G35 & G37, Coupes & Sedans
Old May 3, 2019 | 06:06 PM
  #9631
Scorpi0's Avatar
CSW, are those muffler tips bigger than the OEM? If so, can u give us a shot of it from the rear?
Old May 4, 2019 | 08:36 AM
  #9632
Urbanengineer's Avatar
They are the HKS rep eBay thin wall 4.5" tips on his car. They can't be missed.
Originally Posted by cswlightning
G35 coupe, this used to be an HKS rep exhaust before every component was replaced at a muffler shop. The 11386 is after the flex pipes replacing the Chinese "resonators". It made the exhaust 100% better and livable for a highway daily, but I wanted more quiet, so I upgraded the China mufflers to larger volume straight through China mufflers branded "totalflow" for $30 a side plus $100 labor including welding in new flex pipes. Sounds nice and quiet unless WOT, but deeper and throatier than stock at all RPMs. No highway drone to speak of, at least compared to the original HKS rep.
I haven't done the back mufflers yet, but I'm pretty impressed with the Magnaflow X-pipe so far.
With the un resonated muffler section in the back, there is still drone at high load and low RPM in top gears, but otherwise there is none! Totally worth the $165 installed.
Drone much more minimal then when it was just the H pipe from eBay and when I tried to put fiberglass packs in there as replacements. X pipe FTMFW.
So all in on this HKS I'm $550 . If only I could've found a non rusty replacement for my OE one when I sold the Motordyne. My damn C pipe was corroded and my rear flange was toast on the Muffler and midpipe sections :cry:.
This set up drones less than the Motordyne setup did (auto trans). I'm still butthurt Tony didn't mention that on his listing.
Originally Posted by jparker7269
So is your G a coupe or sedan and a 35 or 37? Did you remove the 8" extension and cut the other length out and clamp it in or have a shop do it and weld it in? I have the HKS knockoff my self and really like it but does get a little droney at certain loads.
It goes behind the flex pipe. See CSW's posts... or my pics below.
IM FINALLY HAPPY WITH THIS WOOOOOOOO.
Attached Thumbnails What did you do to the G today?-photo363.jpg   What did you do to the G today?-photo97.jpg   What did you do to the G today?-photo402.jpg
Old May 4, 2019 | 10:29 AM
  #9633
Albanian122's Avatar
New splitter is here after 5 weeks
Old May 4, 2019 | 11:35 AM
  #9634
Pbfoot's Avatar
04 G35 Sedan performance package. 70k Eibach springs and sway bars. 19 inch wheels. Plenum spacer.
It worked but it was still a LOT of work. Hopefully I never have to do it again.
Happened to my wife's white Camry twice. It did take a lot of elbow grease.
Old May 4, 2019 | 01:12 PM
  #9635
Dear god haha.
Old May 4, 2019 | 01:46 PM
  #9636
Dear god haha.
**** looks like an airplane wing
Old May 4, 2019 | 11:01 PM
  #9637
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It'll look good installed.
Old May 5, 2019 | 11:50 AM
  #9638
Pbfoot's Avatar
Did the 5 minute epoxy differential fix.
Old May 5, 2019 | 01:16 PM
  #9639
It's still debatable if that works long term, but the idea is good and way easier then cutting it out.
Old May 5, 2019 | 08:16 PM
  #9640
eazdaskeez's Avatar
Snapped a pic
Old May 5, 2019 | 08:46 PM
  #9641
Pbfoot's Avatar
I will be the test dummy while I make a sleeve to remove the old bushing.
Old May 6, 2019 | 11:28 AM
  #9642
cleric670's Avatar
BANNED!!!
The old bushing is SUPER easy to remove (after you have the differential out which is pretty easy to remove). Remove muffler, unbolt CV axles, unbolt propeller shaft, remove differential.
Then use a large diameter holesaw to hog out the rubber in the middle, try to match the holesaw to remove as much rubber as possible. The outer shell/race of the bushing is aluminum so it's easy to cut, just take a sawzall and score it in a couple places about 1/2" apart, then use a hammer and flat blade screwdriver to knock that 1/4" wide piece out. From that point it just rolls up on itself easily with the hammer/screwdriver.
I've done it one time with the Z1 Motorsports bushing press and twice using the holesaw/sawzall method, cutting it out is 10x easier AND faster.
Old May 6, 2019 | 12:40 PM
  #9643
Pbfoot's Avatar
Did you use the Z1 urethane bushing for the replacement?
Old May 6, 2019 | 10:19 PM
  #9644
cleric670's Avatar
BANNED!!!
Yeah and I'm really happy with it, it's got a thinner urethane bushing and more metal in the cap in the center. Great overall feel.
Strongly recommend it.
Old May 6, 2019 | 11:35 PM
  #9645
Energy poly bushing (revised) and I'm really happy with it. The Urethane Z1 offers is a little
More stiff. There are different hardness levels of poly.
