Random Little Question Thread
Old Jun 13, 2011 | 12:22 PM
  #4216
NorthDakota's Avatar
Just the stock ones that come on the car I think. round on the outside with a "design" in the face of it.
Old Jun 13, 2011 | 12:26 PM
  #4217
nazc0's Avatar
2006 Vortech supercharged Sedan
go to a few shops and ask to use any keys they might have to see if any fit, or i just found one that almost fit but a bit to big and just bought it and ground down the sides and bam perfect key
Old Jun 13, 2011 | 12:29 PM
  #4218
NFSP G35's Avatar
? = 2B || !2B
Our cars don't "come with" any wheel locks.
Those you're talking about might be difficult to get out
Old Jun 13, 2011 | 01:10 PM
  #4219
albundy1987's Avatar
Stainless Brake Line Question
Do the stainless brake line kits on ebay, such as...
http://cgi.ebay.com/ebaymotors/StopT...item255626e141
Fit the coupe & the sedan. I would think it would be the same but i wanted to check. I have a 2006 G35x.
Thanks
Old Jun 13, 2011 | 01:43 PM
  #4220
Well shlt. I went to tires plus over lunch break and they didn't have anything. I'll check a few more places before I go for the destruction method.
Old Jun 13, 2011 | 05:12 PM
  #4221
SN00P's Avatar
CLUB MODERATOR
Originally Posted by SN00P
i haven't asked a question in a while and its time for to ask ..
within the last 2 weeks my back driver side wheel is making a click sound . i researched clicking from the back and it says rear axle click (TSB)
now i have watched videos and stuff to see if that is exactly what mine sounds like .. in the videos from N-D its makes 2 click/clunk noises and same from N-R ..
on my car when i put in 1st (6MT) from take off it sounds like a bicycle with a playing card hitting the spokes.. click,click,click,click and when i hit the gas a little harder it goes away.. and when i put the car in N and roll to a stop it comes back around 10mph ...
is it the rear axles , hub, bearing , compression rods, end links , coils , breaks ,
need some answers.. also i have another 40,000 miles / 4 years of extended warranty and if in deed it is the axle it will be covered :-)
lets hear your thoughts please
Bumppppppp
Old Jun 13, 2011 | 07:50 PM
  #4222
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by BlkSedan4me
thanks, front camber arms are pretty pricey though compared to the rear. But i guess still cheaper than changing front tires twice a year
That is an intelligent observation, i'm proud of you.
Old Jun 13, 2011 | 08:52 PM
  #4223
OCG35's Avatar
The OEM sport package wheels have mcgard locks
Old Jun 13, 2011 | 08:56 PM
  #4224
OCG35's Avatar
I didn't get the lug key when I bought my car. Would a nissan dealership have one that would fit or will I have to do the socket trick?
Closest infiniti dealership is ~300 miles away.
Check the documnets and owners manual that came with car... there should be a tag with wheel lock code - you can call the dealer or probably mcgard direct and request replacement key... I think you need to submit copy of the document and possibly fill out form.
It used to be a common topic - try searching for OEM wheel lock key (but go back several years)
Old Jun 13, 2011 | 09:03 PM
  #4225
naughty240's Avatar
There is usually someone at Nissan dealer with a set of keys. At least at mine there was.
  #4226
DrewLe's Avatar
My 06 came with wheels locks. I was in the same situation and didn't receive a key from the dealer I got it from, except I wasn't 300 miles away though. I know Infiniti dealers have a universal key for all the wheel locks since no two are the same.
NorthDakota, try the Nissan dealership. If not, then a discount tire or the oversized socket trick
Old Jun 13, 2011 | 09:08 PM
  #4227
NFSP G35's Avatar
? = 2B || !2B
For really? Huh.
Did not know that
I figured wheel locks would be a dealer installed option if anything.
Guess you learn something every day.
Old Jun 13, 2011 | 10:12 PM
  #4228
D.Reaper's Avatar
how would i go about running a secondary hid kit also for low beams? i will be doing a quad retrofit with all 4 projectors running low beam at the same time, with one pair wired for high beam. just trying to figure out the wiring to get it all running correctly
Old Jun 13, 2011 | 10:30 PM
  #4229
CG4DR's Avatar
easy to get off, take them off on the daily. they make kits
Old Jun 13, 2011 | 10:34 PM
  #4230
CG4DR's Avatar
they plug into the factory wire harness
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
