Random Little Question Thread
Old Jun 10, 2013 | 02:21 PM
  #9241
MrTBahgs's Avatar
2006 G35X with about 86,000 miles.
I dont use my manu-matic mode too crazy often, but every now and then I have an issue when trying to downshift and Im not sure what would cause it since it isnt consistant. I will try and continue to test it further and pay more attention to when it happens, but for now maybe I can get some help with the information I have currently.
As far as I know, only when I try and downshift I will sometimes have the transmission do nothing. I recall it almost always happening when trying to go from 4th to 3rd and no matter how i move the shifter it just acts like I didnt touch a thing. Going back up shifting and I think it works perfectly, but during the times it wont downshift the only way it does drop gears is when i slow down enough for the RPMs to drop way low and it forces itself to auto downshift. I think after it does downshift I might again have the problem going down to 2nd. Then it usually works fine again after going back up.
This may only happen once during a full driving session and doesnt always happen. It only has happened in the middle of a driving session, never been the very first time I try and downshift when in manu-matic mode.
Im not sure how the whole system works, but could there be some sensor or something in the stick that is dirty or has bad contacts to not register my downshift? I initially considered it to be a wiring or grounding problem, but with it so inconsistant and rarely happening I wouldnt think thats the issue.
Is this something thats best to explain to the dealer so they can look into certain components for possibly a quick fix?
Its not like its an immediate need to get fixed since everything works fine when in drive, but this would be nice to have working correctly so I can drive in manu-matic whenever I want and not be annoyed by it.
Old Jun 12, 2013 | 09:16 PM
  #9242
PSito's Avatar
08 350z HR y pipe and mid pipe on 2003 g35 sedan
Hey all
I really didn't want to make this thread but I have searched and searched to no avail.
Long story short I've been able to get my hands on a 08 350z HR y pipe and mid pipe for uber cheap.
I know that the 350z HR y pipe will fit with no issues AND that the 350z mid pipe is too short for the sedan.
Extensions can be bought to fit the 350z mid pipe on the g35 sedan, the problem is I have seen BOTH answers of 6" or 8" extensions are needed...
I'm about to pull the trigger on a 6" extension but I just want to make sure 6" is enough before buying it.
The 2" discrepancy seems a bit much so I don't think I can just make it fit if its a full 2" off can I?
Can anyone confirm whether I'll be ok with the 6" extension or do I need the 8"?
Any help is much appreciated.
Thanks
Old Jun 13, 2013 | 10:06 AM
  #9243
Peoria35sedan's Avatar
I welded in a 6" piece and mine fits fine. 8" would probably push the muffler tips out like 05-06's
Old Jun 13, 2013 | 11:19 AM
  #9244
PSito's Avatar
Thanks for the info! Exactly what I needed to know.
Old Jun 13, 2013 | 04:43 PM
  #9245
nazc0's Avatar
2006 Vortech supercharged Sedan
Go for 8'' I put a 6.5 and it looks kinda weird, it fits and works fine but tips look lost in the bumper
Old Jun 13, 2013 | 07:04 PM
  #9246
SooWoo's Avatar
Hi i have a 2005 g35x (awd) and i have numerous lights on my dash. (AWD, abs, vcd, slip, and service engine) i read up on it and most ppl say that i need new brakes/rotors or pads, and/or i need to either clean or replace one of my speed sensors and i was wondering if u had any other ideas or any input on what maybe wrong with my car ?
Old Jun 13, 2013 | 08:08 PM
  #9247
G_DiRTY5's Avatar
Originally Posted by dominate
Question for those who have installed HID fogs: Do you guys use a HID relay?
^ I just found out the other day my 04 sedan has fog lights in the high beam housing, after all this time I had no idea and I had a good laugh when I found out too
Anyway I'm just curious how it works, because it's also a daytime running light which powers at half and then turns into a fog light at full power without blinding anyone. Is there a shield that comes on and off as the high beams are applied??
I wanna know now because that means I can run a bi xennon setup with the hid's being at full power when I need to put on my high beams.
Old Jun 14, 2013 | 09:27 PM
  #9248
lilroy00's Avatar
getting bad mpg
I recently purchased an 06 Infiniti G35 and i really like the car, however i am only getting 19 mpg hwy. i have a jimwolftech cold air intake and aftermaket exhaust (not real sure what kind yet). the car has been lowered and has aftermarket sway bars. it also has 20" wheels with 245/35r20 tires. it has 3.5 with 60,00 miles and 6 speed manual. i figure the larger chrome wheels are killing my mpg. but do you think it is time to change plugs. i don't have a maintaince manual
Old Jun 15, 2013 | 05:39 AM
  #9249
TORETTO's Avatar
When fitting Akebono calipers onto a G35 coupe (2005, no brembo) using stock lines, do I need to replace any of the banjo bolts? (Perhaps stock ones being too long or too short)
Old Jun 17, 2013 | 11:13 AM
  #9250
20" wheels will kill mpg, to much weight to far from the axle. Also don't expect much more than 22mpg ever
Stock lines and banjo bolts are supposed to work with Akebono's.
Old Jun 18, 2013 | 05:36 PM
  #9251
brownie's Avatar
Is there any difference in the 03/04/05 seats to the 06 seats? I've got a company that can redo my seats but he's saying he only has the pattern for 03-05 but not an 06.. But I could swear they're the same exact seat/pattern right? thanks!
Old Jun 18, 2013 | 07:22 PM
  #9252
thegreatkwijibo's Avatar
does he know you have a sedan? I could be mistaken but I think the coupe the 03/04/05 are the same and the 06/07 are the same.
Old Jun 18, 2013 | 08:14 PM
  #9253
brownie's Avatar
Yes he knows that.. That's what I'm thinking cause the 05/06 is the same for sedans.. So I'm guessing they're all the same lol
Old Jun 18, 2013 | 08:41 PM
  #9254
TORETTO's Avatar
I've been hearing issues with the stock banjo bolts being too long and not sealing properly.
And Z1 also states here under Installation Notes
http://www.z1motorsports.com/350_g35...oducts_id=4626
"If your Z/G was not equipped with the factory Brembo brake kit, it is highly recommended that you either purchase the Z1 SS Brake Lines or select the Banjo Bolt option below. The factory banjo bolts are too long and will not seal properly. "
Why would other places sell the BBK as a bolt on kit without mentioning this though?
So now I have conflicting stories. But either I need the bolt or I don't. Which one is the right one?
Old Jun 19, 2013 | 09:04 AM
  #9255
tahoe's Avatar
Hey guys, I have a 2005 g35 sedan with 80,000 miles and I've been having this clunking sound coming from the passenger rear I think. I hear it every time I hit a bump in the road and its more noticeable at lower speeds then highway. It sounds like a hollow springy clunk, I have already replaced the shocks and struts and the rear endlinks but the sound is still there. What else could be causing this?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
