Studio on Wheels - Sound Impressions
Rating: Thread Rating: 2 votes, 4.00 average.
Old Jun 29, 2007 | 05:08 PM
  #256
Virus's Avatar
I was referring to the Bose HT systems and not the SOW. The stock system is fine for me. I'm tired of spending huge amounts of money for car audio. The SOW's is not horrible by any means and it's actually better than "most" OEM systems. I think I'm more disappointed in their highs than their lows.
Old Jun 29, 2007 | 07:26 PM
  #257
dopey's Avatar
Originally Posted by Hattrick
Not sure if you were referring to the SOW here or Bose in general, but in any case I wonder if there are production quality issues/differences with the SOW. I'm saying this because I have measured the frequency response of the SOW with an RTA and with everything set to 0, it does go down all the way to 20Hz and actually with some gain starting 80-100Hz and below. Highs start to roll off at about 8kHz. Front and rear is different, fronts have more mid bass and the rears have more low end bass. The rears also cannot reproduce anything above 12.5kHz. Based on that the SOW does not lack bass, if it does maybe the woofers are disconnected ? Having said that I do think the SOW lacks some punch if that's the right word. I seem to think the amps don't have enough instantaneous power to drive the speakers. I'm not a fan of Bose especially their HT systems, but I am completely satisfied with the SOW as an OE system.
I think the problem is when people say it's lacking in lows, they don't mean it doesn't produce the lows. People are used to stereos and music that is over-engineered so that the gain on the lower frequencies is significantly higher than the gain on the mid and high frequencies. When they look at the SOW which is relatively flat, it doesn't sound like what they're used to.
Personally, I am completely satisfied with the SOW system. Two of the CDs I use to test out stereo equipment are two different arrangements of Carl Orff's Carmina Burana, one with a little more emphasis on the mid and the highs, and one with a good dynamic range all the way across, and both CDs sound beautiful in the SOW system. I know auditory memory isn't perfect, but there was nothing about the ML system in the IS350 that I tested the same CDs on that stood out as being any better than on the SOW.
Old Jun 29, 2007 | 07:53 PM
  #258
mbhforum's Avatar
I am not overly impressed, but a lot of that has to do with the mediocre audio quality of XM and my Zune connection. The reason I upgraded to premium was for the sunroof and Bluetooth, not for the SOW.
Old Jul 12, 2007 | 02:24 PM
  #259
bugmenot's Avatar
Blows me away
I love it.
It crushes the HK that is in my 05 MINI Cooper.
Old Jul 13, 2007 | 01:23 PM
  #260
04NismoV35's Avatar
Was this at +/- 3db? Many drivers/woofers/subs like to hide that they go down to a specified frequency at +/- 6db or even worse. There would be a noticeable difference.
I listened to one not too long ago and was thoroughly unimpressed, at least not for all the hype. It seemed to lack punch as you stated. Then I got into my bro's 335i, which I previously thought wasn't that great either and realized how much better it was than I initially thought. Great impact and staging in comparison.
Old Jul 15, 2007 | 11:04 PM
  #261
Hattrick's Avatar
The interesting part was that I noticed some gain starting at 100Hz and below. 40-80Hz was about +8dB and 20-40Hz was about +14dB. Noise floor was about -40dB. All referenced from 1kHz.
Old Jul 15, 2007 | 11:20 PM
  #262
PiDD's Avatar
I have been meaning to do this... can you post the graphs? I would love to see a 20hz to 20khz graph.
Old Jul 16, 2007 | 12:23 AM
  #263
04NismoV35's Avatar
There must be some cancellations or phasing issues perhaps even due to the acoustics or who knows what. What I heard just doesn't seem correlate your findings. Very interesting though. Where was the microphone placed when you measured?
Old Jul 16, 2007 | 12:55 AM
  #264
wrxrocks's Avatar
I thought it was good, but when I listened to Lexus with Mark Levison, the G's sound crappy. Now that was some sound. But I am happy with the G's because I came from Mitsubishi Evo
Old Jul 18, 2007 | 01:32 AM
  #265
Hattrick's Avatar
Here you go:
Front and rear
Front only
Rear only
One pixel is 1dB. I forgot to note down what level 1kHz was at. The RTA's input gain was set at the same level for all measurements.
The measurement mic was mounted on the driver seat at the height of the head rest.
RTA was a Behringer DSP8024 Ultra Curve Pro
Measurement mic was a Behringer ECM8000
Signal was pink noise track from Sheffield Lab's "My Disc" Autosound 2000 Test Disc
Old Jul 18, 2007 | 01:35 AM
  #266
Hattrick's Avatar
Please share when you get a chance to measure yours. I would like to know if somehow my SOW was setup differently from factory, i.e. they cranked the gain on the subwoofer's amps.
Old Jul 18, 2007 | 01:39 AM
  #267
boostnmuscle's Avatar
yea i came from a dodge srt4 so the studio on wheels is amazing to me lol, i have been in alot of higher class cars (few days ago was in an s8, and wow was that sound amazing, but the G's sounds great to me)
Old Jul 18, 2007 | 01:42 AM
  #268
Hattrick's Avatar
Could be... but my ears do agree with the measurements. I did the measurement to confirm what my ears have been hearing because I thought mine had plenty of bass. The mic was mounted on a mic stand sandwiched by the driver's seat headrest. Now, of course the Behringer equipment I used is not the best RTA on the market but I think it's good enough for this purpose.
Old Jul 18, 2007 | 02:58 PM
  #269
bkrider's Avatar
Do you mean there is 1 dB between the horizontal dotted lines? If so, and if I am reading those RTA graphs correctly, the system is flat within +- 1 dB from 80 hz to 8 KHz, and shows only a 2 dB rise to 25 hz. As an EE and long-time audiophile, this looks very good to me--many expensive home stereos and home theater systems would not measure this well !
Old Jul 18, 2007 | 04:50 PM
  #270
Hattrick's Avatar
^ No... it's not that good. I meant one actual pixel on the LCD screen. IIRC, there are 8 pixels per division.
You have already rated this thread Rating: Thread Rating: 2 votes, 4.00 average.
