Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Jun 22, 2011 | 01:47 PM
  #2191
Calamity's Avatar
Originally Posted by 4DGS
Well you shouldn't need the alignment since you didn't change and suspension. It COULD be out of wack though.
9.5 +22 should not be rubbing what so ever on a stock height car. The fronts sound like they're probably rubbing on the fender liner screw at about 12 O'clock. Remove that and see if the rubbing goes away. The rear sounds like you have blown struts or the rear is sagging out and banging wheel.
Find someone to roll the fenders to be safe but I have never heard of a coupe rubbing with specs like that. My Z has unrolled fenders and its 10.5 +22 (12mm more aggressive than yours) and it doesn't rub even in hard corners.
I needed an alignment before I even thought about wheels, but waited to get it done all in one shot. Then the shop I went to wasnt able to do it
I think i see the liner screws you're talking about. Heres a pic of where I think the tire is rubbing. You can see the marks on the sidewall pretty well, most of it wiped off though. This is from those screws right? And it's fine to just take them off?
Old Jun 22, 2011 | 07:45 PM
  #2192
iamchris's Avatar
Originally Posted by iamchris
Hello. Just picked up some rims but now I'm looking for spacers! Rims right now are ...
Front = 20” x 9” +37
Rear = 20” x 10” +40
Dropped on Tein S-Techs. 2004 coupe.
will +25 mm spacers all around be fine without rubbing? Can I go +30 without rubbing?
To 4do5g35
Fronts are 225/35/20
Backs are 245/35/20
Old Jun 22, 2011 | 08:34 PM
  #2193
4D05G35's Avatar
I would think that you should be good with 30mm front and rear with rolled fenders.
Old Jun 22, 2011 | 11:44 PM
  #2194
iamchris's Avatar
Hmm how far can I go without rubbing?
Old Jun 23, 2011 | 12:14 AM
  #2195
Calamity's Avatar
Getting my fenders rolled on monday.
Old Jun 23, 2011 | 02:19 AM
  #2196
4DGS's Avatar
Yea Calamity, looks like that is the issue. If you're getting them rolled the guy or shop should be able to point out and other problem spots (if he has any idea what he's talking about)
Old Jun 23, 2011 | 02:22 AM
  #2197
Calamity's Avatar
I removed one of those liner screws and it seemed to fix some of the front rubbing. The rear is still banging when I go over dips at a decent speed though.
The guy doing it is local, cheap, and real reputable, so i'm not too worried. Kinda makes me regret not getting the 19x11 rear now lol. Guess spacers and a drop will be in the near future though.
Old Jun 23, 2011 | 02:26 AM
  #2198
4DGS's Avatar
Good to hear, glad I could help!
Old Jun 24, 2011 | 12:28 PM
  #2199
Pepper's Avatar
Specs:
19 x 9.5 -8 (spacers) 235/35/19 -3.5 camber (natural)
19 x 10.5 -2 (spacers) 255/35/19 - 3.75 camber (natural)
I want to go 5mm more in the rear but I need to drop down in tire size. Should I go with a 245/35 or a 245/40?
Old Jun 24, 2011 | 04:05 PM
  #2200
4DGS's Avatar
245/35
Old Jun 24, 2011 | 04:44 PM
  #2201
Calamity's Avatar
What kind of spacers you think i'd be best off with 4DGS? Especially to make the rear a bit more staggered.
Probably gonna get some springs soon too, until I can afford a camber kit.
Old Jun 24, 2011 | 05:32 PM
  #2202
iamchris's Avatar
Backs are 245/35/20
Updated with pictures! Still no spacers still thinking about spacer sizes.
rears
fronts
so yea how far can I go without rubbing. Hope those pics help a little bit.
Old Jun 24, 2011 | 06:15 PM
  #2203
4DGS's Avatar
The ebay brand ones are about as good as ichiba and cheaper. I'd go with those if you don't plan to take them on and off once a week.
Old Jun 24, 2011 | 06:17 PM
  #2204
4DGS's Avatar
Backs are 245/35/20
rears
fronts
Is the rear rolled? if it's rolled you'll be fine with 30mm all around. Remove the screw in the front fender liner at 12 O'clock. It will cause some rubbing occasionally.
Old Jun 24, 2011 | 07:12 PM
  #2205
Calamity's Avatar
You mean the springs or spacers? I won't be taking them on/off often, if at all.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
