LED under glove box/steering wheel help
Old Apr 1, 2008 | 11:48 PM
  #91
Strtsk8r321's Avatar
So is there any way to have it hooked to the map lights but also turn them on while driving WITHOUT the map lights on
Old Apr 13, 2008 | 03:13 AM
  #92
Redpit10's Avatar
I just finished installing mine tonight. Just wanted to say thanks to Deftronix for taking the time to post the pics on the first page. Made the install much easier. Total cost for my install was only about $18. I bought some cheap autolumination leds. Came out good though.
Old Apr 15, 2008 | 11:26 PM
  #93
Bump
Old Apr 16, 2008 | 06:09 AM
  #94
Meatshackle's Avatar
Deep Sea Moderator
You'll have to install a relay with a switch.
Old Apr 16, 2008 | 06:42 AM
  #95
dvsmeth0dz's Avatar
i want this done too!
Old Apr 16, 2008 | 12:14 PM
  #96
k@osx71's Avatar
you can always do what i did and install a switch~ you're basically using the same power line your cig. plug used, that way you can turn it on and off whenever. it's a very easy install~
Old Apr 19, 2008 | 06:14 PM
  #97
Thanks. Where and what kind?
Old Apr 25, 2008 | 06:46 AM
  #98
328is's Avatar
Where did you purchase the ccfl tubes?
Originally Posted by Deftronix
You will definitely want to tap into the map light circuit.
This way it will come on when u push unlock, door open, turn your car off, etc.
I actually did something similar with 4 12" white ccfl tubes.
You can get to these wires right at the BCM (in front of driver side door)
Heres a picture with the info u need (this is the connector furthest right):
Pin 1: Red/Black (+12v)
Pin 8: Purple/Red (-)
Its very nice to have them go on/off automatically. Good luck!
Here is the final result of my install:
Hey deftronix, nice post. I'm going to be doing the same thing for my next project. I am just finishing up a halo project using aac ccfl tubes but find that their tubes (for headlamps) are not sheathed like yours. Where did you get the tubes? Thanks.
Eric - so cal
Old May 8, 2008 | 01:04 AM
  #99
Ching1206's Avatar
humm what gauge those wires are??
Old May 19, 2008 | 09:15 PM
  #100
Algy's Avatar
Okay, I have been wanting to do this project for a WHILE now.
My question is...
1. Where can i get the correct CCFL tubes??
Are these the right ones? http://www.svc.com/clk12wt2.html
2. What if i buy the CCFL tubes and there are 2 inverters??
3. Do I splice the wires that are originally in the connector (red/purple wires) to the black and red and just tape them up with black electrical tape? And how to i go about doing this?
Old May 27, 2008 | 11:07 PM
  #101
johnnydarko's Avatar
OK! So I'm not sure what to do next. I cut the wires from the pictures and connected the led wires. The LEDs turns on and work like they are supposed to.
HOWEVER they aren't as bright as they are supposed to be.
AND when I put neon lights to replace the LEDs, they didn't work at all.
Both the leds and neons where supposed to connect to the 12v via the cigarette lighter.
1. Was I supposed to cut the wires on the LEDs and put one on the negative and one on the positive?
2. Why won't the neons work when the LEDs did?
3. Am I supposed to use a inverter to channel more power to the lights?
4. Whats a inverter? and what kind am I supposed to use to power 2 10in neons and 2 6in LEDs?
Old Jun 9, 2008 | 01:38 AM
  #102
Deep Sea Moderator
Originally Posted by 2K6G35
Here is the video of my revised LED under glove.
As you can see from the video, the blue LEDs are automatically ON/OFF when I open/close the doors. I control the AUTO ON/OFF from the Dome Light switch. I also can turn them ON/OFF by pushing the left side dome light.
Seemless setup!!
Do you have any pics of how you wired it so the left dome light acts as a switch?
Thanks,
Old Jun 9, 2008 | 03:42 AM
  #103
lmSteveO's Avatar
Thanks,
Im glad people like my lil switch...it keeps the car nice and clean..no extra switches...
Red is ( + ) and black is ( - )
Old Jun 10, 2008 | 01:37 AM
  #104
Deep Sea Moderator
Thanks. After looking at it again I thought you might have soldered to the metal bars like that.
Great pic. Thanks again.
Old Jun 11, 2008 | 02:59 PM
  #105
dgburns's Avatar
Okay, I've been thinking of doing something like this myself. I have an 06 Sedan, and rather than blue or white I'm thinking it would be better to try to color match the gauge illumination? So something more orange? Having not dug into this much I don't know if anyone makes orange CCFL's? I like the more diffuse light so would prefer CCFL over LED.
