G35 tips you probably don't know :D
Old Oct 3, 2011 | 08:14 PM
  #241
Swagger_Jacker's Avatar
I changed clothes one day and forgot my key in my pants that i threw in the trunk. Started my car and drove around. When i went to lock the car it was beeping like a door was open. found in the trunk but didnt reopen the trunk.
Old Oct 3, 2011 | 08:27 PM
  #242
rpm&my_G35's Avatar
Your car doors were not locked before you put the key in the trunk and closed it. If the car doors are not locked then the trunk will not re-open with the key inside. You can re-open the trunk from inside the car.
When you turned off your car and exited you could not lock and close the car door because the key was in the trunk, right?
Old Oct 3, 2011 | 08:46 PM
  #243
that could be i dont really remember how it happened. I could have unlocked the door while holding the clothes in my hand as i walked by or somehow unlocked em later. I only have 1 fob so im a little hesitant to try it. either was thought it was weird i was able to start the car with the key in the trunk.
Old Oct 4, 2011 | 09:33 AM
  #244
rpm&my_G35's Avatar
Remove the mechanical key from the iKey fob and you can do all the testing you like. If something goes wrong you can still get in the car using the mechanical key .
I can also start my car if the key is in the trunk. But the good thing is that I cant lock the car doors when I turn the car off and get out.
Old Oct 4, 2011 | 10:22 AM
  #245
GXXXV X's Avatar
Does anybody know if you can use the mechanical key to lock the fob in the car? Like in the cupholder or something
Old Oct 6, 2011 | 09:24 AM
  #246
rpm&my_G35's Avatar
Yes you can but keep in mind that all it would take for someone to run off with your G would be to smash the window and go.
Not a good idea to lock the iKey in the car.
Old Oct 12, 2011 | 12:04 AM
  #247
MPohio's Avatar
Wouldn't you just be able to push the button on the door lock? I mean isn't the keyfaub within range of either door to be able to unlock it?
Old Oct 25, 2011 | 10:39 PM
  #248
Feeelax's Avatar
Originally Posted by G-ride808
False! It happened to me once. Well i was thinking the same, and did a lil demonstration to my friends. And I looked stupid because I acted all confident that it wont lock, but it did. I had someone come 12 miles to bring the other key. I had couple bags in my trunk. Maybe it blocked the sensor? IDK but it can happen!
I actually did this by accident once.. was washing my car and closed the trunk but it popped right back up b/c the key was in it... Maybe theres a time limit or a radius? I don't know but I can tell you 100% I had the key in the trunk and it popped open automatically.
Old Apr 2, 2012 | 08:52 PM
  #249
stockae92's Avatar
Blue tooth phone call
- If you are talking on the blue tooth headset, you enter the car and you turn the power on (I didn't start the engine though), and then you power off your blue tooth headset, your car's blue tooth connection will automatically pick it up from there and allow you to use the car's blue tooth to continue the phone call.
- And then if you start the engine, the blue tooth enabled call won't get dropped, but you can't talk when the engine is starting
Kinda handy when that won't interrupt your call.
Old Apr 3, 2012 | 08:36 AM
  #250
soundmike's Avatar
^ I guess that's handy if you just want to sit in the car before turning it on, right?
If i'm approaching my care while on the phone, get in and start the car, once the BT connection is established the call just transfers seamlessly. Same thing when i turn the car off and have the phone already on my ear.
Old Apr 3, 2012 | 12:55 PM
  #251
stockae92's Avatar
it was useful for me when i am talking on the BT headset and walking to my car, and get inside and want to get on the ride.
i suppose if you start up the car (engine) right a way and turn off the BT headset, the car's BT would pick it right up from there as well
Old Apr 3, 2012 | 01:45 PM
  #252
G force's Avatar
The steering wheel buttons typically allow you to scan through your preset radio stations, however if you push and hold the up/down button it will let you seek to non-preset stations.
Old Jul 22, 2012 | 06:20 PM
  #253
woostar88's Avatar
If you hold the day/night dim button. It will turn off the screen.
Old Jul 22, 2012 | 07:27 PM
  #254
rpm&my_G35's Avatar
I don't want to sound like a smart-*** but that is why the button says OFF on it.
Old Jul 22, 2012 | 07:56 PM
  #255
woostar88's Avatar
Haha that's true. It does say off on it. And I never noticed it. Until my gf "accidentally" hold to turn the screen off.
