Calling all "X's" with a lowered suspension!
Old Mar 8, 2008 | 01:54 AM
  #631
jmonsale's Avatar
Originally Posted by JMAN44544
Just ordered the H & R Springs (following qturbo's pics.) Most seemed happy with the ride and the even drop. I am also adding SPC Rear Camber Kit. The new wheels will be nice and cozy.
Getting em put on next weekend. Will give a good breakdown on the ride.
Thanks for the help from Flyinglumpia and qbturbo for influencing my decision.
How much of a drop do they give you
Old Mar 8, 2008 | 05:48 AM
  #632
JMAN44544's Avatar
Specs say 1.2in in the front and 1.1 in the rear. Go to page 24 in this thread and qbturbo has the springs on. Is a nice even drop, and the springs are progressivly wound instead of linear, so rides should be better.
Old Mar 8, 2008 | 09:50 AM
  #633
Kazaam's Avatar
Just received my new 350z H-Techs for my 05X, looking at buying a rear swaybar cuz I'm told our X can't fit a front one (is this correct?). I want to do all suspension work my boy helps me put springs in. I've waited too long for these coilovers. Will these 350z H-Techs give me an even drop (more in front?). What about all the different tie braces you can put on coupes, which ones fit our X??
Lookin at buying this rear sway since with the X I can't mount the front.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=020
Old Mar 8, 2008 | 11:07 AM
  #634
JMAN44544's Avatar
Next Saturday cannot get here fast enough
H&R springs go on next weekend, but I had to throw the new wheels on for a week so I can judge the difference in ride before and after the springs. These are 19in MRR GT-1 wheels with Falken FK452 245/40/19 tires. The ride feels great so far. Old tires had a bit under 28k on them, so these feel much softer. Even with a bigger rim.
Old Mar 8, 2008 | 02:58 PM
  #635
seddon's Avatar
JMAN44544 if you look at my pics I'm dropped on H&R sedan springs and they give a better rid than teins.
Old Mar 8, 2008 | 03:40 PM
  #636
JMAN44544's Avatar
Great, I love the drop on your ride, so I am quite sure I make the right choice.
Old Mar 8, 2008 | 06:51 PM
  #637
qbturbo's Avatar
Nice wheels, complements the color of the car, the drop will tie it all together.
Love the fogs by the way. Post the pics when the springs go on!
+1 to H & Rs ride over Teins.
Old Mar 12, 2008 | 03:16 PM
  #638
tutty's Avatar
JMAN, would the 40 series tire cause any rubbing problems when you drop with H&R springs? as you know, i'm most likely going with the same setup lol
Old Mar 12, 2008 | 04:31 PM
  #639
JMAN44544's Avatar
I have 245/40/19's and I have 3 inches, pre drop of clearance with a +35 offset. I do not think the 18's with the same other specs should cause an issue. I am getting the work done Saturday am. Will have pics up that afternoon.
Think you will be fine.
Old Mar 12, 2008 | 08:28 PM
  #640
FlyingLumpia's Avatar
I am running 245/35/20 +40 offset with a 5mm spacer on and have no problem. Dropped on 350z s-techs in front.
Old Mar 12, 2008 | 09:50 PM
  #641
jimmyc13's Avatar
Great idea to mount the tires first to see the difference in ride characteristics. I highly recommend you test out your cornering abilities now, with the 19's on & stock suspension....then give it a shot next week...you'll see a world of a difference. Also, I think your car will look 10X better on those rims once you drop it...good luck w/ the install!
Old Mar 12, 2008 | 10:27 PM
  #642
qbturbo's Avatar
tutty:
I'm dropped on H & R springs, 19x8.5 rims, 40 offset, with 245/40/19 tires, no rubbing with 5 passengers and loaded trunk.
Alignment corrected front and rear toe and adjusted rear camber as much as possible.
Good luck.
Old Mar 12, 2008 | 10:37 PM
  #643
Kazaam's Avatar
Got tired of waitin for these coilovers, gettin my 350z H-techs along with a new V2 Richie strutbar installed next weekend. Posted on here for ideas on what additional tie braces like the GT-Spec will fit on my 05 X but got no response. My X looks like a damn SUV with my 20s on lol. Check it out.
Old Mar 15, 2008 | 09:19 PM
  #644
JMAN44544's Avatar
The Shocker
Two fingers in the front and one finger in the back...
Ok, it is a bit better than that. Pretty much a 2 in the front and 1.5 in the back, but not exactly the same.
So I threw on the H & R sedan springs, SPC rear camber kit and bolt kit today. I left on the stock shocks. I drove home from the shop ('bout 45 mins on the highway) on the stock rims and tires and the drop felt amazing. Not bouncy at all. Very tight, less boaty. Some had commented about the ride being bouncy in the rear with some of the drops they had, it is day one, but I do not feel it a bit. These springs are progressive, vs the TEIN that are linear springs, so may be some of the difference.
-Thanks again to qbturbo, Seddon and Flying Lumpia for your help with this.
I have not driven the car yet all finished. Sad but true. Will do that tomorrow and see how she feels. But as far as looks, she looks pretty damn dirty and nice to me at the same time. Will post some cleaner pics at some point, but aside from water, soap and wax, I am done with the outside of this car.
Maybe Turbonetics next spring when my warranty wears off and I have nothing to lose...
Old Mar 15, 2008 | 09:24 PM
  #645
ajwade's Avatar
Kazaam35x that is a fine auto m o b i l e!!!!
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
