I am running out of ideas of what my vibrations are caused by on highway
#77
#78
If there is a consistent pattern now, take it to your dealer while you still have warranty left! Those suspension/steering parts get kind of expensive. They know our suspension better than a generic mechanic. Make it clear to them that this problem is unrelated to the engine problem.
Last time i brought it to them for the vibration they couldn't "feel" it. Theres no way now they can't feel it..but still. I dont trust my car with them..would rather bring it to this tire shop who can do the same job (depending on what it is) for less. Just looked up the entire steering assembly..about $600 on Infiniti Parts...if i need this..i will seriously think about selling the dam car
its an easy check visually
Driving on the highway from work today it didn't do it for first 3 miles..but then it came on doing it's normal pulsating action. Very small and quick movements back and forth also causes it to vibrate.
#79
#81
So i think i am getting new tires
Well first off my front left tire is already starting to cup after only 2,000 miles. I had an alignment 3 days after i got the new tires at Infiniti. I am getting the alignment check at another shop tomorrow..if it's off spec i am demanding my $$ back from the dealer.
I am going to try and contact Yokohama and see if i can get my $$ back and put twords the Michelin MXV4's i plan on getting. They have a 30 day guarantee so even if it is still vibrating..i can get the 800 back and put back on the yokohamas.
#83
i did...but those tires were cupped bad so i don't really know
My car has been looked at twice on all suspension and steering components and all checks out..if this doesn't work..car gets sold by next month
Then it could be transmission..differential ect
Not dealing with that..would rather sell it
#85
I just had a brand new engine put in..i would hate selling the car with a brand new engine...
IInstead of getting a new car..i am just going to replace everything..shocks..control arms ect..because i cant find a car with everything that mine has for under 23K..man i got a good deal on mine
#87
#88
This past saturday when i swapped exhausts with a fellow member (zoop) the guys had to remove a drivetrain balancer on his car. He said that it should not affect the car but it seems like you would be faced with the problems that you are claiming to have. All stock cars have it, but if an aftermarket exhaust was installed it had to be removed. Im curious if this may be that cause of your problems? It is a big metal block bolted around the middle area right where you see the exhaust split to go to the mufflers.
#89
good god..i think it has been fixed *keeps fingers crossed*
Well i had them balanced one more time at this other shop..didn't change it. Went back and ready to order new tires. He said..let me try and balance them one more time before you spend $850...thank the lord he did.
It is actually gone. Slight vibration here and there but nothing like before. He said that 1 wheel in the front had a slight wobble that they spent 20 min to fix. They also said one wheel in the rear was very smooth and they moved that to the front. And that did it. I have more vibration in the seat now..but i can live with it. I knew it was my tires and or rims. So now i know that out of the 2 tires in the rear..1 or both are junk OR the wheels themselves are junk. I do however have more road feel now when they moved one of the rear tires to the front. He did this free for me.
I don't think i am every going to rotate these tires..i can't lose this smooth feeling!
I am getting heel/toe wear however on my tires. They only have 2500 miles on them. I have had 2 alignments done as well and all suspension parts are good even though i am at 65k and should replace shocks soon. I know heel/toe wear will make the tires louder..but hopefully no more vibration!
I think next summer i am going to get new wheels and tires for the complete smooth ride but as of now..i am good...(just went and knocked on some wood)
