Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#3826
the guys running more aggressive setups on the awd is there awd still on? bc I've read that it can be turned off..
#3827
What issues will I have trying to fit this wheel and tire up front on a coupe? Being a 20/11+15 is it safe to assume I won't rub the inside on any suspension parts? Will a pull and tire rub be my biggest concern? So trying to make a educated guess from the last 20 or so pages I read piecing info together. Thanks!
Overall
25.47 in 646.93 mm
Sidewall
3.23 in 82.042 mm
245/35/19
Overall
25.75 in 654.05 mm
Sidewall
3.37 in 85.598 mm
That's 1.09%
#3829
so i go by the diameter, not the circumference?? or idk?? don't know much how to calculate percentage. ![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
heres the calculator i used..
http://www.miata.net/cgi-bin/tirescgi
#3830
What Tire Size Do you Recommend?
I have an 2007 Coupe. Not lowered and no spacers looking for some tires for my
F: 19 x 9.5, +16
R: 19 x 10, +4
They came with 245/35 and 275/30. Time for new tires and looking for a different setup. What do you guys recommend? Keep in mind this is my daily driver.
F: 19 x 9.5, +16
R: 19 x 10, +4
#3836
Drew, you're right that it isn't the same in that instance, but I said 255 for two other reasons.
the first being it's the same as a 245 on 9.5. and second, 255/35 is much much more popular tire size for companies to make than 265/35.
I only mentioned the 245 and 275 examples to imply 255 on 10 isn't a big enough stretch that it would look retarded on stock height.
msuman05 (07-12-2012)
#3837
#3839
Post pics, this has gotta look weird....
