DIY: Clean your throttle bodies
#406
#408
well the valve is nothing but engine deposits blowing right back into your intake so, figured i was just plug the intake where the valve connects and run the pcv valve down and out somewhere since its all gunk and oil spitting out of it anyways. then i saw on my350z people making a homemade catch can for under 20$ i might do that instead.
#411
My 2005 G35 Sedan (117k miles) had been idling a bit high (~800-900 RPM warm idle) and spitting the P0507 code for the past few months.
This past weekend I cleaned the throttle body, reoiled the pop charger, and changed the oil/oil filter. For the next two days my car was driving ANGRY. In drive/reverse it would warm idle at about 1000 RPM, in park or neutral I was lucky to get it under 1400 RPM.
After driving into work today to warm it up, I tried the throttle body relearn procedure. Started it up after successfully completing the relearn, and it's now warm idling in park at about 600 RPM. I'll be watching it closely for the new few days, but am hoping that I fixed the problem.
Just wanted to say thanks for all the troubleshooting that everyone had contributed to this thread. It definitely helped a lot.
#412
#413
#415
#420
