Reviews Reviews of specific modifications, posted by members
Stillen Engine Damper
Old Nov 12, 2007 | 01:57 AM
  #91
caskyline's Avatar
Former Vendor
here is a pic of mine installed. The cars that will get the main benifit of having this mod are 6MT's. I have a 5AT and didn't really notice a difference.
But not matter what car, you will only notice a difference when on hard throttle and shifting gears.
Old Nov 12, 2007 | 02:08 AM
  #92
Calvin's Avatar
Overglorified Altima
Originally Posted by caskyline
here is a pic of mine installed. The cars that will get the main benifit of having this mod are 6MT's. I have a 5MT and didn't really notice a difference.
5MT?
Simple typo.
Old Nov 12, 2007 | 02:27 AM
  #93
OCG35's Avatar
Originally Posted by aHero4Eternity
5MT?
Simple typo.
oh contraire... caskyline is a breed unlike any other... it is not only a 5MT but also one with hidden plasma vortex vaporizing annihilator!!!! It is the ****!!!!!!
No ONE has the Randy Tranny!!!!! (ooops, that sounds a little weird).
Old Nov 12, 2007 | 02:33 AM
  #94
caskyline's Avatar
Former Vendor
My bad, I am just learning how to type again.
Old Nov 12, 2007 | 02:38 AM
  #95
OCG35's Avatar
no plasma vortex vaporizing mechanisms?...
Oh well, I hope you can still paint headlight housing and taillight lenses!!!!!
Old Nov 12, 2007 | 02:42 AM
  #96
OCG35's Avatar
anyone that wonders about the reference to "plasma vortex"... google it... its better than nano technology!
And if you don’t think Randy (caskyline) has anything to do with it... you haven’t seen his car! Or his work!
Old Dec 6, 2007 | 01:20 PM
  #97
SpeedNStylez_JL's Avatar
Does this torque damper comes with install instructions? Also it fits the 6MT right? Wheres the best place to buy one?
Old Dec 6, 2007 | 09:33 PM
  #98
jonnylaw's Avatar
yes, but the instructions suck like all stillen instructions. Best place to buy one...hmmm let me think..stillen.com
Old Dec 7, 2007 | 12:31 PM
  #99
I believe in2win is in process of making some engine dampers with carbon fiber damper...keep a look out for it guys!!
Old Dec 15, 2007 | 02:11 PM
  #100
nfo184's Avatar
ooooo nice c/f coolant caps and such
clean engine
is it cut vinyl? or real??? i'm looking all over for these......and also so i dont switch topics, I installed the stillen damper also and love it.....makes a lil bit of vibration but car feels more power to the wheels
Old Jan 1, 2008 | 06:18 PM
  #101
penelson's Avatar
just installed 1/1/08
Hey guys. Just installed today on my 06 MT coupe. Did by myself in about 2 hours. A few things I would recommend. Loosen the top bolt and remove the bottom two bolts on the PS reservoir bracket and swing it out of the way. Remove the single bolt holding the coolant tank and pull it off it's mount and out of the way. Remove the two bolts holding the grounding wire to the lower frame so you can get the whole grounding wire thing/harness out of your way. Invest in a nice set of 3/8 drive hex sockets + various length extension bars. Use bungee cords (if by yourself) to hold the various lines and PS reservoir out of the way.
After one 5 mile test drive: The engine/exhaust tone sounds a little different.
No significant "extra" vibrations noted at the steering wheel or in the cockpit.
Can't say much about torque gains on one drive around town, but MT shifting does feel crisper, especially launching in 1st.
Old Feb 6, 2008 | 09:42 AM
  #102
Hi-TechG35's Avatar
Stillen Engine Damper Review
So since the weather was nice this weekend here in Boston I deceided to install my Stillen engine damper. The instructions where quite clear but the diagrams were a real PITA. The tools that you will need when installing the damper are are a 1/2 rachet with an extra long extension, 10mm, 12mm socket, a 14mm socket and, a flat head screw driver. The install time took me about an hour. The most difficult part in doing this mod was tightening the screw on the non-adjustable end of the damper that sits on the frame rail of the car. After the install I must say that the difference is highly noticeable! I can only speak on behalf of the 6MT owners. I felt an increase in torque and the power and best of all no vibration anywhere. This little mod is worth every $85.00 and then some :thumbup:. Prior to the install I notice that the engine would vibrate a lot so I did some research on the product and decided to give it a try. I'll take some better shots later on after degreasing my motor (as you can see I got some grease on the damper after lubing the holes for the bolts )
Old Feb 6, 2008 | 10:27 AM
  #103
GreenGoblin's Avatar
The goblin resurrection
looks good I am thinking of doing this in conjunction with solid motor mounts
Old Feb 6, 2008 | 10:38 AM
  #104
Hi-TechG35's Avatar
^Yeah the motor mounts are going to be next mod. I notice that are engines move a lot! The engine damper really helps out a lot in centralizing the motor so there isn't much vibration at all. Even my tranny chatter is less noisy now.
Old Feb 6, 2008 | 12:06 PM
  #105
RealDeal's Avatar
I just ordered one for the exact same reason. Adding a siff 3rd point, I figured, would really help reduce movement, as well as possibly extend the life of the motor mounts and transfer initial engine power to the driveline more effectively.
Glad it's a noticeable difference! Can't wait to get mine on!
