G35 & G37, Coupes & Sedans
Old Oct 6, 2021 | 06:17 PM
  #10486
Row2k's Avatar
20 Year Member
G35 Coupe
Originally Posted by whutch1
installed 3.5" aluminum single driveshaft.
Just a bit larger diameter than oe so there was a small rubbing issue with heatshield and e-brake spring. once i took it apart (again) and did a little "modifying" ...
Love the response! should have done this years ago.
This addition is in response to the un-serviceable U-joints on the OE shaft breaking down on me.
Have also,, very recently, installed the upgraded g37 cv axles and hub assemblies for the rear. VERY pleased with these components.
that's a great mod, I still remember the improvement from installing my CF driveshaft. The drop in drivetrain rotational mass at least to me was most noticeable in higher gears where the car suddenly struggled less in 5th or 6th gear on the highway as there was a noticeable improvement in torque at lower rpm.
Old Oct 7, 2021 | 08:40 PM
  #10487
06G35Coupe94's Avatar
new lights just got finished
Old Oct 8, 2021 | 01:13 PM
  #10488
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Ohhh my god... lol!
Old Oct 9, 2021 | 12:40 PM
  #10489
Had a little fun lol
Old Oct 10, 2021 | 12:16 AM
  #10490
Yinster's Avatar
5 Year Member
I was in Z national at z1
Old Oct 10, 2021 | 05:11 PM
  #10491
whutch1's Avatar
just installed the dress-up cover for the Brake Booster. Just that detail alone makes under the hood so much cleaner.
Old Oct 12, 2021 | 04:37 PM
  #10492
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Nice. I saw quite a few pics from this weekend on IG. Did you get to check out the new Z?
Old Oct 12, 2021 | 08:48 PM
  #10493
Yinster's Avatar
5 Year Member
yes I did man, I really want that mechanical LSD on my G even though I will lost my 3.7 gear ratio vlsd lol
Old Oct 12, 2021 | 09:28 PM
  #10494
cleric670's Avatar
BANNED!!!
Man I haven't even seen one irl yet.
Old Oct 12, 2021 | 09:41 PM
  #10495
Yinster's Avatar
5 Year Member
Its still call the prototype but that's the car we probably get for USDM market.
Old Oct 12, 2021 | 10:20 PM
  #10496
JZ39's Avatar
Meh…
Old Oct 12, 2021 | 10:50 PM
  #10497
Row2k's Avatar
20 Year Member
G35 Coupe
kind of agree on the "meh" in terms of asthetics, but more than anything I'm looking forward to the nismo versions and tunability of the turbo motor. Plus it comes with a manual so It really should be a pretty good package.
Old Oct 14, 2021 | 11:20 PM
  #10498
cleric670's Avatar
BANNED!!!
I think the Q60 red sport guys are creaming themselves because now they have the option of a 6MT to swap into their cars.
I saw a shot of that new Z loaded onto a car hauler and it's not until you see the car from a lower angle that the aggressive body lines take shape.
Edit: here's the photo I was talking about. It's also got a spoiler on it which I haven't seen in ANY other pictures yet.
Old Oct 15, 2021 | 02:16 PM
  #10499
Chutiya's Avatar
Stock G...Just lowered
Still working on it slowly
Old Oct 15, 2021 | 07:53 PM
  #10500
cleric670's Avatar
BANNED!!!
Oil, tranny, diff fluid change on mine today, oil pan spacer on another one.
For the future, anyone doing a pan spacer, COUNT THE BOLTS to make sure you have them all to prevent an emergency run to Home Depot before your RTV sealant sets up... it takes a 6 x 30mm long bolt for the pan bolts.
Also, not sure this has been mentioned anywhere so I figured I'd toss it out, the lower pan baffle either needs to be TRIMMED so it doesn't interfere with the different placement of the pickup tube neck, or you can just delete the baffle. The baffle is only on the rev-up engines I think, personally I just delete it. Here is that lower pan baffle I'm talking about, the red part is the section that needs to be cut out to clear the fill neck if you so choose.
