left side) camshaft position sensor. They're both straight and don't have metal around the shaft. The crankshaft position sensor is part number 23731-AL60C and I believe goes into the transmission housing.
Also the part number on your bag is slightly different than the correct cam sensor: 23731-6J90B.
I've used Amsoil Severe Gear 75-90 for years and the G with 150K miles has never had a diff problem so I'd say it works pretty well.
Old Aug 8, 2018 | 10:15 PM
  #8740
LoSt180's Avatar
The part numbers on the bag are the new revised part numbers for the cam sensors.
In other words: bank 1 (passenger side) 23731-6J90B has been superseded by part number 23731-6J90D
Bank 2 cam sensor is now 23731-AL61D
​​​​​​ They now have metal on them as you can see in my comparison.
Old Aug 9, 2018 | 07:03 AM
  #8741
Scorpi0's Avatar
I live in Compton
Nice...I work at LAX. Not too far from there.
Old Aug 9, 2018 | 09:59 AM
  #8742
Urbanengineer's Avatar
Replace your starter with a rock auto $80 replacement. It's made my G sound fast again with it's startup sound... I really like it.
As for revised cam sensors - interesting!
Old Aug 9, 2018 | 10:00 AM
  #8743
I used redline 75W-90 and have been very impressed with the quality!
Old Aug 9, 2018 | 10:44 AM
  #8744
eazdaskeez's Avatar
Test fitted these bi led projectors into my test lights. They fit nice with no trimming for the projector, the shroud might need a little trimming but that's nothing major. The real question is do I redo my lights or just sell these for profit
Old Aug 9, 2018 | 12:10 PM
  #8745
Edgarc6789's Avatar
see pot holes everywhere
