Injen intake review
#91
on
Hey man, just looks really weird from this point of view. All of the torque lines ramp up the same, some just a smidge later than others. I wasn't implying someone forged the dyno results, and if I came off that way, I'm sorry! I'm still having a hard time believing a whopping 40ftlbs difference, but hell, if thats what it is, it'll save me some time fabbing up a long-tube CAI ![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
I wasn't saying that it was a turbo car either, just the way the torque ramps up looks similar to swapping out different hot sides on a turbo with the associated lag changes.... again, obviously not a turbo car pictured.
I ought to have some dyno time perhaps in the next few weeks, I'll share what I find out as well.
I have a tendancy to just spit out what I'm thinking, but I'm not trying to **** anyone off, and I'll try not to come off as I'm questioning someones integrity/honesty.
Last edited by Cracker Red; 04-29-2006 at 05:38 PM. Reason: my dumb arse came off the wrong way
#92
on
Your absolutely correct in questioning a 40ft-lbs difference at 4500rpm. The correct number is about 263ft-lb (not 283) a difference of only 15ft-lbs. (Correction made in original post.)
I'll look forward to adding your dyno results to the 200+ I have accumulated. I'll be especially interested in your torque results. A W or deep V pattern from off idle to 3.5k or so seems typical to a particular type of CAI.
We've also adopted the following procedure to help obtain standardized G35/250Z dyno results:
1. Coolant temperature at the start of each pull should be between about 190F. Engines should be cooled to this point betwwen pulls.
2. Intake air temperatures should be no more than 10F to 20F above the ambient temperature.
3. All cars should be run for a minimum of 5 minutes at a load of 40-50 road hp to bring engine oil, transmission and differential lubricant temperatures up to a reasonable consistent level (ideally 190F to 200F).
4. Test pulls for G35s and 350Zs shall be 5th gear for manual transmission or 3rd gear for those with automatic transmissions.
5. A minimum of 4 pulls are preferred with the first run dropped from average and peak calculations. Manual transmission pulls should be done from 1500 rpm and ending 100 rpm below the vehicles rev limiter.
6. A minimum of two (2) printouts should be provided showing measured horsepower, torque and air/fuel ratios over the test range. Mean horsepower and torque results are highly valued.
7. Atmospheric conditions, ambient temperature, barometric pressure and % humidity, should be recorded. All test data shall be SAE corrected.
8. Cars tested on inertia roller dynamometers should be “rolled in” and re-strapped to assure proper roller - tire interface and alignment. Tire pressure is critical to an optimum tire-roller interface.
9. Use big fans. You can't have too much air flow.
10. Open hood dyno results seldom if ever duplicate how a car performs in the real world. When properly used they are a good tool to compare where are to where you were.
The above is my personal opinion. Please don't knock it unless you've actually tried this procedure yourself.
Thanks in advance,
DaveO
#95
#96
on
I've got a question for you. I've heard of a consult tool for monitoring the nissan ecu. Is there anything I could perhaps get that would simply interface with my laptop?
If not, how far of a fluctuation does the stock temp gauge before showing the car is "hot"? Does the ecu monitor IAT, or do you use a seperate probe for that?
I'll try and keep everything as "standard" as I normally do. I'm right with you on the closed hood dyno as well (a lot of people arn't).
#97
on
As for other devices, I use a Techtom which is very limited in what it does. There are other more advanced ways to gather info using your laptop. Other form members may be able to help you out on that one.
The ECM (ECU) is provided with coolant and air inlet temperatures. I, along with others, have run lengthy tests on their effects. Hot coolant and/or intake air temps pulls timing. Those effects are reflected in our recommended procedure.
DaveO
#98
on
Originally Posted by 2FastG354U
I am just happy to see Injen CAI didn't give a power loss like G35 TX said...
DaveO
#99
on
#101
http://www.obdscan.net/scantools.htm
IMO, the tool is invaluable because it gives me the trouble codes and lets me clear CELs easily. I got it primarily because my wife's 98 Legacy requires the dealer to scan and clear CELs ($80 a pop). I've used the device on my 98 Legacy, 96 Maxima, 03 G35, my father's 03 Sienna, and multiple 96+ Honda owned by my friends.
#102
#103
Originally Posted by G35_TX
Every dyno I have seen including the ones this weekend have shown a loss. Also the cars have problems with dieing with the Injens as well. See my350z.com for loss power issues with injens.
