Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Aug 25, 2011 | 04:00 PM
  #2416
pghg35sedan's Avatar
Would 19x9.5 +38 wheels fit on an 04 Sedan? What would be needed to make these wheels fit? I am lowered on BC Racing BR series coilovers.
Thanks for the help!
Sam
Old Aug 25, 2011 | 04:17 PM
  #2417
4DGS's Avatar
Originally Posted by MisterG35Tee
Here is what I am thinking about getting:
Front Wheel Size (include offset): 20x9+20
Rear Wheel Size (include offset): 20x10+25
Front Tire Size: 245/35/20
Rear Tire Size: 275/30/20
Front and rear spacer size: You'll probably want some
Suspension type: Lower it
Alignment info: None
Fender roll required: Roll the fenders anyways, but not not required.
Other questions:
- Will I need to drop my car for it to look right or will stock suspension look ok? If a drop is recommended, any specific brand recommended?
No drop will look stupid with wheels, lower the car.
- Will the tize size listed above have be stretched on the wheels size
No
- Will tires rub with this size? Will I need to roll fenders?
No
- I have also had problems with the inside of my stock front tires prematurely wearing with the stock alignment. Any alignment recommendations to avoid the premature wear?
Get aligned by people that know what they're doing. These cars are known for tire wear problems. It isn't an economic car so you will have to deal with some things like that.
- Any opinions on going with 20s versus 19s?
Ride is shittier on 20s
- Any tire brand recommendations that are that will last long and arent too expensive?
hankook V12
Sam
They will fit fine, I recommend rolling your fenders if you drive the car hard.
Old Aug 25, 2011 | 05:26 PM
  #2418
Hmmm..I'll need to find somebody in the Pittsburgh area with a roller or a shop that can roll them. I don't know as much as I would like about wheels fitment and offset. Your help is greatly appreciated.
Old Aug 25, 2011 | 06:28 PM
  #2419
4DGS's Avatar
You're that far east eh, I have 4 or 5 guys that can do it in Philly.
Old Aug 25, 2011 | 07:21 PM
  #2420
Calamity's Avatar
Originally Posted by Calamity
I'm currently on 19" wheels, with a kuruma front and lowered on 350z h-techs
Will I be able to put my OEM 17"s back on for winter and have enough clearance or will I be way too low for snow?
I know you said I would be able to do this but how much do you think the wheel swap will drop me?
Old Aug 25, 2011 | 07:24 PM
  #2421
Philly is kind of a haul lol. I'll have to look around local and see if anybody can do it.
Old Aug 25, 2011 | 10:46 PM
  #2422
4D05G35's Avatar
What are the tires sizes that you are running on the 19"s, and what are the tire sizes that you are running on the 17's?
Take the overall diameter of the 19's (say 26.5") as your baseline then take the overall diameter of the 17's (say 26.0") then devide the difference in half and that = your change in ride height. For this example your car would sit 1/4" lower.
Old Aug 26, 2011 | 12:30 AM
  #2423
MisterG35Tee's Avatar
Thanks for the advice!
Any help with the wheel offsets/specs? Will the wheel spec I listed achieve a staggered look, concave, and a lip in the rear wheels (specific to Vertini Magic)?
Old Aug 26, 2011 | 05:01 PM
  #2424
4DGS's Avatar
That's a question for the wheel company. (the concavity and lip size)
As for the specs, roll the fenders and throw a 15mm spacer on the back and 10mm on the front.
I noticed they have an 11" rear wheel, why not go for that? figure out the offset on the 11"
Old Aug 26, 2011 | 08:44 PM
  #2425
J350GT's Avatar
I'm currently looking at a set of XXR 522's.
Just a bit iffy on the setup for the rears.
19x8.5 +15 Front
19x10 +20 Rears
What would be the best tyre size for those rims as I'm also planning on dropping the ride either on H-Techs / S-techs. Would like to avoid rolling my rear guards as much as possible.
Old Aug 26, 2011 | 09:44 PM
  #2426
4DGS's Avatar
Roll your fenders or don't even ask about what the best set up is, because the answer is there is none. Roll the fender or don't bother.
Roll the fenders and add a 15mm spacer in the back and a 10mm in the front and you should be happy.
Old Aug 26, 2011 | 11:08 PM
  #2427
J350GT's Avatar
figured as much lol Thanks for the info
Old Aug 27, 2011 | 12:08 AM
  #2428
Cabos G35 Coupe's Avatar
Are Ventus Sport K-104 good to stretch a lil 235 35 19 on 19x9.5?
Old Aug 27, 2011 | 07:50 PM
  #2429
LILShiraz's Avatar
Would these be a good winter wheel on a lowered g35 coupe? no bbk
http://washingtondc.craigslist.org/m...568216391.html
http://washingtondc.craigslist.org/n...555077396.html
Old Aug 29, 2011 | 09:55 PM
  #2430
agedog2gt's Avatar
Wow. This thread is perfect.
my question is:
I am purchasing 20" XXR 521 black with chrome step lip. Im going 10.5 " on tire width all the way around. I to plan on lowering the car as well. I am looking for somewhat of a flush look. Any ideas on tire size for front and rear?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
