Random Little Question Thread
#5206
I would do NGK plugs. That is what myself and many others would recommend. I'm fairly certain you want the Iridium plugs as well IIRC.
It isn't really that hard of an install but I'm more of a do it yourself person. It could get a little daunting if you didn't want to do it.
I saw a video on how to change it and it was quite over whelming for me since i am not a DIY guy and won't like to play with engine. So i may have to pay and get it outside.
#5208
OEMs are Platinum btw NGK (6240) PLFR5A-11 which will last longer then Iridiums, both will work.
g35_white (12-05-2011)
#5209
Hey guys i need help, ive been trying to get rid of the clunking comin fr the passenger side i ended up swapping, sway bar links, lower ball joints, upper a arms, compression rod bushings and the passenger side upper strut mount and struts and the noise has been reduced a lot but i still got clunking on the passenger side i dont mind changing parts cause ive gotten every thing pretty cheap from the classifieds and im getting my suspension ready before i drop it, so what else could it be is only on small cracks, may tie tods, rack and pinion bushing, heeeeelp
#5210
^ going over bumps?
Check out this thread https://g35driver.com/forums/g35-sed...rut-noise.html
I have a clunk (there is a video on the last page) I have replaced the endlinks, I have to change the strut mount, which should be it.
#5212
#5217
ill Sedan
#5218
telling him to get a square setup is just an easier answer, had he attempted to find info, he would of found the group of postings on wheels and tires for the X.
I'm on squared wheels and stagged tires. Was on stagged wheels and tires. Will eventually go square tires and wheels.
#5219
This is what mine looked like at 125k
Stock Platinum NGKs
#5220
but answering it this way opens up 15 more follow-up questions...
