Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 28, 2011 | 11:24 PM
  #2116
Will_Ireally_AM's Avatar
20x9.5 -7 offset and 20x10.5 +0 offset or a 20x9 +0 20x10 +6 witch ones will look better lowered on g s techs
Old May 31, 2011 | 03:38 PM
  #2117
4DGS's Avatar
Assuming this is a coupe.
The first set up will need a little bit of stretch (tires) and a little camber in order to fit.
I would recommend the latter.
Old May 31, 2011 | 08:40 PM
  #2118
Anh's Avatar
Anh
I'm just bought wheels that are:
19x9.5 f +17 and came with 255/35/19
19x10.5 r +19 and came with 285/35/19
The rears needed to be replaced so I bought a 275/35/19 because I didn't want it too bulky in the rear....will I have any problems running :
The old 255/35/19 fronts
With the new 275/35/19 rears?
Please and thank you.
Old May 31, 2011 | 08:42 PM
  #2119
G_Ride09's Avatar
I have always got really good info from this thread so I figured I'd ask my question here because the the Z forums sucks.
I just recently picked up a 350z and wanted to know if anyone knew how aggressive I can go on the wheels. (MAX LIPS) BTW IM GOING TO BE RUNNING AIR SUSPENSION
Old May 31, 2011 | 09:09 PM
  #2120
NNOCENT's Avatar
once you decide on a wheel, ht me up and i can source it for you
Old May 31, 2011 | 09:19 PM
  #2121
G_Ride09's Avatar
keep your eyes out for 20x11 +0 front and 20x12+0 rear.
Old Jun 2, 2011 | 02:12 AM
  #2122
4DGS's Avatar
Nope, you'll be fine.
It's pretty limitless with air... Milts Garson wheels are up for sale right now.
19x10-6 19x12-12
$3200
or if you're a real boss, these are brand new in boxes.
20x10.5 -16 20x12.5 0
$3200
Old Jun 2, 2011 | 03:21 AM
  #2123
G3V's Avatar
G3V
i find its difficult finding used wheels for my g35 locally, is it uncommon to run 19x7.5 +40 with like 25mm spacers all around? wouldnt that essentially be similar to running 19x9.5? or are the spacers like running 19x7.5 +15
Old Jun 2, 2011 | 12:02 PM
  #2124
4DGS's Avatar
19x7.5 is dumb. It not only looks bad but fits ****tier than OEM, even with a 25mm spacer.
You're going to need to up your budget I think.
Old Jun 5, 2011 | 03:39 PM
  #2125
Perry123's Avatar
does anyone know a reputable dealer of vossens in georgia?
Old Jun 6, 2011 | 01:58 AM
  #2126
4DGS's Avatar
Anyone who sells vossen isn't reputable.
Look in the vendors section or go to your regional.
Old Jun 7, 2011 | 12:09 PM
  #2127
NorthDakota's Avatar
Stock sedan x will 19x9.5 +40 fit all around without modification?
I'm stock height now but I might lower with coupe sport springs.
Old Jun 7, 2011 | 01:00 PM
  #2128
4D05G35's Avatar
Yeah you will be just fine.
Old Jun 7, 2011 | 01:02 PM
  #2129
4D05G35's Avatar
Use this link to compare your current wheels to the new ones you want. It will tell you how much more or less inner and outer clearance you will have.
http://www.1010tires.com/wheeloffsetcalculator.asp
Old Jun 7, 2011 | 02:22 PM
  #2130
4DGS's Avatar
Depends on tire size, if you get crazy on the tires then it may rub in hard corners (once dropped not at stock height)
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
