Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Aug 5, 2011 | 10:06 PM
  #2326
who4ever's Avatar
hi guys
planing for forgestar F14 20" F9.0 R10.5
what is the best offset for G35 sedan (v36)
with no lowering kit (OEM)
Old Aug 5, 2011 | 10:27 PM
  #2327
TheloniousMonk's Avatar
When buying rims, how do we know what offset to get if we want a flush look?
Old Aug 6, 2011 | 01:30 AM
  #2328
4D05G35's Avatar
http://www.1010tires.com/wheeloffsetcalculator.asp
You can put in your current wheel specs and what the new ones would be. It will tell you how much the wheels will stick out, or in compared to the wheels currently on your car. It will also tell you how much more/less inner clearance (between wheel and suspension) you will have.
Another great thing to do (as I spent countless days doing) is search through the pic forum and/or fitment threads to get a visual of how the wheels fit on other peoples cars. There are a few posts floating around
https://g35driver.com/forums/picture...some-nsfw.html
https://g35driver.com/forums/media-s...tch-sedan.html
Old Aug 6, 2011 | 08:04 PM
  #2329
4DGS's Avatar
Originally Posted by who4ever
hi guys
Aim for about +30 in the front and +40 in the rear.
I strongly suggest a simple 1" drop though, it will tie everything together much better.
Old Aug 7, 2011 | 09:16 AM
  #2330
Nail's Avatar
Does anybody have Privat Legende wheels on their coupe? I'd love to see what they look like IRL if anybody has pictures
Old Aug 8, 2011 | 05:45 AM
  #2331
4DGS's Avatar
Sorry don't have on a coupe, but here's one of Grant's Sedan.
They're nice wheels for sure!
Old Aug 8, 2011 | 08:03 AM
  #2332
Nail's Avatar
^Those look pretty good, are those 19's?
Old Aug 8, 2011 | 02:10 PM
  #2333
NorthDakota's Avatar
would these https://g35driver.com/forums/20-inch...k-w-tires.html work for an 04X lowered on coupe sport springs. front will fit fine. I'm just iffy about the rear. tires on the rears are 275/30
Old Aug 8, 2011 | 08:03 PM
  #2334
4D05G35's Avatar
You would need to change the rear tire and roll the rear fender flat. You would need to run a few degree's of neg. camber, or pull the fender, and run less neg. camber. The rear fitment is similar to mine (20x10 +25) and I am rolled flat with a slight pull and -2.1 degree of camber. You would want to match the O.D of the front and rear tires being that you have an X.
I think you can make it work, but IMO you are better off with a square set-up or go with a slightly less agressive staggered set-up.
Old Aug 9, 2011 | 03:35 AM
  #2335
4DGS's Avatar
18s actually.
The rear offset is a little on the low side for you height.
Old Aug 9, 2011 | 11:46 AM
  #2336
LILShiraz's Avatar
Looking to get these Nissan SE-R wheels for my winter set up, will they fit a 2007 coupe?
Edit: they are 18's
Old Aug 9, 2011 | 12:25 PM
  #2337
Calamity's Avatar
What spacers would you guys recommend I run for a more flush fit? 19x9.5 wheels all around
http://www.flickr.com/photos/63250530@N06/5909312127/http://www.flickr.com/photos/63250530@N06/5909312295/
Old Aug 9, 2011 | 02:45 PM
  #2338
4DGS's Avatar
Edit: they are 18's
They will be very sunken in, but yes they will work...
What offset, what camber and are the fenders rolled?
Old Aug 9, 2011 | 03:06 PM
  #2339
Calamity's Avatar
+22 offset all around. not sure on the camber until I get another alignment, and all fenders have a mild roll
Old Aug 9, 2011 | 08:59 PM
  #2340
LILShiraz's Avatar
I am lowered as well. I just want a cheap winter set up, would it look decent with some 20mm spacers?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
