350Z HR Y-pipe installed on a 2003 G35
Old Mar 5, 2009 | 11:51 AM
  #271
Jeff92se's Avatar
Red Card Crew
Originally Posted by DaveB
When the 2007 350Z came out with the VQ35HR motor and I saw pictures of the exhaust I took interest in the new Y-pipe. The layout of the y-pipe was entirely different than the Y-pipe that comes on the 2003-2006 G35s (VQ35DE/Revup). What really caught my attention was the longer down tubes and two rubber pucks mounted to the inside portions of the pipe. In exhaust theory, usually the longer the downtube off the header/manifold, the better the torque and powerband. I don't know if this was Nissan was going after, but obviously they saw some sort of performance benefit by substantially revising y-pipe. The rubber pucks were clearly installed to reduce NVH from the exhaust. After discussions with Godmans on this site, it turns out this revised Y-pipe fits because he's had it installed on his 1st gen G35 for a while now. I picked a HR y-pipe for $50 shipped and decided to give it a try for the hell of it. Tony with Motordyne has stated he thought the longer downtubes could improve low/midrange power because he's tested numerous Y-pipe downtube configurations when developing his new exhaust systems.
The DE y-pipe downtubes are about 5" long whereas the HR y-pipe downtubes are over 13" long. The exiting pipe at the midpipe junction is a full 2.5" vs the 2.35" for the DE y-pipe. Major power gains!!!!!!!!!1
Here's a shot comparing the two pipes:
I got the pipe installed tonight. There are no clearance issues and the pipe fits like the DE pipe. I drove around for about 5 miles and the car feels good. The car does feel better down low and in the midrange (nothing earth shattering), but I need to give it a week or so because my experience has been that it takes Nissan ECUs some time to adjust. One thing I did notice was reduced NVH under heavy load (low rpm going up hill and WOT). The exhaust tone is slightly deeper too and is slightly more exotic. Keep in mind I do have the 05/06 midpipe on my 03.
Old Mar 6, 2009 | 02:14 AM
  #272
Lucky-G's Avatar
They look VERY similair. Someone send me thiers for free and I'll try it out
Old Mar 8, 2009 | 03:04 PM
  #273
ELMACHOGERACHO's Avatar
i have access to a few sedan hr y-pipes thru work and i took a few rough measurements and its roughly the same length as a ypipe on a 2nd gen g35. ~34in.
Old Mar 8, 2009 | 07:07 PM
  #274
naughty240's Avatar
Finally installed mine today. I must say I like it a lot. Best 70 bucks ive spent in a long time.
Old Mar 8, 2009 | 09:01 PM
  #275
Lucky-G's Avatar
Does the 05/06 sedan midpipe, when installed on an 03/04, provide the same results as a coupe midpipe?
Old Mar 9, 2009 | 10:46 AM
  #276
driguez's Avatar
Im looking to pick one of these up so i can have my Kinetix HFC installed at the same time.
Old Mar 9, 2009 | 12:48 PM
  #277
tiguy99's Avatar
Hey just in case they decide to "toss the old ones out" why not grab a few of these Y pipes and help your fellow G owners out
Congrats bro! Not sure if you have a MD ISO spacer or not but toss that in the mix and you have a recipe for more fun fun fun. Have you reset your ECU yet?
Not a bad idea. Actually it would be a lot easier and probably cost the same hour or so of labor to have both installed at once vs doing them seperate. That's a great idea. How much did those Kinetix HFCs go for when you picked them up?
Now this I'm not sure. Anyone who's swapped these midpipes care to chime in and share your expertise?
Old Mar 9, 2009 | 01:02 PM
  #278
driguez's Avatar
/\/\/\/\ Got the HFC's at my305z for $100 + shipping, used of course.. Now im hawking for the Y pipe, hopefully i can find one soon.
Old Mar 9, 2009 | 01:19 PM
  #279
vstypicals's Avatar
Anyone know if I'll need 4 jack stands to do a Y-pipe plus test pipes install or will 2 jack stands be enough? I don't want to rely on the jack to lift up one side so essentially, I'm asking if both sides, front and back, need to be lifted or will lifting the front be enough?
Thanks!
Jeff
Old Mar 9, 2009 | 07:06 PM
  #280
g35 sedan hr y-pipe fits with no problems. i just installed one on my car today. fits like a glove. hopefully i wont have to worry about the vibration issues since mine came without the vibration dampeners.
Old Mar 9, 2009 | 07:54 PM
  #281
naughty240's Avatar
Thanks!
Jeff
I just raised the front. I also used a torch to loosen the bolts
Nope the spacer is soon though. No I havent reset the ECU. I didnt have any lights. I dont remember seeing you had too?
Old Mar 9, 2009 | 08:44 PM
  #282
vstypicals's Avatar
Where did you put the jack stands? .. stock jack points?
Old Mar 9, 2009 | 09:01 PM
  #283
naughty240's Avatar
^on the pinch weld towards the front.
Old Mar 9, 2009 | 09:11 PM
  #284
UmassG35's Avatar
Did you experience the same results as those who've installed one off of a Z?
Old Mar 9, 2009 | 09:15 PM
  #285
the exhaust sounds a bit more z/g coupe like. didnt really feel much more power, but i didnt beat on the g on my drive home due to traffic.
