Random Little Question Thread
Old Feb 3, 2012 | 04:21 PM
  #5596
Trickstyle's Avatar
Originally Posted by jdubin94
Will lowering the psi on my tires give me better ride quality? I feel like it would
I wouldn't do it, as you lower the psi your gas mileage drops with it too, and you'll eventually have sidewall damage. Your sidewalls simply aren't made to be driven on, and you will go through tires a lot faster if you do drive on them excessively.
If you over inflate your tires, you will wear out the center of the tire much faster than the rest of the tire. Again, going through tires at a faster rate.
I would just stick to the 30psi, you will get the best mpg and life outta your tires. If you want a better ride quality, I would suggest getting some 17's. Typically more tire = better ride quality. When i went from my OEM 17's to low pro 20's on my Z, it was like night n day. I felt every single freakin rock I ran over lol
Just my .02
Old Feb 3, 2012 | 04:55 PM
  #5597
thescreensavers's Avatar
Mr.202?
Someone dumped water on my i-Key and now its broken
I checked on ebay and tons of people are selling OEM keys but they are not really OEM keys they have aftermarket internals. Anyone have experience with this?
Old Feb 3, 2012 | 04:58 PM
  #5598
Mr.202?
Just my .02
Id go by door jam psi which is 32 for the sedans, 30psi is a bit on the lower side. Just need to check it frequently so it does not dip too low
Here is a good read on PSI and Wet Tire Performance http://www.tirerack.com/tires/tirete...e.jsp?techid=3
Old Feb 3, 2012 | 06:18 PM
  #5599
TurTLe*'s Avatar
link to one of these aftermarket internal ones?
I never knew/heard of such things.
Old Feb 3, 2012 | 07:04 PM
  #5600
TurTLe*'s Avatar
Best way to transport coupe seats ?
For anyone who got them shipped how much did it cost?
Old Feb 3, 2012 | 11:23 PM
  #5601
SSJRICH's Avatar
Do the coupe Brembos fit the sedan? I am pretty sure I read it somewhere that they do. And it logically makes sense that they do. Also I guess is there a difference in the ABS or brake cylinders etc that would have to be changed too?
Old Feb 3, 2012 | 11:41 PM
  #5602
NFSP G35's Avatar
? = 2B || !2B
Yes they fit.
I don't think you have to change master cylinder, but you do have to change brakelines IIRC.
Not 100% sure though, so you should probably wait for someone else to chime in
Old Feb 4, 2012 | 12:20 AM
  #5603
Theory_EK's Avatar
Brembos are a direct swap you need to trim you rear dust shield tho. Depending on your wheel situation you may need spacers also.
Old Feb 4, 2012 | 12:24 AM
  #5604
jdubin94's Avatar
How do you?
How do you guys hold the steering wheel? In all different situations?
-Highway?
-City Driving?
When I am driving at high speeds on the highway like 75+, I feel like I dont have enough control with 1 hand up top... How would you hold it if you were going that fast?
Old Feb 4, 2012 | 12:26 AM
  #5605
TORETTO's Avatar
1 hand at 12 o clock is gangstalicious. I hold it at 9 oclock or partially rest my arm on my lap gripping the wheel somewhere on the bottom half. The other hand somewhere on the upper half. Taking it off only when shifting the car. (Real shift, not one of those fake manumatic up-down things)
Old Feb 4, 2012 | 12:55 AM
  #5606
NFSP G35's Avatar
? = 2B || !2B
left hand, approx 8 oclock
Old Feb 4, 2012 | 04:03 PM
  #5607
SSJRICH's Avatar
9 oclock in steering wheel tumb part. Right hand on shifter usually. (MT)
3 oclock for spirited 2 handed driving.
Old Feb 4, 2012 | 09:09 PM
  #5608
NjMatteSedan's Avatar
they fit in the backseat. you just gotta put them on a sideways "69" position and be careful when you close the door so you dont scratch your door panels with the seat rails. maybe put a towel under the rails just to be safe.
Old Feb 4, 2012 | 09:13 PM
  #5609
TurTLe*'s Avatar
how much force is exactly need for this move?
This could save me a LOT of money if the coupe seats can 69 in the back seat Joking and seriously.
Old Feb 4, 2012 | 10:09 PM
  #5610
ray1370's Avatar
What I did was pull the backseat bottom out first, then let the coupe seats sit on the backseat floor facing front. I put flattened computer shipping boxes on the backseat floor to protect it from the coupe seat rails, and between coupe seat back and the backseat. Wrap the ends of coupe seat rails with towels, and be careful not to scratch your paint/trim when getting them in and out of your backseat. Each seat weighs about 50~60 lbs. Hope this helps.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
