Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Nov 18, 2011 | 04:56 PM
  #2641
4DGS's Avatar
Originally Posted by rhampsterwha2
Yeah exactly, though my budget is 3k for wheels so I can't have what I want brand new unless there's a group buy or I find them used in great shape
If you guys know of any 20" step lip or concave wheels in a silver finish let me know!
I'll keep and eye out but just keep looking on here (marketplace) as well as my350z.
Originally Posted by knoxboys
need some help. been searching threads looking for what size tire to get for the new rims that will keep the computer happy. 04 coupe wheels are axis shine 19x8.8 front 19x9.5 back. thanks
245/35 and 275/35 will probably be your best bet. But 245/40 up front would work as well.
Old Nov 18, 2011 | 09:51 PM
  #2642
CheeWho?'s Avatar
Originally Posted by 4DGS
There is an inch difference in overall diameter from 35 to 40 sidewall. What size wheel is it? 19?
Nah, 18's. My gut choice was 40 to help fill in the wheel well more bc of the smaller wheel, but was doubtful bc of the lack of clearance when running a sidewall that big and riding slammed.
Old Nov 19, 2011 | 05:57 PM
  #2643
4DGS's Avatar
What specs are you looking at? And defined slammed for me.... lol You and I may have different definitive cars of Slammed.
Old Nov 19, 2011 | 10:25 PM
  #2644
CheeWho?'s Avatar
18x9.5 +0/10.5 -10. And by slammed I mean like 1.5 - 2" clearance at most. Thats pretty slammed to me atleast lol.
Old Nov 19, 2011 | 10:43 PM
  #2645
jbrueggemann84's Avatar
Got a question. 2008 G35x A/T
Currently stock height. Want to use Eibach springs to drop 1.4" in front and 1.1" in rear. Will I see tire tilting and need camber adjusting? also is that enough room for a 18" with low profiles?
Old Nov 20, 2011 | 09:12 PM
  #2646
Ceeds23's Avatar
Just bought an 06 g35 coupe w/ sport tuned suspension and I have stock 19s, would GTM wheels 18" with Goodyear RSA tires be a compatible set up? Note: I don't have much background in cars.
Old Nov 21, 2011 | 06:23 PM
  #2647
4DGS's Avatar
I can't remember your initial question, please ask again with all given info and I will answer.
You'll need and alignment but you want need camber arms, the drop is too small.
There's enough room for a 20 with some serious tire. 18s are kind of small for the G so I recommend going larger. Your OEM wheels are larger in some cases on the second gen.
Not enough info to give a valid suggestion. Get me specs on the wheels and tires and I can try to help. I avoid goodyear tires like the plague though. Just me.
Old Nov 21, 2011 | 08:24 PM
  #2648
CheeWho?'s Avatar
I'm running 18x9.5/10.5 +0/-10 respectively. On 225/245's. Dropped with ~1.8" of clearance to the ground. I was wondering would a 35 series be better than a 40 considering I'm running 18's.
On a side note, I think they should change the thread to "Have a Question/s about wheels? Ask 4DGS here" lol. Thanks in advance for the help man.
Old Nov 22, 2011 | 12:57 AM
  #2649
vq35dedriver's Avatar
^ forget changing the name of the thread, 4DGS should be part of the staff/mod
Can you run 215/45/r18 square setup on oem 18s?? For coupe
Old Nov 22, 2011 | 04:33 AM
  #2650
4DGS's Avatar
Haha, Yea I seem to be the only one in here on a regular basis now.
Personally I would not go to the 35 (this come from someone who ran 18s this past summer with 40s and 35s)
I ran 18x10 18x11 225/40 and 255/35. The tires were way to small and a straight up bitch to get them to look how I wanted. The 40 sidewall gives JUST enough meat on the tires to make it not mess with VDC too much and not make the overall diameter too much.
I'd do the 40 sidewalls for sure. If you go to 19s then 35s are the way to go.
I'm an ******* in the other 90% of this forum so me being a mod would reflect the staff poorly lol however, me being mod of ONLY wheel and tire section would be bad ***
Yes you can run 215/45/18 square without an issue, it's not an ideal set up but I'm gonna take a shot in the dark and say it's for winter use?
Old Nov 22, 2011 | 12:38 PM
  #2651
^ yes winter use lol
That's what I meant a mod only in this sub forum
Old Nov 22, 2011 | 01:02 PM
  #2652
4DGS's Avatar
Then yea go for it man, that's a great winter set up.
Old Nov 22, 2011 | 03:18 PM
  #2653
hologram's Avatar
So 18x9, and 18x10 on 245/40 265/40 on stock suspension @ +20/+18 F/R rub at all at stock height? Its not that I dont wanna roll fenders, I cant find any fender rollers in phoenix lol.
Old Nov 22, 2011 | 04:20 PM
  #2654
4DGS's Avatar
I'll try and find you a roller by the end of the night.
Was that for a sedan or coupe? If coupe then yea you're fine.
Old Nov 23, 2011 | 12:23 AM
  #2655
hologram's Avatar
Its a coupe. And thank you sir!
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
