Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jun 10, 2011 | 04:44 PM
  #2161
4D05G35's Avatar
^ thats if you run the 255/35 up front. With a 245/35 or narrower you shouldnt have to.
Old Jun 10, 2011 | 05:23 PM
  #2162
DGP-G35's Avatar
Thank you 4D05G35, much appreciated.
Hopefully at stock height it will not rub at all (not even the liners over big bumps).
Jason
Old Jun 10, 2011 | 06:27 PM
  #2163
4D05G35's Avatar
You're welcome. Glad to help.
Old Jun 10, 2011 | 06:49 PM
  #2164
Will_Ireally_AM's Avatar
Smile
Will I rub with 20x9 +18 20x10.5+20 with tein G stechs I have 245/30 and 275/30
Old Jun 10, 2011 | 07:46 PM
  #2165
Calamity's Avatar
So I came in here to double check.
Getting AvantGarde M310s, i think im going with 19x9.5 +22 all around with 245/35/19 front and 275/35/19 rear. I shouldnt have any problems, but will this setup look awkward without being staggered? im currently at stock height. also was thinking that if it does, i could just get a spacer for the rear.
could also possibly get a 19x11 rear but some say ittl rub, some dont. i think that may be a bit wide too.
Old Jun 10, 2011 | 07:49 PM
  #2166
4D05G35's Avatar
The front you are fine. The rear might need a slight rolling of the fender.
Old Jun 11, 2011 | 06:30 AM
  #2167
Gsedan6mt's Avatar
I have an 06 sedan rwd with rolled rear fenders, Just wondering if someone can tell me if 19x9.5 +40 would work for me all the way around. Also what size tire would you run if it does work? thanks
Old Jun 11, 2011 | 06:36 AM
  #2168
Fender rolling in Ga
Does anybody roll fenders in the kennsaw or marrieta area? Becuz this shop I went to they dot know what rolling the fenders mean lol
Old Jun 11, 2011 | 01:17 PM
  #2169
4D05G35's Avatar
Yes you will clear no problem. 255/35/19 or 245/40/19. Is the car lowered?
If the car is lowered a bit you could even run a 245/35/19, but IMO at stock height those tires look to small.
Old Jun 11, 2011 | 03:21 PM
  #2170
Gsedan6mt's Avatar
thanks for the info, im on a g/z drop right now. so u think a 245 40 19 is ok?
Old Jun 11, 2011 | 03:27 PM
  #2171
4D05G35's Avatar
The 245/40 is slightly larger than stock(26.7"), but you will be fine. What size of wheels/tires do you have now?
Old Jun 11, 2011 | 03:39 PM
  #2172
Gsedan6mt's Avatar
23545r18 stock sport wheels and tires
Old Jun 11, 2011 | 04:41 PM
  #2173
4D05G35's Avatar
This is on an 18" wheel, but the width and tire is the same.
http://www.tyrestretch.com/9.5_245_4...40_R18.jpg.php
the 245/40 will be a very minor stretch so you might want to run a small spacer to bring them a little more flush. With the fender rolled and the 245 you could probably run up to a 10mm spacer.
Here is a 255/35, but once again in an 18. The sidewall height and stretch will be the same.
http://www.tyrestretch.com/9.5_255_3..._R18_2.jpg.php
I ran 255/35/19's with a 19x9.5 + 40 on my car in the past. The set-up cleared just fine without needing the fender rolled.
Have you purchased these wheels yet?
Old Jun 11, 2011 | 05:16 PM
  #2174
Gsedan6mt's Avatar
havnt purchased wheels yet, just checking fitment
Old Jun 11, 2011 | 05:33 PM
  #2175
4D05G35's Avatar
ah ok. gotcha.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
