Random Little Question Thread
Old Jul 18, 2012 | 02:12 AM
  #6736
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by dofu
Just something to think about...
This true is too
Old Jul 18, 2012 | 07:01 AM
  #6737
TunerMax's Avatar
G35
I still don't see how the temp drop of the upper plenum from the addition of a spacer helps any bit since the upper manifold still get hot to the touch after the installation of the spacer (I've gone through a few different spacers). .
Insulation/isolation from the effects conduction head has on the upper manifold.
This doesn't stop convection heat (air) when the engine bay eventually gets hot enough, but it still lowers temps, and with moving air (actually driving) it's very relevant.
[quote=dofu;6515770. Even if the upper plenum is cool enough to touch, the hot lower plenum is still a problem. .[/QUOTE]
I see what you're saying, but it DOES still make a signifigant difference. Just like a true Cold Air Intake does. That's like saying a CAI is pointless because the Intake manifold is hot. Get what I am saying here?
Also things aren't black and white when we say "cold", cold is relative. It will still be hot air to you as a person feeling it, but to the engine, by comparison, it's much colder.
Perhaps sticking to LOWER temp would be less confusing here.
[QUOTE=dofu;6515770The best solution is to put a gasket to stop the heat from transferring between the motor itself and the lower plenum. This way you can actually rest your hand comfortably on the upper plenum (and even the lower plenum too if you can reach it), meaning overall temps are actually decreased enough to finally make a difference. Why half-@ss a job with a cool upper plenum while your lower plenum still gets hot as hell?
.[/quote]
This is a good idea.
Old Jul 18, 2012 | 11:03 PM
  #6738
dominate's Avatar
Is it just me or is there a larger fender gap in the front on revised Z?
Old Jul 19, 2012 | 12:28 AM
  #6739
thescreensavers's Avatar
Mr.202?
^ The revised Z is the same drop as G/Z, the Front is the same as unrevised but the rear is only dropped half an inch.
Old Jul 19, 2012 | 03:06 AM
  #6740
dominate's Avatar
Yeah maybe its just me but it looks like the Z/G and revised setups have more fender gap in the front.
Old Jul 20, 2012 | 09:50 AM
  #6741
rjohnst27's Avatar
quick Ipod question/clarification for 2005 G35x
Hey everyone, I'm sure this topic was beat to death but I just need some clarification.
Heres the situation, I want to get an adapter for my IPOD to work in my 2005 g35x with SAT.
Now I know that you can get the USASPEC PA 15 INFI that installs in the truck.
HOWEVER, I want to install the unit behind the radio because it would be much easier for me to do.
Can the USASpec PA 15 INFI be installed behind the radio or does it HAVE to be installed in the truck?
Will the PA 15 NIS work with my car being that that unit does install behind the radio?
If the answer to those questions is NO, is there any other comparable units that would work with the install behind the radio?
Thanks in advance.
Old Jul 23, 2012 | 11:23 PM
  #6742
dominate's Avatar
I lost the key for my OEM locking lugs, could the dealer do anything about it?
Old Jul 23, 2012 | 11:25 PM
  #6743
Mr.202?
^ They will charge you to buy new ones if you want the key. They have the key their still.
You can also buy the key at your local autostore.
Old Jul 23, 2012 | 11:55 PM
  #6744
dominate's Avatar
Thanks, do you know how much the dealer would charge for the new lugs?
Old Jul 24, 2012 | 03:17 AM
  #6745
VincenzG35's Avatar
What's the average price for the HKS muffler for the 2003 sedan I see about 500$ when I search is that right
Old Jul 24, 2012 | 11:34 AM
  #6746
dofu's Avatar
20 Year Member
It depends on the dealer and the car. The last time I looked at the sticker on the door of a brand new GT-R, the dealer listed the price for OEM locking lugs at $399. I know, I should have taken a picture and posted it up here.
Just order them online and bring them with you. You don't really have to go with OEM either, unless that is your preference.
Look through our vendors. I remember buying mine from a vendor here at a pretty good price. I think it was about $400.
Old Jul 24, 2012 | 12:04 PM
  #6747
TunerMax's Avatar
G35
Locking lugs are not dealer specific/OEM specific, though some dealers DO provide them as an option, they're still not OEM, they're mainly made by "Mcgard", that's the most well known, and the one most OEM's use.
That said, there's way too many versions/keys on the market, it would be surprising if they carried the same one still, more likely it will be special order. This is also the same product you would get from your local parts store.
It's normally Cheaper/easier to just have them all removed with a special key (universal removal tool) and install new ones. Not to discourage you from trying to get a key, just a useful bit of knowledge before you spend any money.
Old Jul 24, 2012 | 12:41 PM
  #6748
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
ok so, Nissan DOES offer OEM wheel locks,
if you loose your key, you have these options, you can take your car to the nearest Infiniti dealership, pull up on the service drive, they can find out which lock you need by putting the master set till one fits, and order you a replacement, 20-30$ they can use the master set to remove your current locks, and you can get an OEM replacment lock set w/key put on, they average 40-50$
if you still have your McGaurd card from when the car was purchased, you can give that information to the dealer and they can order you a replacement with that card information without the master set needed
Old Jul 24, 2012 | 12:43 PM
  #6749
mpugeda's Avatar
hey Phil, do you sell 03-04 G35 Sedan rear bumper covers??? If so how much?
Old Jul 24, 2012 | 05:35 PM
  #6750
TunerMax's Avatar
G35
That's cool to know, but who makes them for Nissan?
That's a good price for a Dealership Wheel lock set though, you can pay the same at the parts store. I think your prices might be below par compared to most dealers though.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
