Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 26, 2012 | 07:00 PM
  #3286
susu510's Avatar
What do you guys use to clean your wheels? I have some work vs-ms wheels with a polished lip/gunmetal face and I want to clean them without scratching/messing them up. All advice and feedback is greatly appreciated. Just want to pamper them the same way I do to my car with washing and waxing lol thanks in advance!
Suel
Old Apr 26, 2012 | 09:46 PM
  #3287
kei's Avatar
kei
I have a 05 sedan and I was about to purchase 19x9.5 +42 with a 245/40/19 tire for the front/rear but was told that the fronts may not fit and possibly hit the control arm. Can someone tell me if I would be OK? Would adding a spacer fix it. Not sure if I would still be tucked or more out, sorry.
If it's not ideal than I plan to go
F:19x8.5 +38 | 225/40/19
R:19x9.5 +42 | 245/40/19
Unfortunately the rims I want does not offer other offsets. I plan to roll fender if I need to. Thanks.
Old Apr 27, 2012 | 01:15 AM
  #3288
soniic11's Avatar
Suel
i find wheel cleaners to be too harsh for the most part. Car soap a microfiber sponge to remover dirt and dried with a terry cloth always works for me
Old Apr 27, 2012 | 01:16 AM
  #3289
DrewDrew's Avatar
Originally Posted by Pepper
What camber kit is recommended to add some negative camber? (1-2 degrees)
Front or rear? I'm guessing front.
Old Apr 27, 2012 | 01:18 AM
  #3290
soniic11's Avatar
Originally Posted by MidKnight
What size tires should I run on 20x8.5 F and 20x9.5 R wheels? I Want them to be low profile but I also don't want to be getting new tires all the time.
hard to tell depends on the drop and offset of the wheel. aggressive offsets and/or drops will need camber adjustment to get it close to stock spec. post drop and offset to get a better idea.
Old Apr 27, 2012 | 12:57 PM
  #3291
Pepper's Avatar
Apologies, front is correct.
Old Apr 27, 2012 | 07:23 PM
  #3292
4DGS's Avatar
Originally Posted by MPG35fiend
eibach pro spc
New arms, those are for small adjustments they don't really correct heavy drops.
Originally Posted by luisp88
approximate what offsets should i look for, for my 05 g35 sedan
front 19x9
rear 19x9.5
front 19x8.5
rear 19x10
19x9 +30 or more
19x9.5 +36ishish
19x8.5 +20ish
19x10 +43ish
Originally Posted by Crustybug
So I've been looking into the xxrs and tsws for my 05 sedan, and I definitely want 18s or 19s, not sure what I should rock for width and offsets though. Most guys on here are okay with rolling fenders, but what can I run w/o a roll, on a z spring/strut setup?
Depends on the width, what wheels are you looking at?
245/35 and 275/30 (or 265/30)
SPL is the only real suggestion. Megans are cheap but ONLY add negative camber, so keep that in mind in you decide to pick those up. (SPLs are $500 megans are like $250)
Suel
Invisible glass or any quick detailer spray (might be called a spray wax depending on the brand)
Adding a spacer will definitely fix it. and you'll have room for one up to about a 15mm spacer. You should be fine with that set up.
The second set up also works but again, since they are smaller you'll want a spacer just to make them look right.
You also have room for a larger tire out back if you wanted.
Old Apr 27, 2012 | 07:28 PM
  #3293
Pepper's Avatar
I picked up a set of SPC's
Old Apr 27, 2012 | 08:09 PM
  #3294
4DGS's Avatar
You're low right? Do you like banging noises?
Old Apr 27, 2012 | 08:15 PM
  #3295
D-ASSASSIN's Avatar
Okay so I have a question of my own. I have the second generation sedan "08 G35xs" and want to run Varrsteon 2.2.2 19x8.5 +32 offset front and 19x9.5 +35 offset rear. Heres the question can I run these at stock height and should I change/request a different offset?
Old Apr 27, 2012 | 08:17 PM
  #3296
Pepper's Avatar
They rattle?
Old Apr 27, 2012 | 08:19 PM
  #3297
D-ASSASSIN's Avatar
anyone ?
Old Apr 27, 2012 | 09:26 PM
  #3298
lsvtec4dr's Avatar
Originally Posted by lsvtec4dr
Here's the drop because honestly, I don't know how low I am:
Setup is Megan Coils and Megan rear arms. I do not have arms in the front, however the front area chassis is slotted up front so the camber can be adjusted from the bottom of the wheel vs. the top. Seems like by bringing the camber in from the lower side threw my offsets off by a few mm. For example, my +5 in the front sits like a +8-10mm.
Camber is set close to spec. Rear is around -1.8~-1.9.
My rears fenders are rolled flat. Front fenders aren't rolled, but the thicker tires up front brought my fenders out just a wee bit.
Wheels are 20x9.5/10.5 +5 all around with Yoko S Drives. I know the Yoko's have a little thicker side wall.
New setup:
20x9.5 -12 and 20x11.5 +1
Tires are gonna have a little better stretch, so I'll either run Toyo's or Falkens. 225/35 and 255/35 or 265/30. What do you guys think as far as camber settings and would I need a fender pull on front or back or both?
Any suggestions?
Old Apr 28, 2012 | 01:40 AM
  #3299
soniic11's Avatar
Wheel guru's quick question, will 19x11 +15 clear the front strut and arm without spacers? Non brembo setup coupe.
Old Apr 28, 2012 | 02:04 AM
  #3300
DrewDrew's Avatar
They rattle?
They sometimes smack the...top of the fender/up inside the fender actually. Did that make sense? lol sorry. Mine occasionally smack on bumps. :/
Any suggestions?
Don't run Falkens. Front tire size is perfect. The rear is really up to you, the 265/30 will stretch like a 245/35. You could also run a 275/30 or 255/35, they're nearly identical. I'd go with the first option myself. Pull isn't absolutely necessary, but you're looking at -4* camber front and rear with no other fender work. I'd get a mild pull, about 10mm or so, front and rear, so you can be under -3*. But it's really up to you how much camber you want/willing to run.
Yea. No prob. 11.5s have enough clearance too.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
