Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Aug 3, 2011 | 12:50 AM
  #2311
wijiboy's Avatar
Originally Posted by 4D05G35
Check your door jam, it will tell you the stock recommended tire pressure. Since you have wider tires you can run a little less pressure. What are your wheel offsets? Coupe or sedan?
Coupe, offset is +12... Are you less tire pressure
Old Aug 3, 2011 | 01:32 AM
  #2312
4D05G35's Avatar
I just got new tires and haven't made any changes to them yet. I have been driving the car very little due to this nice weather i'm on my bike. In the past I have ran the pressure a little lower.
Old Aug 3, 2011 | 01:49 AM
  #2313
anthonychavez's Avatar
i have a 2008 g35 sedan lowered on h tech springs. i am going to buy the concept one RS8 20x8.5+30 all around not sure what tires to get, i want a flush look but not to agressive, the wheel shop recomended 265/35 general tire any recomendations
Old Aug 3, 2011 | 03:22 AM
  #2314
4DGS's Avatar
Always run 32psi unless your stretch, if you stretch then you should understand tire pressure before you dive into that shallow pool.
What wheel shop might this be? 265 is technically an over sized tire for 8.5" (Too wide) wheel and also an incredibly tall tire for 20" wheels (more than an Inch taller than stock)
If you go with the 8.5+30 then I would recommend 245/35/20.
Old Aug 3, 2011 | 11:34 AM
  #2315
apexi957's Avatar
Best offset for 19x10 all around? I dont care about tire stretch, but i dont want to pull fenders, add more camber or lift/lower it
Old Aug 3, 2011 | 12:08 PM
  #2316
Calamity's Avatar
You'll probably rub in the front depending on the offset... i'd roll your fenders
Old Aug 3, 2011 | 01:09 PM
  #2317
blk35's Avatar
If some can please help me out, I have 04 sedan will a 20x11 +25/+15 work or just keep dreaming?
Old Aug 3, 2011 | 01:51 PM
  #2318
Thx for the help 4dgs I will most definitely tell the tire shop about that messed up size the recommended
Old Aug 3, 2011 | 02:06 PM
  #2319
4DGS's Avatar
Assuming it's the sedan in your signature (I've been wrong on that assumption before lol)
Are you lowered? The offset you're looking for is going to be roughly +36-+40
However, I cant recall how much inner clearance the second gen sedans have and weather or not the front wheel would rub on the strut with that high of an offset.
JDM_cain and myself are both running 11s in the back. If you don't know someone that can do good fender work and you don't know about stretching and camber then these aren't for you...
What are the front specs?
You're looking at lowering the car pretty damn low, putting a 255/35 or 245/35 tire on it, running about -4 degrees of camber and then pulling the fenders the rest of the way.
The rear will end up looking something like this (18x11 +20 255/35/18 -4.7 Degrees of camber)
Np
Old Aug 3, 2011 | 11:55 PM
  #2320
apexi957's Avatar
Yea I'm lowered on BC racing BR. I already decided to run a 19x10 all around +30(f)+25(r)
Old Aug 4, 2011 | 10:13 PM
  #2321
luger303's Avatar
Any body ever seen stock rims with a .20 or .25 spacer? Quick fix for a horrendous wheel gap problem?
Old Aug 4, 2011 | 11:25 PM
  #2322
hdmark's Avatar
im getting my OEM 18s powder coated black but im wondering if i can do a polished lip on them? what type of metal is the sport 18s? (04 coupe if it makes a difference)
i know they are allow, but aluminum allow? sorry, i am still learning alot about cars and i started with audio first lol so bear with me.
thanks!!
Old Aug 4, 2011 | 11:28 PM
  #2323
4D05G35's Avatar
Yeah there are a few pics floating around on here with 25mm front and rear. Some do 30mm/25mm, or 20mm/25mm.
Old Aug 5, 2011 | 12:29 AM
  #2324
Hey do u think I could fit the 245/40/20 w/o any probs
Old Aug 5, 2011 | 09:10 PM
  #2325
4D05G35's Avatar
Thats a tall tire, even taller than the 265/35 that the shop recommended you. I would keep it to the 245/35/20 that 4D recommended. 245/35 is just slightly larger than stock and will look good.
http://www.zeforged.com/downloads/20...oze-041911.pdf
OE sizes are about 26.3" O.D. It's best to stick around that size. Some run smaller, but thats usually because they are slammed.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
