Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 3, 2011 | 06:18 PM
  #1891
qbanboy's Avatar
Because i can't spent $3.000 in a set of rims, i`m happy for the people that can, but i can't....if i see a good looking rims for half of the price that's what I'm getting...Wolks, T1s, ETC they are good wheels but the price is insane, if i hit a pot hole, i gonna have to spent $1000 in a single rim, bro thats crazy as long as the car looks good i`m fine with that.....
Old May 3, 2011 | 06:25 PM
  #1892
qbanboy's Avatar
By the way does anyone know where i can get stock suspension shocks for my G35 Coupe 06? i think i just gonna get the tein springs....but i need to replace my old shocks....
Old May 3, 2011 | 06:30 PM
  #1893
dcityjatt's Avatar
Originally Posted by Will_Ireally_AM
im getting sum 526 xxrs and they come in 20X9 and 20x11 what tires should i get for a nice flush look?
where is dre when you need him
first of all-post your offsets to help determine how flush you will be
the size of tires could vary depending on how much you are looking to drop the car, and the amount of camber you are willing to run.
Old May 3, 2011 | 06:47 PM
  #1894
Will_Ireally_AM's Avatar
the offsets are +15mm my b im new to all this and i plan on lowering it on g35 s techs or 350z h techs idk about camber
Old May 3, 2011 | 06:50 PM
  #1895
qbanboy's Avatar
if you want info about this you should look in the 123 to 126 i think you have some info there....... xxr 526 15+ offset
Old May 3, 2011 | 07:17 PM
  #1896
4D05G35's Avatar
Are you wanting OEM shocks/struts due to cost?
Personally I wouldn't buy used shocks with more than 20K miles on them and finding OEM with less than that might be hard. They are around, but it might take a while.
Tokico HP are a good cost affective alternative to OEM replacement. They will match the higher spring rate of most aftermarket springs better. They will also last longer with the new springs than OEM will.
If you get 350z shocks/struts they will have a shorter rod (body is the same length) which would also match the lower stance from the new springs.
A few vendors on here sell them for good prices.
Old May 3, 2011 | 07:26 PM
  #1897
4D05G35's Avatar
Originally Posted by GSoccer24
How about 18x10 +25 all around on a 2007 G35S Sedan?
The rear will fit with a rolled fender and a little neg camber (see my pic a few posts up that 10" +25 also). I am not sure on the front. Outward fitment will probably be the same.
Old May 3, 2011 | 07:27 PM
  #1898
qbanboy's Avatar
I was thinking in getting the coil overs but i`m not sure.....this car is my daily drive so dont know if spending $1100 on suspension will be worth it... i want something smooth no hard....what is the difference between coil overs and springs... will spring only will be more softer? or coil overs are both softer and adjustable? i want 20 so dont know if just springs will give me that nice drop look....will like the car to look even no more drop in the front and less in the back...
Old May 3, 2011 | 07:35 PM
  #1899
qbanboy's Avatar
Right now the car has EIBACH springs in the front And factory In the back
Front is 5 inches front and rear 8 1/2 inches..... front the floor...i will like to get at least 7 rear so i guess im going to get those coil overs my friend......
Old May 3, 2011 | 07:41 PM
  #1900
4D05G35's Avatar
Check out the thread in the suspension section called "pirate coilovers" or similar to that.
Most coilovers will allow tuning of the shocks (rebound and dampening) so you can tune them to your liking (softer, firmer etc) and height adustability usually from 0 to -4" some more or less.
Coils will lower your car a set amount and thats it. Depending on which ones you go with they may be softer or firmer than OEM springs. I ended up with coilovers after several sets of springs. I like the ability to adjust my ride height to my liking along with tuning of the shocks.
Used set-ups show up in the marketplace here often. I have seen some good deals, but you have to be ready to jump on them when you see them otherwise someone else will ****** them up.
Old May 3, 2011 | 07:44 PM
  #1901
qbanboy's Avatar
I was cheking on ebay and they have the Basic teins coil over for $845...
  #1902
4D05G35's Avatar
What are you measuring from? The rear of your car is 3.5" higher than the front?
Old May 3, 2011 | 07:45 PM
  #1903
qbanboy's Avatar
yes sir...
  #1904
qbanboy's Avatar
because i bought the car like that....i guess who had it just drop it in the front
Old May 3, 2011 | 07:47 PM
  #1905
4D05G35's Avatar
Someone correct me if im wrong, but I believe the Basics dont allow for tuning of the shocks/struts, just height adjustment. If thats the case I would spend a little more and get adjustable shocks/struts.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
