Random Little Question Thread
Old Feb 3, 2011 | 10:44 PM
  #2866
CG4DR's Avatar
yes the rev light blinks 500 rpm before what you set it to come on steady...
and 6mt at 80 in my 05 is around 3000rpm....
and my random question.... if i add test pipes will an exhaust leak in my ypipe get louder??
Old Feb 3, 2011 | 11:29 PM
  #2867
NFSP G35's Avatar
? = 2B || !2B
^Most likely.
I did a test pipe in the 94 and had an exhaust leak get louder.
Old Feb 4, 2011 | 12:22 AM
  #2868
CG4DR's Avatar
cowboy bepop? bleach?
Old Feb 4, 2011 | 12:33 AM
  #2869
NFSP G35's Avatar
? = 2B || !2B
No and no.
Cowboy Bebop was great though. (Also, your closest guess)
Check the sig
Old Feb 4, 2011 | 12:36 AM
  #2870
CG4DR's Avatar
i know who that is but i just can't remember the name... the big O
and i want this!! http://cgi.ebay.com/ebaymotors/MEGAN...item3cb16fc379
Old Feb 4, 2011 | 01:05 AM
  #2871
NFSP G35's Avatar
? = 2B || !2B
^I've considered it. you'll probably get a better price here: https://g35driver.com/forums/exhaust...es-y-pipe.html
If you got $51 to blow and are feeling adventurous: https://g35driver.com/forums/dfw-g35...03-y-pipe.html
Old Feb 4, 2011 | 09:39 AM
  #2872
Swivel's Avatar
Moderator
Originally Posted by The Stimulation
Are the OEM springs from a sport and non-sport sedan the same? I think they are, just not sure. Wanna verify if the non-sport springs would fit on the sport shocks/struts.
They are not, the sport springs are stiffer. They will fit, but will be a little hard on the shocks.
G35 sedan with sport suspension
314F/342R
G35 sedan non sport
283F/308R
Old Feb 4, 2011 | 01:04 PM
  #2873
Siaon's Avatar
What color bulb is the stock corner lights on an 05 sedan?
Old Feb 4, 2011 | 01:07 PM
  #2874
NFSP G35's Avatar
? = 2B || !2B
^The bulb is just a plain bulb, no color. The lens housing itself is amber.
Old Feb 4, 2011 | 01:12 PM
  #2875
Siaon's Avatar
Oh, alright, thanks.
I wasn't sure if I had to buy new bulbs or anything if/when I get some clear corners. I'm getting sick of the amber, knowing that it could be white. :P
Old Feb 4, 2011 | 01:15 PM
  #2876
NFSP G35's Avatar
? = 2B || !2B
^You should.
Yellow/Amber LED or tinted halogen, if you want to be legal.
If you keep the stock clear bulb, it'll look bad and won't be legal either.
Easiest thing is just to go pop the lens out and see what's in there now, it only takes like 2 minutes.
Old Feb 4, 2011 | 01:26 PM
  #2877
Siaon's Avatar
Is there a specific size bulb for LED in the clear corners? I don't have a lot of knowledge about them. I believe PIAA is a good brand for them.
I asked her because I had a bunch of time with nothing to do, with the exception of going to my car. xD
  #2878
The Stimulation's Avatar
314F/342R
G35 sedan non sport
283F/308R
Thanks so much!
Old Feb 4, 2011 | 01:44 PM
  #2879
NFSP G35's Avatar
? = 2B || !2B
http://www.sylvania.com/ConsumerProd...lacementGuide/
Old Feb 4, 2011 | 01:54 PM
  #2880
Siaon's Avatar
Thanks a bunch!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
