Thanks man will I have to get my fenders rolled when I get it lowered? And do you think it will look good going 10 all around?
Quote:
single digit positive.Originally Posted by Bunthis2
For 20x9.5 front and 20x11 rear sitting on 235/35/20 and 275/30/20 would would be a agressive strecth look in offsets with out the wheels sticking out to much
Following specs won't rub on a sedan right assuming no fender modifications? Done my research but just want to double check
18x8 +30 225/45/18
18x8.5 +33 245/45/18
18x8 +30 225/45/18
MPG35fiend
close
- Join DateFeb 2010
- LocationVirginia Beach, VA
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:302 Times in 223 Posts
no it won't rub, you'll need to be worried more about being too low. 225s are pretty small.
i have 18x8.5 w/ 245/40 all around slammed to the point if i go any lower id be permanently scraping!
thats what I'm upgrading STANCE with 19s.
I have a 2007 G35x and I'm planning on purchasing a set of WORK VS-XX in 19's. I want the wheels to sit nice and flush with the fenders but not a "hella flush" look. The car is lowered on Eibach springs. What offset and width should I go with for the front and backs? And what tire size? I want a minimum of 2.5- 3.0 in lips.
I see, I think I'll be fine with those specs, SD Genius used same tire widths just a different aspect ratio (40) front and rear on his wife's sedan, paired along eibach prokit front rear and it looks fine. Thanks for the inputOriginally Posted by MPG35fiend
no it won't rub, you'll need to be worried more about being too low. 225s are pretty small.i have 18x8.5 w/ 245/40 all around slammed to the point if i go any lower id be permanently scraping!
MPG35fiend
close
- Join DateFeb 2010
Quote:
no problem bro! glad i could help out... Originally Posted by dominate
What up guys. I have a dilema. I want to put some 5mm spacers front and back on my 03 g35. My issue is that i am not sure whether i need longer studs or not. I have had many different responses. I dont know what to think anymore.
most companies who sell spacers say anything over 3mm need extended studs.
edit: blain, when you see this. your recent pics look like your wheels still poke a lot at your drive height...but, do they still tuck in the fenders on huge dips? your ride can't possibly be that stiff...
edit2: also, you happen to have any saved pics of jeff's 225/245/30 stretch, or any really? google images and rimtuck were all mislabeled and couldn't find anything. I think that's what I'd move to when I get bags.
What about if I want more of a square set up with 18x10.5+20 all around, with a really light stretch?
Quote:
18x8 +30 225/45/18
Most likely not. Originally Posted by dominate
Following specs won't rub on a sedan right assuming no fender modifications? Done my research but just want to double check18x8 +30 225/45/18
My rear is 18x8.5 +33 265/40/18 lowered down to about 1.5 finger gaps, i had to roll the rears if people was in the car. But after the ROLL, no issues period, i've actually went down to 1 finger gap now.
First question, Bump stops!Originally Posted by DrewDrew
most companies who sell spacers say anything over 3mm need extended studs.edit: blain, when you see this. your recent pics look like your wheels still poke a lot at your drive height...but, do they still tuck in the fenders on huge dips? your ride can't possibly be that stiff...
I'll have to fig up some photos but if you take a look at Jeff's Stance Nation feature those are all pretty high res.
Quote:
What if what? Dunno what you're asking.Originally Posted by ss284
Sorry. what tires should I run for a square set up on 18x10.5 all around?Originally Posted by 4DGS
First question, Bump stops!I'll have to fig up some photos but if you take a look at Jeff's Stance Nation feature those are all pretty high res.
