TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Oct 7, 2010 | 01:55 AM
  #1306
Jairen's Avatar
No tranny.
Old Oct 9, 2010 | 11:52 AM
  #1307
gspotter's Avatar
Originally Posted by rastaman
my 03 is half way between H and L after 2500 miles of driving is that ok? and what does that = to in quarts lossed?
That's only one-half quart in 2500 miles. You're fine.
Old Oct 10, 2010 | 02:26 PM
  #1308
bhancz's Avatar
has anyone experienced OC tests at either Riverside Infiniti or Miller Infiniti (In LA)??? If so, what service rep did you work with???
I need to start my SECOND oil consumption test
thanks!
Old Oct 14, 2010 | 11:49 AM
  #1309
BL4K L4V3ND3R's Avatar
I am currently going through my 1st oc test. They said it would take about 2 hours? Is that right? I asked if I failed the 1qt/1000 miles test then I clearly qualify for the replacement block, but the service rep said no I'd have to come back 3 times for them to decide that?!? And if anyone that has gotten this test in the Chicagoland area (orland park) pls let me know what they've done for you. All answers are greatly appreciated.
Old Oct 14, 2010 | 03:02 PM
  #1310
RA031524's Avatar
There is a new version of the TSB available. See here: http://x.infinitihelp.com/forum/loca...=76&linkid=878
My dealer in Calgary made the determination with only one test. I'm getting a new short block installed on Oct 25.
I read in another thread that I can't find now that a fellow doesn't have an oil change history of this car (he bought it second hand). It looks to me that this is covered in the TSB. Look at the flow chart. i think they were just jerking him around.
Old Oct 19, 2010 | 11:12 AM
  #1311
infinity27's Avatar
new short block
I am getting my 07 G35 back on friday with a brand new short block due to the oil consupmtion issue. Does anyone know the proper way to break this new engine in?
Old Oct 19, 2010 | 11:46 AM
  #1312
cynage's Avatar
you can find the instructions here
http://tinyurl.com/35vjwvx
Old Oct 19, 2010 | 12:16 PM
  #1313
Hammerhead i-Eagle Thrust's Avatar
rofl
or in that neat book that came with your car
Old Oct 19, 2010 | 12:27 PM
  #1314
infinity27's Avatar
google and owners manual.. thanks guys!
Old Oct 19, 2010 | 01:08 PM
  #1315
cynage's Avatar
I'm sure the dealership will tell you about it too.
If not, you can ask.
Old Oct 25, 2010 | 05:53 PM
  #1316
DivZero's Avatar
I got my engine replaced about 6 months ago.
Lately I've been noticing a burnt oil smell after long drives or strenuous drives. Also when I open up the oil cap, a vapor is inside, I'm not sure if it's smoke or not, but there's a definite vapor.
Do you guys think my new engine is burning oil too?
Old Oct 25, 2010 | 08:21 PM
  #1317
V35 Skyline GT's Avatar
6MT Coupe
^What's your dip stick say per 'x' miles.
Old Nov 1, 2010 | 10:00 AM
  #1318
black07g35's Avatar
Hey guys I need some help!! I have a 07 6mt and it's burning oil. I'm currently getting the OS done. My first reading, the dealership told me that the level was down a half quart in the first thousand miles, I went Saturday for my second measurement and they told me that it was down 9mm which wasn't in the no good range for 2,000 miles. Someone correct me of I'm wrong but I thought a half quart was 12mm on the measuring tape. So how would the car gain 3mm of oil in 1000 miles?!?! I told them I would be contacting consumer affairs but I want to be 100 percent sure before I do. The help would be greatly appreciated.
Old Nov 1, 2010 | 11:21 AM
  #1319
6MT Coupe
^ Your Dealer played you. Sounds like they topped you off for second return trip. First return = 12mm (.5qt) and second return = 9mm. Both in the 'no good' on chart.
Since they say 9mm in 2K mi and 'ok' on chart now, read TSB pg 8. Come back just prior to 2K or just after 2.5K. Make the chart work for you, not them.
And from pg 5:
11. Ask the customer to return to the dealer after 1000 - 3750 miles to recheck the engine oil level.
G/L
Old Nov 2, 2010 | 09:38 PM
  #1320
loki05's Avatar
~1000 miles + or - my car burned 1/2 the oil of the dip stick, this wouldn't qualify for OC test?
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
