Hello all from Tire Rack
Old Dec 6, 2011 | 07:44 AM
  #661
finallygot1's Avatar
You get paid (enough to own a G no less) to blog? Sweeeet
Old Dec 6, 2011 | 06:25 PM
  #662
neal@tirerack's Avatar
PLATINUM SPONSOR
I dont' see any problems with those sizes, should fit wheels fine and work well with VDC. The V12's are a great tire but on a pretty heavy backorder. If you liked the Kumho's might want to stick with those.
Call me when ready!
Old Dec 7, 2011 | 08:42 PM
  #663
bboynicku's Avatar
Call me when ready!
Sounds good neal! will def call when ready! I've switched to my winter wheels/tires now so it will be a while...
Old Dec 7, 2011 | 08:52 PM
  #664
bboynicku's Avatar
Call me when ready!
thanks Neal! will def call when i'm ready. will be a while cause i just swapped out to my snow wheels and tires...
Old Dec 8, 2011 | 04:07 PM
  #665
PLATINUM SPONSOR
Sounds good!
Old Dec 12, 2011 | 10:18 AM
  #666
thundercracker's Avatar
hi,
have an 08 g35x, needing new set of rubber. looking for an all-season, something that can get me through the Boston winters. Not a spirited driver. my criteria, in order of importance:
- low noise
- decent life (40k+ miles or better)
- serviceable in the winter snow
- less than $150/each.
i've had some yokos and eagle gt on my last wrx, and the g now runs on some b-stones, but they are wearing out after 30k mil.
suggestions?
looking at bf goodrich advantage t/a (but worried about reviews about noise) and yoko envigor.
others to consider?
thanks
Old Dec 12, 2011 | 02:15 PM
  #667
PLATINUM SPONSOR
Pretty decent selection of tires in that price range. The Yoko Envigor would be my first choice for a sport all season tire. Should get 45K or so, pretty quiet, good handling. A step in the longer life quieter ride direction would be Kumho's LX Platinum. About 60k, softer ride, quieter, but not as sport based as the Yoko. Both good tires... just depends on if you want the performance or luxury side.
Call me when ready!
Old Dec 17, 2011 | 04:58 PM
  #668
soundmike's Avatar
Hi Neal, nothing sales related but i've been having trouble with inside lip rubbing on the front sway bar at full lock with the RP03's i bought from you folks a while back. To address the issue i've added a 5mm spacer using the OEM lugs. I'm able to get 7.5 full turns on the nuts, your site recommends a minimum of 8. What are your thoughts on this?
Thank you.
Old Dec 19, 2011 | 02:39 PM
  #669
PLATINUM SPONSOR
Really need the eight turns for proper engagement. Might need a slightly smaller spacer to allow more exposed stud.
Old Dec 19, 2011 | 04:01 PM
  #670
GAU-8's Avatar
Interested to know if you can order XXR's? Your site doesn't list them. There's only a handful of places I know of that carry them. Mostly online stores too.
Old Dec 19, 2011 | 04:44 PM
  #671
PLATINUM SPONSOR
Sorry, can't get those.
Old Dec 20, 2011 | 04:55 AM
  #672
HI,
so what have you heard about the kumho ecsta 4x? seems like a good value, and it tested well on tirerack.com ? i'm worried about treadlife though, but for $99/tire, i have to consider it...
so my options, kumho ecsta 4x, then the kumho lx then yoko envigor or avid trz...
i'm worried that the 4x's will only last me 2 yrs (30k mi), while the other options might last 3 yrs (given no unforseen pothole/damage)
Old Dec 20, 2011 | 03:10 PM
  #673
Originally Posted by thundercracker
HI,
Ordered today! thanks neal for the suggestions and easy transaction!
Old Dec 20, 2011 | 03:52 PM
  #674
PLATINUM SPONSOR
Thank you for the order!
Old Dec 29, 2011 | 12:17 AM
  #675
Canadiotica's Avatar
Hey Neal,
Looking to pick up a set of summer tires for my new rims I just ordered which are 18x8.5 +25mm offset for a 2005 Infiniti G35x sedan no mods, not sure what size tire would give the best fitment with stock suspension for now. Also a fair priced tire and any good brands you recommend , I don't mind a bit of stretch.
Any info would help this noob out greatly, thanks!
