Random Little Question Thread
okay so it is a 2003.5
Another thing, this car is a 2003.5 6mt, if cold (as in the car hasnt wamred up) when you sgtart it the rpms, go up like normal, then the rpms drop down and the car stalls.....does anyone know what could be the reason for this? there is no check engine light or anything
Hey guys i need this answer ASAP, looking at a 2003 sedan 6mt, the guy doesnt know what options it had and i didnt really get a chance to look when i went and looked at it, but if it has a cassette player does that mean it has the Bose system? do the 2003's even come with Bose systems? I believe is a 2003.5
Cassette player also comes standard on 03-04s, with Bose being optional. Check the flap of the cassette tape insert and the sub woofer mesh behind the back seat, if it says Bose then it comes with Bose system.
Those might be hard to find. I've only seen kits for the piston seals. Have you tried calling back to the powder coater to see if they still have them when they were taken apart?
2003.5 6MT sedan comes standard with sports package.
Does the rpm drop after it warms up or when it's still cold, right after it started?
Does the car drive fine? If it does then it might be the throttle body needs to be cleaned, my car was doing it when the throttle body was dirty. There's some gunk build up around the throttle valve. Clean it up and see if it helps. Remember to DISCONNECT THE BATTERY before you clean the throttle body.
yes the car drive great, i just biought it so tomorrow im going to start doing full maintenance on it,like changing all the fluids andcleaning everything up.
Another thing, the guy i bought it from said he used synthetic blend high milage oil. Nowdo i have to keep using synthetic blend or can i switch back to normal conventional oil? I much rather use conventional oil
^You're far better off using synthetic oil.
If you absolutely must switch back, you should run at least 1 oil change in-between that's a 50/50 synthetic blend.
and if imay ask why do you say im better off using synthetic? i know i can search for this,im at work right now and doing a little bit of internet searching...
I need an oil change..I have an 03.5 at 160k...any types of oil brands (synthetic), i can buy at autozone or walmart, you recommend?
Is there different filters, if so which do you reccomend?
i usually take it to a shop for oil change, so im not sure what brands i should look for
thanks!
thanks!
thanks!
thanks!
Better off staying clear of Mobil1 oil and Fram filters
It's just better, and used oil analysis has proven it.
