Calling all "X's" with a lowered suspension!
Old Mar 13, 2013 | 02:16 PM
  #2536
halloffamerjc's Avatar
Originally Posted by chris32086
Yes I'm on stock struts. I'm going to change them when I find sport struts. But this works great on my x. Z stech with 20 and nitro tires
if you don't mind me asking whats your tires size?
Old Mar 26, 2013 | 09:58 AM
  #2537
jeggo's Avatar
Hi guys! I just got my X the other day. I owned 2 rwd sedans before but first time X owner so be nice please
Couple questions I have here for you guys (I'm still reading the whole thread but I just want to kick start my questions while learning. I have a set that I used with my rwd before I was wondering if it will still work with the X.
Specs:
18x8
225/40 ZR18 92W XL
18x9
235/40 ZR18 95W XL
Both +43 offset. I will need spacers for sure.
I started reading page 160 going up and I read at one page that for an X the tires needs to be the same? So my set up won't work then?
Also, I bought a set of megan lowering springs for my 350 that I was thinking of just installing to this car. It's rated to be lower the Z 1.25. So that means it will last the X 2.25 right? That's enough if a drop right?
Last but bit the least, I just noticed the other day. With stock height, is the rear really a tad lower than the front or is it just my imagination? And no, I didn't have anything sitting at the back when I checked.
Hope to hear some answers from you guys. Thanks!
Old Mar 26, 2013 | 10:14 AM
  #2538
jeggo's Avatar
Just installed 350z sTechs on my G35x looks good and ride is smooth. Im sitting on 20x8.5 with just a hiar gap between tire and fender. Im happy
Do you mind posting pics as well?
Old Mar 26, 2013 | 03:25 PM
  #2539
Mike04x's Avatar
^ As long as the overall tired diameter is the same the staggered set up will be fine, the drop from the z springs will be more like 2.75'' given the drop on the x is about 1.5ins more than a rwd
Old Mar 26, 2013 | 08:02 PM
  #2540
jeggo's Avatar
Thanks for the reply. So it should be okay then, right? As they're both 18" for the rims and both 40 for the side wall. Right?
For the X it's more compared to a RWD? Really? Is 2.75" gonna be way too low? Because I have a set of oem Z springs as well. Just wanting to know and see if anyone used megan springs before for their X. As the Oem Z springs doesn't look like its low enough.
Old Mar 28, 2013 | 12:24 AM
  #2541
FlyingLumpia's Avatar
Use this to help with the tire size. http://www.rimsntires.com/specs.jsp
Old Mar 28, 2013 | 10:34 AM
  #2542
jeggo's Avatar
Awesome! Thanks a lot!
So it's saying my rears are 1.3% taller. That's acceptable for the X right? I've read somewhere that it shouldn't be 3% higher?
Old Mar 28, 2013 | 11:18 AM
  #2543
TurTLe*'s Avatar
i forget the numbers but i'm about 98% it will not work.
i think more along the lines of .3 inch or mm. I think i posted my findings in this thread say 2-4 years ago when i was in the same shoes.
There are only so many reasonable tire combos for 18's, i have one combo which is 235/45/18 and 265/40/18. That is actually a little outside of reasonable because my wheel width is 8.5, you need a 9 inch width for a 265 wide tire. But it is what it is.
Old Mar 28, 2013 | 11:28 AM
  #2544
jeggo's Avatar
^ seriously? It's that sensitive? I guess I'll just change the fronts to 235 as well I guess
Edit: I swear I saw at one point in this thread that 3% is acceptable.
Old Mar 28, 2013 | 06:03 PM
  #2545
jookyshank's Avatar
I haz hugz to givez
ARGH!!! I've maxed out the BC coils in the back and i'm 1/8th from where I want it to be (matching the front) so now I have a rake which I'm no so happy with This project just keeps dragging itself out hehe wish I had access to more skilled / not wallet breaking peeps to help me fine tune this setup!
/rant
Pics to come...advice will be welcomed
Old Mar 29, 2013 | 12:10 AM
  #2546
Jook, is the shock and the spring maxed out? If the shock is but spring is not take away some preload, or remove one of the collars.
Old Mar 29, 2013 | 12:19 AM
  #2547
jookyshank's Avatar
I haz hugz to givez
Spring is maxed ...you can...adjust the shock?! you mean the stiffness setting? man I was under there this morn and I must be missing something...
Old Mar 29, 2013 | 01:22 AM
  #2548
frontieragent's Avatar
aurora g35x
im on bc's too and im lower than you shank. im about to go even lower next week.
Old Mar 29, 2013 | 01:27 AM
  #2549
Yeah Shank, you can turn the lower and raise the shock into the mount.
Old Mar 29, 2013 | 01:32 AM
  #2550
jookyshank's Avatar
I haz hugz to givez
Truth...but I am lower than you've seen as of a few days ago
Aiight will check in da sunlight danke guru
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
