Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 12, 2011 | 07:44 PM
  #1996
tpc303's Avatar
So with being lowered 1.5 inches should I run a 20mm spacer up front and no spacer in the back? my wheels are +41 in front and +37 in back and they are 19's
Old May 13, 2011 | 02:39 AM
  #1997
salamsg35's Avatar
thx for each person that helped me answering me questions.
just got my wheels 20/8.5 +20F 20/10 +20R tires 245/30/20F 275/30/20R
this is a pic
click on the link for the pic
Old May 13, 2011 | 01:30 PM
  #1998
Swiftyk6's Avatar
alright i was looking into this a little more and thanks for all the advice but the smallest size adapter i could find for my wheels is a 1 inch (25.4)mm and its 5x114.3 into 5x112. the rims are F- 20x9 +35 w/ 245 35 20 R- 20x10 +44 w/ 285 35 20. will my back tire fit with a 25mm adapter> obviously the ideal would be to test first then purchase but i dont have that option anyone running this set up? Also i'm dropped on TEIN S techs
Old May 13, 2011 | 04:58 PM
  #1999
qbanboy's Avatar
[QUOTE=salamsg35;5869319]thx for each person that helped me answering me questions.
this is a pic
click on the link for the pic[/QUOTE
Post some pics man I can't see the link....
Old May 13, 2011 | 05:30 PM
  #2000
TheChairman's Avatar
I have an 04 coupe and just got a set of wheels with 19x9 +47 front, 19x10 +30 rear offsets. No mods yet but eventually getting coils and either 20mm or 25mm spacers. What would be good tire sizes with which spacer to get a flush look?
Old May 14, 2011 | 12:28 PM
  #2001
4DGS's Avatar
Can't tell you if I don't know the widths
Contact these guys
http://www.motorsport-tech.com/
Terrible offsets, even with running spacers you'll be pretty far off the flush look. The rears are doable with a 30mm spacer but the fronts will need like a 40mm spacer.
Old May 14, 2011 | 06:43 PM
  #2002
tpc303's Avatar
Sorry about that they are 19 x9 +41f and 19 x 10 + 37r. Also can I run 235/35/19 F and 275/30/19 R and still be at a close enough rolling diameter to run on my X?
Old May 14, 2011 | 06:59 PM
  #2003
Nightcrawler's Avatar
How about all you idiots wanting to run spacers all the time actually buy wheels that fit? Do you realise that 1). spacers are illegal, and 2). they are dangerous as hell, as the wheel doesn't sit perfectly flush with the rotor face as it was designed, as well as introducing either an extra set of nuts to come loose (in the case of bolt-ons), or significantly higher radial load than any stud was designed to take.
Old May 14, 2011 | 08:03 PM
  #2004
T-Money23's Avatar
I'm running Tenzo Type M's 19x8.5 F and 19x10 R, with 245/35/19 +17 and 275/35/19 +22 Offsets. I currently dropped my car on some Z-HTechs and have no rubbing issues.
I'm wondering if anyone knows if I do the .5in springmount mod in the rear will I rub? and need my fenders rolled? Thanks...
Old May 14, 2011 | 08:46 PM
  #2005
4DGS's Avatar
Whoa wait you're in a sedan? Yea you'll be fine with that. I'd recommend a 245 over the 235 though. And no spacers
Do you realize that 1) no they aren't and whoever told you/made that up is almost as dumb as you for believing it. and 2) Nuts don't come loose when torqued down properly, and if you've ever even seen how a spacer mounts you'd know they are hub and wheel centric.
So unless you have questions, shut the **** up and go make a thread.
(if you want to argue with me some more about bull**** go read my thread about spacers and why I hate them)
Personally I'd roll the fenders, but it really wouldn't be neccessary, you'd probably only rub in hard corners. However, if you roll the rears you could throw a 10mm spacer on there and be much flusher and still rub free.
Old May 14, 2011 | 11:00 PM
  #2006
tommynsxs2k's Avatar
help with tires
hi guys needing help for my g. its a 2006 g35 coupe sport package. i have now are work vs xx. 18x9.5 +21 and 18x11 +26. tires are 215/35 and 245/40. dont look that good with huge gap. dont want to drop the car. i want them to fit without fender roll. what size tires should i go with thanks
Old May 15, 2011 | 02:23 AM
  #2007
salamsg35's Avatar
these are some pic
http://flic.kr/p/9H3VEo
http://flic.kr/p/9H12sV
http://flic.kr/p/9H3Vyq
Old May 15, 2011 | 04:19 AM
  #2008
gowner's Avatar
Painting DG 18" Wheels
I am interested in painting my original 18" wheels and have someone in town who I feel I would do a great job at it. My questions to all of you are: What color would best fit my Diamond Graphite coupe? Should I just paint them the original color? How about gunmetal? Also, have any of you have tried this (painting them gunmetal) and if so, do you have a DIY procedure or the color codes you used to do this? Thank you in advance to all who read my post.
Fabian
Old May 15, 2011 | 12:04 PM
  #2009
tpc303's Avatar
What do you like better about the 245's? The reason I ask is because I can get a really really good deal on Nitto Nt 05's if I go with the 235's up front.
Old May 16, 2011 | 12:41 PM
  #2010
4DGS's Avatar
Who the **** did you buy those off? Those are retarded tire sizes.
1. Wheels will look ghetto unless you lower the car.
2. Roll the fenders, it's not a big deal and it's better than tucking the wheels or cutting a tire.
3. 255/35 up front and 295/30 out back would be aight.
The 245 is closer to the rear diameter and these cars have enough oversteer as is. the 235 would be fine, but if you're buying NT05s, sounds like you drive the car pretty hard so I'd go with the larger front.
Just before you buy those though... They can not be driven in the rain, I've had Nt05s before and you'll hydro going like 30mph. Terrible wet grip.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
