Tires for OEM 19s : The end-all thread
Old Jan 13, 2010 | 07:23 PM
  #421
infinitisport's Avatar
this thread sucks ***** - & liks 'em 2
bunch of retards playing rubbers when they should be playing condoms
Old Jan 21, 2010 | 04:19 PM
  #422
franksbanks's Avatar
Question tires sizes for stock 17" on 03 g35 sedan
so i was thinkng of getting some 225/60 r 17 for my stock 17"s..would that work??? i know that right now it has 225/50 r17', and they sit very good ..but I'm just curious to know.. and also if anyone knows what the max of tire width can fit on the tires/car..
thanks!!
Old Jan 21, 2010 | 04:32 PM
  #423
LightsOut's Avatar
SIETESG
225 is max on a 7.5 width rim
225/60 check with a tire calculator so see how much it throws you off
Old Jan 21, 2010 | 04:37 PM
  #424
Question
thanks for the quick response..i know the following question is a dumb one but im going to ask it anyways.. for a tire size for the "50" "45" on the 225/"xx" is the the measurement of how thick the tire will be right?
Old Jan 21, 2010 | 04:55 PM
  #425
LightsOut's Avatar
SIETESG
the xx" is the pecentage of the 225
Old Feb 2, 2010 | 09:45 AM
  #426
lost hybrid RF's Avatar
I have 225/35/19 in the front and 265/30/19 in the rear. The previous owner didn't have tpms sensors in them and drove ~ 500 miles on tires, Nitto 555 Extreme. I was wondering if I put tpms in them, will it be okay to run on them?
Old Feb 2, 2010 | 09:16 PM
  #427
SacG35's Avatar
i got 235/35/19 in front and 255/35/19 in rear and they are michlein ps2 sports there great
Old Feb 10, 2010 | 12:25 AM
  #428
g35man04's Avatar
CLUB MODERATOR
I plan on going tomorrow to get my rears changed out on my car and I am running the stock setup right now as far as tire sizes go....
If I left the fronts alone for right now and went ahead and changed up the rear should I go with the 255/40/19 or 255/35/19...im not lowered right now but plan on throwing on some springs..I have 25mm spacers front and 30mm spacers rear. I would like to wider on the rear tire but want to stay within the safety net....with that being said I am needing to replace the fronts as well so would be okay to go with a 245/40/19?
Old Feb 10, 2010 | 12:52 AM
  #429
blaccG35's Avatar
^ im also wondering this also but if IIRC the ideal tire size foe the 19's are F 245/35/19 R 255/40/19 can anybody confirm this thanks
Old Feb 10, 2010 | 11:31 AM
  #430
LightsOut's Avatar
SIETESG
245/40 is to tall, go with quote below this
its been confirmed through out the entire thread...
Old Feb 10, 2010 | 12:31 PM
  #431
g35man04's Avatar
CLUB MODERATOR
thanks lightsout! I am ordering mine today. Probably getting Hankook Ventus V12 evo K110. Can I up to a 265/40/19 or not recommended
Old Feb 17, 2010 | 11:08 AM
  #432
izeroi's Avatar
Need some answers to tire combos (tried to read most of this thread until I just got a huge headace from seeing all of the different tire combos being thrown out there lol).
I currently have G37 rims on my G35 coupe, and I'm dropped on S-tech. The fronts are 225/45/19 and the rears are 245/40/19 (stock size tires for both front and rear G37 rims).
*Fronts are 19x8.5 Offset +43
*Rears are 19x9 Offset +45
Now, the problem I' am having are my front tires are tucked under the car and rub, the rears are fine and there are no issues there. In a week or so I'll be ordering new tires and I need find a tire size that will allow clearance with the drop I have as well as keep the vdc happy. I'm sort of a noob when it comes to tires so any help would be appreciated.
Would me going with a F: 225/40/19 and a R: 245/40/19 clear this up or would I need to go with a taller tire in the rear and a shorter one in the front?
Also, I have 20mm spacers in the front and 25mm in the rear, so if I were to go with a wider tire would there be some rules I would have to follow? I just basically want to get a tire that's going to fit properly without and issues.
Old Feb 17, 2010 | 12:27 PM
  #433
LightsOut's Avatar
SIETESG
you have the setup I wanted to go but I just never went through with it.
245/35F
275/35R
add 15mm spacer front
20mm spacer Rear for conservative look. more aggressive will be 20-25 or 25-30 and fender roll.
best option I would have gone with was 15 front 25 Rear
Old Feb 17, 2010 | 04:42 PM
  #434
izeroi's Avatar
Awesome, thanks for your help man.
Old Feb 21, 2010 | 01:20 AM
  #435
syshs's Avatar
Hey Chris,
Did you go with 255 or 265 in the rear?
